dikman
Everything posted by dikman
  1. The feet look a bit like my Pfaff binder feet. On the controller box the bottom button looks like it has a turtle and a hare on it (?) which would suggest speed control. My guess for the others would be P to access various parameters and +/- to change the values? It'll probably be trial-and-error to find out what the settings do. If you start messing with it write down any values before changing them because some will refer to the NPS it's got fitted. Overall it doesn't look too bad, decent table and servo.
  2. That article is written by someone who has no idea what they're talking about! What I would call mis-information.
  3. Your last photo shows how the table was used, good stuff, I couldn't quite work it out from the first one. There's something nice about those old cast iron table supports.
  4. The tabletop certainly has some character! Looks good to me. I'm still not convinced that the motor is original equipment or would have had a step pulley fitted, I think they just used the pulley that lined up best with how the motor fitted. Still, you've got a 155 and an interesting project with that stand.
  5. I found a manual for that number you quoted but it's in German and so is unintelligible to me! It sort of looks like it's equivalent to a Pfaff 335 to me and can indeed be fitted with a binding attachment.
  6. I had to look up a Vito, the van should make it easy but still take the head off, it's never a good idea to transport a sewing machine with the head on the table. When someone's getting out of the game there's always a possibility of picking up some nice "extras". I think Wiz meant getting someone (a piano mover) to move it upstairs for you? If SIL is giving you a hand, however, you shouldn't have any problems - get him to carry it upstairs!
  7. Interesting stand, appears to be made from pressed steel and welded, whereas the old Singers were cast and bolted together. My 51W59 stand was pressed (heavy) steel but was still bolted together, not welded. I had a similar pulley stack/clutch on one of my machines but I ditched it for a servo motor. The original motor, in my case a Singer, was very old and so was all the wiring and I considered it a safety hazard! I doubt if the motor's original or that it came with a step pulley, my Singer motor didn't, you just adjusted the motor position if changing speeds. The timber top looks solid and it might be worth sanding/cleaning it.
  8. Definitely start a new topic. Nice machine ,btw, so clean!
  9. Unfortunately there's only one of me and I'm not exactly built like Arnie!
  10. Oh yes, the table......every used machine I've bought I took the head off the table and like Bert said wedged it carefully so it couldn't move, then I dismantled the table completely to get it in the car and make it manageable. The biggest pain was always the clutch motor!!
  11. Generally there's four bolts holding it to the table, remove those and lift the whole thing off (after disconnecting any lifters, of course). As for lifting it there's a pretty good chance that you can, my 335 is no problem to move.
  12. So you drove in and back with no problems?
  13. Andreica's main problem, Silverd, is that where she's located she doesn't have access to the choice of machines like we have, which is why she's looking at the two Pfaffs, they are convenient to her and the prices are, hopefully, reasonable. Many of the models that we often suggest as a good starting point are simply not available to her.
  14. Definitely doesn't look like a girl in the photos I've seen!
  15. I knew that! I was just being facetious.
  16. Ah, but Superlube has Syncolon!!
  17. It's amazing the number of different lubricating products there are for firearms. A new one seems to come out every couple of months! It's also amazing how many just use good ol' 3-in-1 on their firearms.
  18. Might be a bit of overkill for making bags, but what a lovely piece of old machinery. Presumably what Noah used on the Ark.
  19. So chrome-tanned , not veg tan. Incidentally, posting links to flikr is pretty pointless, as you have to sign up to see anything. It's always better to post pics directly to the post, that way there's no concerns about pics going missing down the track and making a post meaningless.
  20. Probably so you can't see it if it gets in the food! Good idea, though.
  21. 1500w motor??????? 550w should work fine, 750w will be more than enough! A speed reducer will not only let you sew slow but will give increased torque. For sewing webbing a pointed needle, as used in sewing cloth material, will be best (a leather point needle is likely to cut the webbing/nylon).
  22. Why does it have to be clear? I haven't seen too many clear greases around (other than vaseline).
  23. Andreica, given what you've just said then the 335 (not the binder) would be a reasonable machine but I think the 545 would be a better option. I'm not familiar with it but it appears to have a larger bobbin and has higher lift under the feet. Either machine should handle #92 thread fine, and probably up to #138. As for shipping, if you can buy local and pickup yourself it's always preferable. Unless the person arranging the shipping knows what they're doing then the risk of damage can be high. Industrial machines are heavy and need to be well packed otherwise things get broken!
  24. Locking up? Sorry, but that's a bit vague. Does the needle stop moving? Or is the thread jamming? Or won't the handwheel turn? What exactly do you do to unjam it? Any chance of taking a pic of what's Jammed? So many questions.......
  25. I probably should have clarified the stitch length, I guess. We're both right. The stitch length varies a bit, depending on the sub-class, and mine is limited to 4mm. There's no easy way of getting it any longer. As for the feed dog, it just seems to me that a none-elliptical travel smooth dog is not going to give much assistance to the material movement - but you could be right, and I could be wrong, if so I'm happy to learn something. But I still don't think it's the right machine for someone who will only have one (which is why many of us have more than one.....).
