Everything posted by dikman
Yep, rubber and skin, super glue works exceptionally well on them.
Fair enough, I wasn't thinking about having to navigate London traffic! Keep looking......
$280 delivered - and it comes from the US! Not bad, I guess, but I'm happy with my $99 one, does the job and I'm $180 richer.
Mike, while I have no doubt you know what you're talking about re-paypal, to say that they always favour the buyer isn't quite correct. My experience, with a $500+ item, was not good, it took me three months and I only got a refund when I finally involved the Australian financial authorities (and even then they still insisted that they were in the right to refuse me!). I know of others with similar experiences. Back on topic, toxo, if you're at all mechanically inclined then do the servicing yourself. Manuals are generally available for most machines, plus you have this forum as a resource, and in general these machines are not that complicated once you get into them. Save yourself some money. Servomotors - you don't have to buy the most expensive one, many of the "cheaper" ones are quite satisfactory. If it has a binder then there's not much you can do about the cost of standard feet etc, other than search ebay/aliexpress. Collecting, just be grateful you're in England, where everyone lives close by (relatively speaking), here in Oz long distances are par for the course.
That's a bummer, made worse because it's essentially a one-off hand-made item. I've never had anything go missing - yet - but it's always a concern when I post anything, hoping it gets there.
I've heard lots of reasons why, Bert, but all I know for sure is that it's always been this way here. The advent of the internet (and ebay etc) has been a boon to we folks here in the Antipodes, at least we can now buy parts and accessories at reasonable prices. How often have you looked something up on ebay from China and then further down seen exactly the same item for sale here at double (or more) the price? Happens to me a lot. Considering we are much closer to China than the US you would expect shipping costs to be less, which should make items cheaper but I don't think it does. Of course, our lousy $ doesn't help either!
" except for your location" Pretty well sums up the problem here in Oz.
What he said, probably the simplest and easiest way to achieve what you want. The other way would be to make a foot pedal and fit the actual actuator housing to it, but this would likely mean extending the electrical cables between it and the control box/motor. I seem to recall Uwe made a remote foot pedal for a servo?
The 5100 is a Juki 441 clone, same as a Cobra 4 and Cowboy 4500. If you search youtube for those machines you should find quite a few videos which will be relevant to your machine.
There is a wealth of information about sewing machines on here and youtube is a good source of videos.
Not a handwheel, just a larger pulley. I've fitted one to a Pfaff and one to a Seiko, they are just pulleys that I had in my pulley/bearings spares box! I've found that this approach is simpler than fitting a speed reducer and works the same. This is the $99 servo.
I've finally finished messing around with this (I think). I replaced the round anvil thingy with a thick steel plate and cut an old chopping board to fit. A piece of angle iron will serve as a fence, with a couple of quick and nasty screw clamps welded from scrap offcuts, and I made five inserts to handle different thickness tools. The biggest problem I could see was the handle needing re-positioning with different length tools. One common solution is to grind off the lower two teeth on the ram, and when it is raised the handle can keep turning when it hits where the teeth were. Nice, but I didn't want to remove the teeth. After coming up with all sorts of ideas for a removable (tool-less) locking design for the shaft the obvious finally dawned on me - I replaced the collar locking screw with a bolt, ground down the head and loc-tited a wingnut to it. Now I can remove the collar, slide out the handle and rotate it to a new position then re-tighten the collar, without tools. Simples. Oh, and I finally drilled a hole in the other end of the ram (only 'cos I could) with a locking screw. At the right of the photo is a block of steel with a pin, if I need to use the ram for anything heavy I'll invert the ram and this block will fit on to save the end of the ram from any wear.
Zac, that is a fairly generic type of servo from China. I bought a similar one recently, it has a different control box but specs are pretty much the same, as was the price. I haven't used it much but it seems to work ok. I also had another similar one but sold it with a machine, no problems with that one either. These motors work better for leather if you either fit a speed reducer or replace the hand wheel with a larger pulley. That's not to say that they don't work as they are, but the mods give greater slow speed control and more torque. Replacing the motor pulley with a 2" one helps too. If you can successfully control a clutch motor then you'll have no problems with a servo. Fyi, my first servos were bought from China about 3-4 years ago, using Aliexpress, and cost me between $190 - $250. They are now being sold here on ebay cheaper than you can buy the same thing from China! I have seen ones like Pinto posted here in Oz for around $400!!
Looks like she's working well.
Hmm, they might be a bit too strong, you don't want too much extra tension or you will lose sensitivity in operating the pedal. You really only want something to balance the "dead" weight of the cast iron in the pedal.
old controversy Hand Made /Sewing Leather
dikman replied to spurdude101's topic in Leatherwork Conversation
You make a good point. I have had pretty much all that you list happen to me (not all at once, of course) which is one of the reasons I want my machines to sew very slow!! There is an element of skill involved in using a machine - understanding how it sews, correct needle and thread for the project, balancing thread tensions etc. Definitely not as simple as hand stitching. -
Have not posted in quite a while.
dikman replied to Jarhead44706's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice. You guys get to make some cool holsters over there. -
Yep, that's the stuff, but mine was a bit thinner than your typical cord. I'm glad you're going to re-do the linkage, it had me worried.
I have the same type of pedal on the Pfaff table and it's pretty heavy, with weight forward! I just used a piece of elastic strap, from the front of the pedal to the cross support of the table frame, to take some of the weight off the pedal. Not a particularly elegant solution but it's simple and it works.
Will Leather Sewing Machines Ever Go High-Tech?
dikman replied to NewfoundlandLaw's topic in Leather Sewing Machines
You and me both, brother. -
Nicely done, I'm sure that someone else will find this useful at some point. I've never seen anyone use a woodworking plane to bevel the edges, first time for everything. The only negative thing I can say is please mount it on a decent solid bench, I got a bit seasick with everything wobbling around!
I Need An Opinion On Singer 29K55 Sewing Machine.
dikman replied to Handstitched's topic in Leather Sewing Machines
Only took you 9 years to get back to your post. Can't rush these things, I guess. It came up pretty good. -
. I even heard the voice of HAL when I read that!
