Everything posted by Dwight
Did you get the PM? May God bless, Dwight
I take a ball point pen and outline my piece, . . . then take a razor knife (that has been previously stropped SHARPPPPP), . . . and cut away at the pattern. Since almost everything I do will have the edges sanded anyway, . . . I can get away with a less than perfect cut, . . . and the beveling always removes any extraneous ball point pen ink, . . . it works for me. I used to use a pencil, . . . gave it up, . . . sometimes I would follow a shadow, crease, or something, . . . got out the ball point, . . . works every time. The only real exception to the above is when I grab the old strap cutter and start in with it. May God bless, Dwight
When I took mine in to Ben, . . . before he took the back off, . . . he tried it "as is" and just shook his head. He looked at the bobbin, . . . the needle, . . . you know, . . . gave it the $ .25 onceover. When he couldn't find anything else wrong, . . . he flipped it around and took off the back. He actually had the guy working next to him come over and look , . . . asked if he had ever seen one slip like mine did, . . . it was like 2 1/2 or 3 inches to the right of where it should have been. He told me that the distance was just short of critical, . . . and while I couldn't remember what it was, . . . I went out and measured it, . . . from the inside edge of the casting, . . . to the nearest edge of the collar, . . . is 5/8 of an inch, . . . and he marked it for me. The marks you see to the right of the collar most likely are knurlings on the shaft, . . . mine has them too. It's pretty difficult to tell in the picture, . . . but like I said, . . . mine is 5/8 of an inch, . . . and works flawlessly if I do my part. Best wishes, my friend. May God bless, Dwight
Once you have the piece cut out for the front and the back, . . . lay it down and trace the back, . . . round cut the top of it like in the first picture you posted, . . . then punch and cut the slots just like in that same picture. OR: What I'll do sometimes, . . . is to play with my computer, . . . take a picture and make it 10% bigger (or smaller, depending on what I need) until I get it exactly the size I need so I can lay it down on a piece of dampened leather, . . . trace the outline and details with a ball stylus, . . . remove the paper, . . . go to cutting leather. I've used up a dozen sheets of paper from time to time, . . . but it has none the less been well worth it to get EXACTLY what I needed. May God bless, Dwight
Mike probably gave you the answer, . . . BUT, . . . if that didn't do it: Refill the bobbin that did work, . . . and try it. If it works, . . . take a ball peen hammer to the one that did not work. Then you can toss it. Double check the needle, . . . they can be ever so slightly bent, . . . and NOT WORK AT ALL HARDLY, . . . UGH !! Last, . . . take the back off your machine, . . . make sure everything looks like this picture. Especially the upper left corner. That collar slipped on mine one time, . . . I wound up not seeing what was wrong, . . . took a day off from production, . . . drove 200 miles to the Tippmann factory, . . . Ben fixed it for me, . . . free gratis. May God bless, Dwight
I agree, . . . TinkerTailor has it nailed, . . . at least that is what I would do. May God bless, Dwight
I Made My First Gunrig!
Dwight replied to Dorado's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like it, . . . but it makes my fingers hurt, . . . all that hand stitching........... Good job, . . . good perseverance. May God bless, Dwight -
My apologies, indidana, . . . I guess I missed the part about returning for his money back. Got any idea what he paid for it?? May God bless, Dwight
I don't understand the problem: cut the stitches, . . . remove the screw / rivet / stuff. Voila, . . . you have a pattern. It's actually looks like a takeoff of a Thad Ribka holster, . . . called a Rhodesian, . . . which are all considered to be great from what I've ever seen. I make a similar holster for small automatics, . . . it works really well for M&P Shields and smaller pistols. May God bless, Dwight
Looking For A Inside Waist Band Holster Pattern For A Sig Sp2022
Dwight replied to biglew's topic in Patterns and Templates
If you have the gun, . . . use the search function here, . . . make yourself a pancake, . . . a simple two piece holster, . . . with the gun in the middle. Add a couple of metal clips, . . . one on each end, . . . voila, . . . IWB holster that will work. This will then give you the personal information as to what you DO like about it and what you DO NOT like about it, . . . so then you can make one that suits you, . . . your way. If you look on my website, . . . my "Cactus" holster evolved in a similar fashion, . . . and is super comfortable, . . . even all day in the heat of the summer, . . . with an all steel 1911 commander in the saddle. Good luck, may God bless, Dwight -
History On Split Rivets (Two Legged Variety)
Dwight replied to Dwight's topic in Leatherwork Conversation
Thanks, Art, . . . appreciate the effort my friend, . . . but Bruce uses a washer with his split rivets, . . . and they seemed to be flat headed. The rivets I have are solid brass (or bronze??), . . . have a domed head, . . . and when they were set, . . . the tips of the legs were driven down into the leather so the legs, . . . if you looked at a side view, . . . would resemble a rounded "M". That would prevent the tips from snagging on anything. My opinion is they were put on with some kind of special setting tool, . . . as they were all way too uniform to have been done by hand. It's really no big deal, . . . I was just wondering if anyone knew of using them, . . . as it would maybe give me a date for the ax and when it was used. Got a suspicion it's an old timer. Joet, . . . are those the type of rivets you have??? May God bless, Dwight -
Leonguaranipy, . . . just passing on what was given to me. I had the same problem with my first painted holster, . . . made for a special friend of mine, . . . did not know how to get it done. Manager of local Tandy store told me, . . . the rest is history. May God bless, Dwight
Plus, . . . they are not above getting something for you. They're good people to deal with. May God bless, Dwight
I have done basically what you are asking, . . . using Resolene to seal the leather, . . . then paint the Resolene. May God bless, Dwight
Today, I took apart an OLD, . . . old, . . . ax sheath, . . . from the C. C. C. & S. . . . whoever they were, . . . to fix it up for a friend. The thing was put together with brass rivets (for want of a better name) that had a head on one side, . . . then split in the middle, . . . and each had two legs and were pounded out flat on the other side, . . . holding the leather pieces together. Anybody got any kind of an idea about how old this thing might be? It was really dry, . . . so I gave it a dose of oil, . . . after I took it all apart. Going to put it back together for him next week, . . . just was hoping somebody could share a bit of info. Thanks, may God bless, Dwight
Sometimes I groove, . . . sometimes I just dampen the leather, . . . set my pair of dividers, . . . outline the edges with the dividers, . . . then I have a tendency to have a much better looking stitch line regardless of which tool I used. A stitch groover also takes off that all important top layer of leather, . . . and on really thin leather like a wallet, . . . or some purses, . . . it can seriously weaken the overall product. May God bless, Dwight
Sig 938 Bbq Set
Dwight replied to greystoneleatherllc's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Poor gator.............. Seriously, . . . really good looking rig, . . . you did your profession well. May God bless, Dwight -
Ride Height For Iwbs?
Dwight replied to Deanimator's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Deanimator, . . . if you go to my website, . . . you can see the holster, . . . where it rides, . . . how high it rides, . . . and how well it conceals as a tuckable IWB. It is the holster I wear 98% or so of the time, . . . there are a couple others I use occasionally, . . . but "occasionally" is the operative word there. If you want it to be comfortable in virtually all positions, . . . it has to be flat backed for most people. Now there are some chubby folks out there who have enough of a "cushion" that you could put a Ma Deuce down their pants and it wouldn't bother them, . . . but for most of us, . . . the flat backing is the key for comfort at about any position. Try looking on the main page: www.dwightsgunleather.com May God bless, Dwight -
I would really suggest you try the kit first. No they are not tooled, . . . you do that too. Once you've made a couple of kits, . . . you will then have a better idea if you want to continue in leather, . . . and won't have a big cash outlay if you decide to pursue basketweaving or some other endeavor. May God bless, Dwight
Hey, Guys, . . . thanks a bunch, . . . think I'll find one in one of those places. Still don't know for sure if I'll need it, . . . went out and looked on Ebay earlier, . . . just didn't have that "comfy" feeling about it. But anyway, . . . thanks again. May God bless, Dwight
Anybody got a good source for a raccoon skin? I may be needing one for a project, . . . need to find a source. Thanks, may God bless, Dwight
Thumb Break Stiffeners
Dwight replied to GaryNunn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Red Cent will have to beat me to this one, . . . I don't have one on the place that is finished, . . . and after looking at all the pictures I have, . . . nothing is really suitable to show it. I may have a job coming up for one, . . . I'll make a note to get some pics then. May God bless, Dwight -
This is about all I ever saw as a kid growing up, . . . in the '50s, . . . except for those the police carried, . . . and many times they were very, very similar but were black. This is a Heiser holster, . . . and was laced around the outside edge, . . . the ones I saw were all sewn along the edge. May God bless, Dwight This is about all I ever saw as a kid growing up, . . . in the '50s, . . . except for those the police carried, . . . and many times they were very, very similar but were black. This is a Heiser holster, . . . and was laced around the outside edge, . . . the ones I saw were all sewn along the edge. May God bless, Dwight
No insignia on it, . . . in fact everything but the New Jersey is not ID'd. The manager of a local VFW gave it to me, . . . it actually is a beer promotional poster, . . . they had one for WW2, Korea, 'Nam, and the sand box, . . . I talked him out of this one, . . . cut up a bamboo fishing rod, . . . framed it, . . . It reminds me from time to time just how well I've been protected.............. May God bless, Dwight
How Do I Make Lower Half Chaps For Motorcycle Riding.
Dwight replied to SFC Morris's topic in How Do I Do That?
If I was doing MC chaps for the lower half of my legs, . . . I'd just rip out the seam in my jeans, . . . sew the leather to the jeans, . . . sew the seam back up and be done with it. I took the seam out of two pairs of jeans a couple years ago, . . . lined them puppies from top to bottom, . . . and they are so warm, can't wear em any length of time in a warm house. May God bless, Dwight
