Everything posted by Dwight
I got $500 for mine, . . . I thought it was fair, . . . as that is about the investment I had in it at the time. May God bless, Dwight
Another Blue Gun Question 1911
Dwight replied to Boriqua's topic in Gun Holsters, Rifle Slings and Knife Sheathes
FWIW, . . . I did find an older Springfield Armory, . . . all stainless, . . . 1911 (I think it may have been a "loaded"), . . . was absolutely bigger. This was a number of years ago, . . . and I have never run across it again, . . . but it would not go into a Milt Sparks Executive holster, . . . nor would it go into one of the cheaper kydex holsters I had at the time. Just sayin. May God bless, Dwight -
Snubbyfan, . . . Great looking holster, my friend,.......and you definitely do a better job at basket weave than I do. Guess I just never really caught on to it like I would like to, . . . so I tend to stay away from it somewhat. But I did giggle a bit when I saw the suicide strap, . . . knowing the guy using it is not one of the "whole bunch younger" crowd. And as said before, . . . the concho really sets it off. May God bless, Dwight
Actually, . . . this is an old trick I learned years ago, . . . and while I've never kept a log sheet, . . . the different needles seem for some reason to like different positions. All I'm doing is making sure that when I lock it down this time, . . . it is not where it was when I loosened it up. I had taken the needle out to check the size on it, . . . and when I put it back in, . . . it all went south, . . . seems OK for now. I've got a pancake holster to do for an order, . . . I'll find out for sure then if all is well. May God bless, Dwight
That, indeed, is some excellent work, . . . far beyond my expertise that is for sure. BUT ! If you are interested in doing that, . . . one of the things you can do if you want to get into that type of carving, . . . use a laser printer, . . . reverse the image, . . . print it on to waxed paper, . . . lay the waxed paper onto the leather, . . . use a squeege to transfer the ink onto the leather. At least you won't then have to try to draw the image, . . . May God bless, Dwight
If you look down on the top of the needle, . . . like you were standing up in front of the machine, . . . it's 3:30 or three-thirty on the clock, . . . or 4:00 or four o'clock. It indicates where the pin would be pointing. AND, . . . thanks Wizcrafts, . . . gives me something else to look at. I've actually gotten a bit lax in my "maintenance" schedule here in the last few years, . . . need to just toss a dart onto the calendar and whatever day that hits, . . . got to take some stuff down, . . . PM and clean it, . . . put it back in operation. I used to be really good at doing that stuff, . . . gotten lazy in my old age, . . . kinda got to the "if it ain't broke, don't fix it" routine. May God bless, Dwight
Wet Moulding And Carving... In What Order And How Much Water?
Dwight replied to shagsj's topic in How Do I Do That?
Generally speaking, . . . it's pretty much an either / or situation. Trying to tool a holster, . . . then come back and form it, . . . and add boning, . . . nahh, . . . I'll tool the leather, . . . make the holster, . . . and dampen it just enough to form the general shape, . . . but boning lines and fancy add in's are above and beyond my expertise. But then again, . . . never been asked, . . . so that has worked out so far. I did a rose pattern on a western six gun rig some time back, . . . tool, cut, sew, dampen, form, finish, . . . was kinda the progression, . . . turned out nice. May God bless, Dwight -
Glockanator, . . . OK, . . . got mine fixed, . . . it would sew 20 or so stitches then somehow catch the thread, . . . next time, . . . 2 stitches. I took out the needle, . . . then took a straight pin, . . . stuck it in the "eye", . . . and played with it until I got it to sew, . . . by moving the needle back and forth. When the pin, . . . stuck in the eye, . . . was pointing to about 3:30 or almost 4:00, . . . it finally decided that It would sew. I was able to completely sew my niece's belt up with it, . . . did not skip a stitch or catch even once. May God bless, Dwight
Brass Cartridges Turning Green
Dwight replied to x101airborne's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I always coat my cartridge loops, . . . inside and out, . . . with resolene. It should take care of your problem. I've got nickle ones in my saddle rig that I know have been in there for 3 years, . . . maybe 4, maybe 5, . . . no tarnish. May God bless, Dwight -
I use both sides and double shoulders for belts, . . . sides for the big guys, . . . double shoulders for the smaller ones. There will always be scrap, . . . but since I use a strap cutter, . . . at least they are "uniform" scrap pieces, . . . and I wind up using them on various other projects as I keep em all in a bag. May God bless, Dwight
Actually, . . . I guess this whole discussion just may hang on one question: do you provide a buckle with the belt you are selling? Yes, . . . I always do. That is the way stores sell em, . . . that is the way they are sold by just about everyone I know about on the net, . . . so that is the way I do it. That is also the way I know when I make a 44 1/2 inch belt, . . . it is a 44 1/2 inch belt from the inside of the buckle lip to the center hole. But that's just my way, . . . OMMV. May God bless, Dwight
Ain't never been there, . . . ain't never done that. But what I would do is just go on with what you were doing, . . . don't change anything. Veggie tan leather is some pretty forgiving stuff from what I've seen in almost 60 years of playing with it. I've had projects that I was sure was ruined, . . . came out all right. Matter of fact, . . . got a belt out in the shop that my sewing machine flubbed on, . . . will take a different look at it in a couple days. Right now, my big hammer is too close to the sewing machine better stay in here for now. Worst case scenario, . . . you become the resident expert on what happens. May God bless, Dwight
First Holster
Dwight replied to ihateselectingausername's topic in Gun Holsters, Rifle Slings and Knife Sheathes
1. Get that stitch line a whole bunch closer to the trigger guard, . . . that looks very much like you made the holster for a different gun. But for a "first" one, . . . it is great. Y'all ain't never gonna see my first one, . . . nada............ 2. Don't stain, . . . dye your leather. It would have taken me all of 30 seconds to dye that holster, . . . and it would have stretched to 3 minutes if you count clean up and put away time. I use 9 by 14 (or so) baking pans, . . . pour the dye in the pan, . . . drop in the leather, . . . swoosh it around a bit, . . . drag it out, . . . daub off the puddles, . . . let it dry. While it is beginning to dry, . . . I pour the rest of the dye back in the bottle, . . . wipe out the pan with a paper towel, . . . throw it and my rubber gloves in the trash, . . . What part of Indiana do you hang your hat in? My two sisters and I laugh about all living in Marion, . . . they're in Marion, Indiana, . . . I'm in Marion, Ohio. May God bless, Dwight -
Well so far, . . . I've had to "re-do" a grand total of 2 belts, . . . doing it my way. The first was when a guy told me he needed a 36 inch belt. I didn't realize he was basing that on his britches size. As it turned out, . . . his new one was a 41. He had stretched the 36's that far. The second belt was a cowboy rig, . . . western belt, . . . bullet loops and all that regalia. I measured him for a 53, . . . and always add 4 inches for a gun belt, . . . When he put it on, . . . it only went to the first hole in the belt and he was kinda sorta struggling to get that buckled. I re-measured everything, . . . dude had gone from a 53 to a 56 in the time it took to make his belt. If you want to do it your way, . . . have at it, . . . I lost track of the number of belts I've done down through the years, . . . and like I said, . . . got recalled on a grand total of 2. May God bless, Dwight
Not meaning to be hard headed, . . . OLDNSLOW, . . . but stop and think about it for a minute. If you measured your bedroom for carpet, . . . do you not measure all the way to the wall on each side??? Not measuring the buckle, . . . leaves that much off the measurement around the person, . . . kinda like measuring your bedroom, . . . but starting about a foot from the wall. Measuring the buckle also, . . . will give you a more accurate measurement of the person you are attempting to surround with the belt. There is one caveat to all I have written, . . . and that is if the person intends to use a totally different type buckle on his/her new belt. If the person in Wyoming (I live in Ohio) wants a belt made by me, . . . they tell me 39 1/2 inches from inside of buckle tip, . . . to most used hole, . . . and I make exactly that, . . . using the buckle I have in my supply. If they measure from the fold, . . . and are using some kind of a Rodeo Reward buckle the size of a large human hand, . . . the belt I make them using a standard buckle will be too short when they get it. Uhh, . . . been there, done that, . . . so to speak. And, . . . I hate re-making something I thought was correct when I first did it. May God bless, Dwight
My First Wallet
Dwight replied to GrampaJoel's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I went out to start on my niece's belt tonight, . . . machine decided to throw a fit, . . . so I'm down now for the long count. My Boss is a good machine when it is working, . . . when it decides to be a pain, . . . a red-headed, step-daughter, turned into a mother in law doesn't even begin to describe it. Had to just come in the house and bake me a cherry pie to get my nerves unfrazzled. We'll eat it tomorrow, . . . working on the Boss. May God bless, Dwight -
OK, Glockanator, . . . misery loves company they say. If you figure yours out, . . . holler at me. I went out to sew up a belt for my niece tonight, . . . something I've done XYZ number of times, . . . COULD NOT GET IT TO SEW. So, . . . I'm back in the house, . . . chilling, . . . I'll take a whack at it sometime tomorrow, . . . If I mess with it tonight, . . . I'll take a whack at it with a 4 pound hammer, . . . Didja ever get yours running correctly??? May God bless, Dwight
When I do these, . . . I do the loops through only one side, . . . and it is the "looped back through the same hole" style, . . . never sewn, . . . but that is just my way of doing them. After I get the loops on, . . . I put on the buckle and tongue billets, . . . then wet the whole thing down pretty good, . . . fold in the middle, . . . crease with a one and and a half inch wide wall paper seam roller, . . . hang it up by the tongue billet and let it dry. I then come back and contact cement all of it on the inside except up under the buckle billet, . . . where I stash the cash. I suppose some of those back in the old days may have had a longer tunnel for the money, . . . all my customers will be putting greenbacks in there, . . . so I give em room for that. And, yeah, . . . 6/7 is fine. I always do mine so they become a roughout belt. May God bless, Dwight
My First Wallet
At 71, . . . still "having at it", . . . getting ready to do my first long wallet like this. Needed some "inspiration" on the pattern, . . . thank you my friend. I've done other wallets, . . . just never got into the long ones, . . . sister has a "special friend" who needs one, . . . so here we go. May God bless, Dwight -
I measure from the inside edge of the belt buckle, . . . to the most used hole. THAT is the fatness or skinneyness that the customer is. Measuring from the fold is an inaccurate measurement, . . . kinda like weighing out your hamburger, . . . with it in the cast iron skillet. And, . . . 7 holes is my standard. May God bless, Dwight
Glockanator, . . . try this: I sent them an email indicating you were having trouble, . . . Here is the response *************************** Hi Dwight, I’m sorry to hear that your friend is having trouble with his machine. Our technicians would like to help him out. Please have your friend give either Jamie or Al a call at his convenience. Thank you. Have a great day! Rachel Fogarty Purchasing Agent Customer Service Representative Tippmann Industrial 3518 Adams Center Rd. Fort Wayne, IN 46806 1-866-286-8046 Rachel@tippmannindustrial.com Rachel@air-ordnance.com
Welcome, Vana, . . . glad to have you aboard the leather working train. Your belt sample looked really good for a first go at it, . . . keep working, you will only get better. Or, . . . you will get broke, as in "no more money". It is also one of the attributes of leather working, . . . May God bless, Dwight
Boriqua, . . . one of the fun things you can do with blue guns is customize em. I do it often. Add several layers of masking tape here or there to make the slide wider, . . . augment with a layer or two of manila envelope, . . . be surprized what you can conjure up. I had a guy wanted a glock (ugh !!) holster and the model he had was a bit longer than the only one I had at the time. About 20 minutes after I found out what the difference in the two was, . . . I had a wooden extension for my glock (ugh !!) blue gun, . . . that when taped on, . . . carefully modeled the one he wanted. Made him the holster, . . . he's been a happy camper ever since (guess about as happy as you can be if you own a glock, . . . y'know). Anyway, . . . go for it. Nothing ventured, . . . nothing gained. May God bless, Dwight
