dikman
Everything posted by dikman
  1. Wykoni, after reading Wiz's reply it may sound daunting, but it's not that bad. Like anything new it takes time to become familiar with it. There are many videos on youtube about this class of machine and plenty of excellent help here. You won't regret getting one and funnily enough I found the big machine to be easier to use and more forgiving than my smaller machines (there's something nice about a big needle and thick thread ). Learning how to set it up is probably the hardest part.
  2. I'm perplexed why anyone would want to run a clutch/pulley unit on a treadle machine.
  3. What Wiz said. Some time ago a member in the US looked into importing a machine direct from China and he found that any likely savings would be minimal and it just wasn't worth the trouble. I found the same thing here in Australia. Better to buy from a reputable dealer.
  4. I'm assuming it's a single phase clutch motor, in which case a VFD won't work, it will only work with a 3-phase motor. Which means you will have to buy a new motor + the VFD. Then you will have to make up a fitting to adapt the remote potentiometer on the VFD to work with a foot pedal to give you a speed control. As Jimi said you're better off just buying a servo, they are a bolt-on replacement and will give you what you want with a lot less messing around.
  5. If you ever have trouble removing the loctite'd screws just apply a little heat from a pinpoint flame, it should be enough to loosen the bond. Won't need much.
  6. Jimi, that is a pretty remarkable effort making those Akai plugs! Brian, the new printer makes the "old" one look like a little toy.
  7. "Apparently there are different versions of the CB-4500 floating around different parts of the world. I have yet to see one with pre-drilled holes for mounting an edge guide." Mine came with the holes already there, I just had to make an adapter plate. I just assumed it was the same on all CB4500's. Hence my post.
  8. Yes, very nice. Your other work looks good too.
  9. It already has holes drilled and tapped in the back.
  10. As Wiz alluded to earlier, the "bursting" problem is pretty much unavoidable when sewing leather on a machine (it's the nature of the beast). You can reduce it somewhat by playing with needle size but you won't eliminate it. The only way to get a nice hole appearance on both sides is to hand stitch! Theoretically using a pointed needle should provide the best result visually because it's not cutting the leather, and on thin leather this should work, but on thicker leather it may create problems with trying to pull the thread back up through the leather. Sewing leather on a machine is always about compromise. If you're a perfectionist then hand stitching is the only way to go.
  11. Love it! I'm not showing the grandkids because then I'll have to make some.
  12. You're full of bright ideas, aren't you? (Well, full of something...). Some on youtube use the coloured caps to make a multicoloured object, looks pretty cool.
  13. Thanks for the info Dave. Spyros, I used the milk jug thing too. I did a bit of experimenting with the plastic and like everything it's not quite as simple as you'd think! If you get it too hot it burns, and if you try to melt it too thick, or the temp is wrong, it might not fuse in the middle. I've used an oven, hot air gun and gas torch (requires very delicate application!!) to melt the stuff. When you get it right it's nice stuff though, and turns quite nicely on a lathe. I still have a large container of cut up bottles waiting to be used.
  14. Maybe a scotchbrite scourer instead of steel wool? Dave, that looks bloody nice, mate. You said the head is polyurethane, is it any particular type?
  15. I've experimented with melting various waxes, using pure gum turpentine as a thinning agent, but what I've found is that over time the turps appears to "come out" of the mix and leaves a fairly hard black deposit in the container.
  16. I stripped (kept the pulleys and shafts) and junked two, both old Singers that were potentially dangerous due to the age and condition of the wiring. I gave one of the more "modern" style to a mate to experiment with and sold two on gumtree for $20! Turned out the guy who bought them had a couple of machines he was repairing and needed the motors, so at least they were being used. I had visions of using them but it was just too hard to convert them into something usable and they were just taking up room in my shed.
  17. I can't see any practical benefit for texturing the head. If you look at the one on the right you can see where the texturing has worn off from use.
  18. The hole won't be seen once it's all assembled, so no-one will ever know, and it could always have epoxy put down the hole to fill in the gaps. It looks so nice that it would be a shame not to use it.
  19. Unfortunately you don't just buy a remote unit made up (at least not from the store). It consists of a potentiometer (I used 10 kohms), a knob, a switch and a box to mount it in, all of which are available from Jaycar, if they're handy, or online. Some of the VFD's have a removable control panel but I don't think it's a good idea to try and mount it remotely. I used a 3-way switch to give me forward and reverse but after wiring it up it struck me as pretty pointless having the grinding belt going backwards!! I'll probably replace it with a simple on-off switch. Pity we don't live closer, instead of 3,000 kms or so, but I'm happy to help in any way I can. If you get stuck with the remote bit I can make you one and send it up. I've been looking at the cheaper VFD's on ebay and all of them that I looked at had 220v input and 318v for the 3-phase, and while they obviously work we use 240v and 415v for 3-phase - which the one I bought from Conon is rated for. I'm thinking that I should buy another one of those for the lathe (I'm undecided). I noticed that the lathe motor has a squeak, which is not good.
  20. I'm curious, why is the off-centre hole a problem?
  21. Matt, a 1x30 can be very useful (bigger isn't always better ). I've had the other one for over 30 years and I've found that I actually use a belt grinder quite a bit, but the main reason for lashing out on this is to get the variable speed, as there's no easy way to vary the speed of a single phase grinder.
  22. Brian, it's a 1.1 kw (1.5 hp) motor, it's the size they recommend for this grinder. As it's designed for hogging out metal I don't think I'd want anything less, but if it's only used for leather/wood you could possibly get away with 1 hp, but the price difference between the motors isn't much. I bought the motor from Artisansupplies only because it was convenient but there's a place on ebay called Conon Motors, in Vic, and they have a good range at what appears to be good prices (unless you can find one locally maybe). If I go ahead with modding my lathe I'll get the motor from them. I bought the VFD from them ($200) but there are others on ebay for around $100 and I've found good reports on them. I think if I buy another I'll try one of the cheaper ones. Putting the VFD in a separate case is a good idea, as you say it protects it and once it's set up you don't really need to access it, all you do is fit remote start/stop and speed controls, all done by programming. My background is in electronics but the programming had me scratching my head for a while as the terminology was a bit new to me. I watched a few vids on youtube where guys had fitted them to lathes and that helped me understand the basic ideas. Most of the settings don't need to be changed for our needs, basically just add the motor parameters (volts, phase, current, hp etc, all of which is on the motor nameplate) and that's it. Depending on the VFD type it may be necessary to set the voltage input, I didn't have to on mine. The trickiest part was working out the settings for the remote controls, but like a lot of things it was fairly obvious afterwards! Anything you want to know just ask.
  23. Actually, she saw it on the credit card account and said perhaps I should have it as a combined birthday/christmas present. Here's the "finished" product, a cheap (because I used whatever I had in the sheds) and rough-as-guts (well, I did give the wood a rough sand to remove most of the splinters) dust catcher! I routed a slot in the rear piece so it can be adjusted for height, a few assorted plumbing fittings, a spare hose from an old vacuum cleaner and a cheap shop vac. Works well for leather and wood (no good for metal, of course), but even with the vac outside it's still noisy!!! Now I think I need to buy one of those digital tachometers off ebay so I can measure the speed and mark my adjustment dial.
  24. Spyros, I'm impressed! That's a great bit of fettling there, both the lathe and the stuff you made with it!
  25. Bert, that's what I'm working on. A quick mockup showed that it should work and I was going well today until I got a call that my wife had fainted at the bank, so had to rush over there. She was ok, she had given blood earlier that day and the bank was hot and stuffy and that combined with a long wait got the better of her but the medics still insisted on carting her off to hospital. Couldn't do any more on the dust collector 'cos I had to walk back to get the car and then hang around by the phone.
