dikman
Everything posted by dikman
  1. Sorry, but I'll have to resort to asking. Uwe posted some posts/photos on his experiments with top mounting a servo but I'll be blowed if I can find them! I think they were inside another post, can someone point me in the right direction?
  2. Good combo, between them you should be able to sew almost anything.
  3. I agree, that label doesn't indicate it was actually made in Germany. I can't help wondering why that label is damaged so much?
  4. Hard to tell in the photo, but is the actual take-up arm broken or is it the bent guard that you're concerned with?
  5. WD-40 won't harm anything and is pretty good at loosening grime, just don't rely on it as a lubricant or for rust protection. As for "rust reverser"? I haven't heard of that before, rust is a process of metal erosion, once the metal's gone you can't bring it back. Are you thinking of Rust Converter? This stuff basically neutralises the rust and seals it by chemical reaction (it normally consists of phosphoric acid). Can be pretty useful on stands etc before painting, but I'd be wary of using it inside a machine. Another concoction for loosening stuck parts is a 50:50 mix of acetone and auto trans fluid. Many people swear by it. Sounds like a good buy and should be an interesting challenge.
  6. I've still been searching both aliexpress and alibaba trying to find a match to that unit R8R has posted, but with no luck. I can't find any servos rated at 1100w, the closest is 800w, this model is a close match at 800w and the control panel appears to have the same functions (LT-800W, made by Lishui). There also don't appear to be too many that start at 100 rpm, all the ones I've looked at start at 500 rpm. Curious.
  7. Excellent! Thank you Wiz.
  8. Interesting. I just checked mine, I have two types, a 550w and a 750w, same brand (Lishui). The 750w is 68mm and has a round front, the 550w is 70mm and has a square front like that planetary gearbox.
  9. Thanks mate, you're right and I'm an idiot! Not long ago I bought some 190R's for one of my other machines and forgot about it! They are indeed the length I want, but I'm facing the same issue I had before - I can only get them in 110/140 size and garment point. I'll have to try and source them from overseas to get leather point.
  10. Don, if you're referring to the one R8R pictured it appears to be pretty much identical in construction to my servos (in other words, fairly "standard" construction).
  11. My Seiko uses 135 needles. Is there a needle type that is the same shank diameter but about 3-4mm longer?
  12. Well, I've gone as far as I can to get the synchroniser working. The belt wasn't long enough to try the 4" wheel and my other belts are either too short or too long. I recall that when I first got it it worked fine but the pulley ratio was pretty much 1:1. It might work at 2:1, but I'm beginning to suspect not. The unit I have appears to be a pretty generic type as supplied with several servos, so probably pretty basic.I suppose the last two days haven't been completely wasted as I've learned something (and made a nice bushing for my big pulley). Matt, good luck with trying to achieve what you want, I'm sure it can be done - with enough money! Me, I'm back to a tiny pulley on the servo and I can crawl the Seiko and it easily punches a #140 needle through 1/2" of veg.
  13. A bit more info for those who might like to know these things. I fitted the 3" (actually 75mm) pulley and it works fine! Actual ratio is 2.73:1. Whether it's firmware or software is probably irrelevant but I would assume that it's programmed to only work up to a particular ratio, and if so then logically one would expect it to be a whole number and 3:1 would be a good guess. What I need now is a 2 1/2" pulley in order to prove this, unfortunately it's not a common size. Now to experiment with settings and see if it suits my needs with the 3" pulley. It's now an hour later and it's not as simple as I thought. If I go slow it stops fine, needle up or needle down, but if I run it fast it appears to get very confused when I take my foot off the pedal and shudders slowly for 3 or 4 stitches and then throws up an error. Next thing is to swap the 3" pulley for a 4" (2:1) and see what happens. Only problem is I'm running out of belt adjustment! It's obvious that it's no longer going to be an option for me as I'll lose the slow speed and torque I had, but I need to know at what point the synchroniser will work (the info may be of some value to others).
  14. Very nice! I actually like that "honey" colour as it has a nice warm feel about it. Great job on the stamping.
  15. At the moment I'm using a simple belt, unlined, with a right side holster and a left side cross-draw. I angle the belt across my waist so that the right side holster sits lower, this places the cross-draw at my front left and higher. Both holsters are angled on the belt. If I'd used a heavier/lined belt it might have been too stiff to sit at the angle across my waist. If you have two holsters, left and right, then yes, the ranger belt will probably give better support.
  16. Is the right length needle fitted?
  17. Could be a fairly involved project, Matt. I guess my next step is to replace the motor pulley with a 3" and see if that works. This will give me a ratio of 2.67:1 compared to the current 4.5:1. I don't particularly need the synchroniser, but now that I've invested this time and effort it would be nice to get it working. And I need to know.........
  18. Matt, I hate you! You piqued my curiosity, I knew the synchroniser wouldn't work with a pulley reduction system (I tried it), but you got me thinking "did I actually try it with a (very) large pulley?". So I just spent all day to prove it one way or the other - and you're right (unfortunately). I had to make a new sleeve to fit the pulley to the shaft as I needed it more accurate than the existing one and also machined the end to take the synchroniser. Took most of the day! Then I had to move the control box from the left side of the table to the right side 'cos the cable wouldn't reach. While I was at it I swapped the motor and controller over, as one of my tables had a 750w motor which I felt would be better on the Seiko. So at the end of the day I tried it and found after 1 1/2 stitches it stopped and gave an error message indicating a synchroniser problem. The two pulleys, by the way, are a 1 3/4" on the motor and an 8" on the head. I wonder at what ratio it stops working?
  19. Excellent job on the belt! Why not make the holster belt in the same style (if it's good enough for Clint Eastwood )? As to your question, I think you've answered it yourself, the only reason to make the billets single layer is to make it easier to feed through the buckle (or use two layers of thinner leather). It would certainly look better lined.
  20. I also had a look at Alibaba but so far haven't found anything like it. I did find one with the knob control and a couple of push buttons next to it which looked interesting. If I need another one sometime I might consider it.
  21. Thanks for clarifying things Matt, now I understand where you're coming from and can see where a synchroniser would be a real asset. I just spent some time on Aliexpress trying to find that "German" motor (I wondered where they sourced it from). I was looking for that particular control panel, but the only match I found didn't have a synchroniser, although it did come in 600 and 800w models. Unfortunately my Chinese is non-existent so I couldn't make any sense out of the instructions!
  22. Fair enough. Personally, I found that once I'd slowed everything right down for sewing leather I didn't need the synchroniser, if anything I found it to be a nuisance. I can see where they would be an advantage for high speed sewing, particularly with small stitches, but in my case it would sometimes give an extra stitch and with larger stitch spacing the last thing I needed was an unwanted extra hole!
  23. Technically, a California-style Slim Jim with a Mexican Loop half skirt. Very similar to Cullen Bohannon's holster in Hell on Wheels (except his was plain and grotty looking ). Very nice job indeed. Of course, you realise that you're supposed to give details too? Like colour used, finish etc?
  24. Oh? Have you tried it? It should work as the ratio between the two pulleys is constant, whereas fitting an intermediate speed reducer means the ratio varies as far as the synchroniser is concerned. That will definitely cause issues (well, it did with mine).
  25. Replace the handwheel with a (much) larger pulley. I'm assuming you have the smallest pulley you can on the motor? This will give you a considerable speed reduction and allow the use of the needle synchroniser, This is my Seiko. I did the same on my Pfaff 335.
