Everything posted by dikman
Neat way of making the frame for the reducer, already has lots of holes for attaching things!
One thing I've found useful is using the machine, without thread, to punch the holes first. With careful planning I can do the two edges of the holster while it's flat (before folding) and with a bit of luck they line up for gluing. I then use an awl to widen the holes for the needles/thread. It keeps the stitches in line and the spacing uniform. That 31-15 would probably do that (hand cranking, and single thickness only) but I would still hang out for a reasonable walking foot if I were you. My first effort with one of those multi-prong punches looked good on top, not so good on the back - I found out that you have to make sure the punch is kept absolutely vertical! Tried a drill press, didn't like it.
Welcome Jaybogg, you did the right thing by asking here first. If you want to sew 1/2" of leather you're going to need a decent machine, preferably a walking foot and with a servo. If you're only sewing knife sheaths I'd stick to hand stitching - It gives a stronger stitch and you can use heavier thread. I still hand stitch holsters as none of my machines can handle that thickness of leather or thread any heavier than #138 (it's a big jump to the type of machine needed and I can't justify it).
servo motor Servo motor with syncro and speed reducer
dikman replied to Reacher10's topic in Leather Sewing Machines
The needle positioner that I bought with my servo worked fine - until I fitted a speed reducer pulley setup. It did not like it one bit! So I removed the positioner. Fitting a small motor pulley and a (very) large pulley in place of the handwheel works great for slower speed and extra torque without messing around with pulleys and bearings and shafts. -
Been a busy boy, Dwight? Look good.
Man, that's a bit of a beast! And I thought my 750w servo was pretty good...... That edge guide looks pretty good for $24.
More like 1400 rpm maybe?
When I bought one of my servos I bought a needle positioner as well (seemed like a good idea at the time). I tried it, of course, but soon took it off as I found that with the slow speeds used for sewing leather it wasn't really needed (and, in truth) I found it a bit of a nuisance.
I thought I'd add my experiences to this thread (which, by the way, has some very good info in it). I decided to have a go at making walnut dye and did a lot of reading. I soaked the husks for a while, then boiled them and let them soak a while longer. After straining through some calico (very time consuming) I ended up with a nice dark liquid. My first effort at dying leather wasn't that successful. I soaked a piece for a couple of hours and let it drain dry. The leather hadn't changed colour much, although there was more darkening just along the edges. I might have to let some of the liquid evaporate to thicken it up a bit. Anyhow, I've decided to have another go with this year's crop - the birds (cockatoos) start to get into the nuts while they're still green so I'm not going to get an edible crop (again) so I might as well make some use of them. This time I'll try something different that I read about. I started off with the complete nuts soaking in a large bucket, soon there was a second bucket, then two more buckets full of nuts, with more to come, so I used a largish wheelie bin, with a lid, and dumped them all in it and as the birds drop more nuts I just throw them in whole. Being Summer (and bloody hot!) the bin is in the sun and heats up the water/nuts inside which should speed up the fermentation. Now for the good bit, an easy way to hopefully make the dye - I'll just leave the whole lot to stew for at least a year! One chap posted that he was doing the boiling/simmering thing but also had a heap sitting in a barrel outside and he found that after a year or so it produced a dye that was no different to the stuff he'd been boiling/simmering/peeling. It also means that if, for some reason, the dye doesn't work I haven't wasted lot of time (and fuel) making it.
LH holster - JLS pattern
dikman replied to JKHelms's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That has a nice "used" look about it already. -
That's an interesting idea, although not much use to me as my meagre supply of thread is moved between different machines.
ndnchf, perhaps you could call that "flight of fancy"? Suits the machine quite well.
Pretty classy with that nice polished steel (would look a bit out of place next to my machines ). I find the bog-standard ones more than adequate for my needs, but maybe one day.....
Hard to see from the photo but it looks to be nice and clean. Unless you've got very good foot control you might need more than a small pulley to use it for leatherwork.
Pity you're on the wrong continent, a 155 would be nice. On the other hand, maybe it's a good thing that I can't get them . I'm surprised someone hasn't grabbed them already, as it's a very good offer.
Ka Bar Knife Sheath
dikman replied to Forester's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Staples inside the stitch line? Seems strange to me, I wouldn't want any metal in the sheath where it could catch the blade edge. -
Looks good! How did you avoid the teeth marks from the foot? And getting #138 to work is pretty impressive (bet you don't get much on the bobbin!)
Scrap Leather Crossdraw
dikman replied to Eddie Q's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The ones that look like chicken scratchings? -
Nice, but I reckon a full skirt would look a little better aesthetically. I like the random pattern, what did you use to make it? -
I wouldn't drink it either . I just wanted to point out that it's made from crude oil, rather than being a natural product. (When I saw the name "Saddler's Oil" for some reason I just assumed it would be a natural product). As you say, the important thing is whatever works, and you're obviously getting good results from it.
I was curious what U82 Saddlers oil is, it's just under 100% Solvent naptha (petroleum) heavy aliphatic, the rest being alcohol! I'm sure it works, but I think I'll stick to neatsfoot oil, beeswax, tallow etc.
Ka Bar Knife Sheath
I recall as a kid I had sheath knives with the strap like that and the cross-guard always caught on the strap when removing the knife. -
Singer 31-15 tension pin + any tips?
dikman replied to DominickTuroski's topic in Leather Sewing Machines
That part should only move when you operate the foot lift lever, if it does that then all you need is a suitable pin. I doubt you will get a pin when you buy a tension unit as it's a separate part. -
Ka Bar Knife Sheath
Ahhh, I'm in Australia, we don't have a "right to bear arms". We are constantly reminded that it's a privilege to own a firearm and it can be taken away in the blink of an eye if the police think we've done something wrong. Hence our equally absurd knife regulations.
