Everything posted by Dwight
I use Feibing oil dye and pro dye . . . exclusively . . . only 4 colors . . . always 50 /50 diluted. That keeps the expected results always predictable . . . or reasonably so anyway. May God bless, Dwight
First thing . . . ALWAYS dilute feibings dyes . . . at least 2 dye to 1 thinner. Preferably . . . 50 / 50 . . . has always worked great for me. Second . . . you are wasting good money putting the red on first. Forget that step . . . unless it is some kind of a two tone effect you are trying to achieve. If you want straight black . . . then dye black . . . period. Third . . . let it FULLY . . . FULLY . . . dry . . . 24 hours does it pretty good usually. 4th . . . buff with a dry cloth . . . alcohol should NOT be involved . . . best cloth is an old tee shirt . . . or an old bath towel. Buff until you do not get any more rub off. That is the way not to get any rub off later. I do not get any rub off whatsoever using the above technique . . . and I finish with one or two light coats of resolene . . . cut 50 / 50 with water. May God bless, Dwight
I am sure I could personally conjure up a pair of moccasins that I could wear. I need more than that. With my neuropathy in my feet . . . any shoe I have ever worn . . . begins to hurt my feet after 4 or 5 hours . . . they HAVE TO come off. I want to make a pair of mocassins that will stand maybe "short" cowboy boot height . . . maybe 4 inches above my ankle If you have such an animal . . . I'd love to see it. May God bless, Dwight
Honestly . . . I have no idea of what size needle I've always used in my boss (20 yrs) . . . as I'm still on the bunch I got with it originally. Don't recall where I saw it . . . but I saw a video that said "this is the way to size your needle for your thread" Cut off a piece of string about 36 inches long . . . thread it thru the needle. Grasp the thread in your two hands . . . wrapping it so you can hold it tight. Slide the needle up against your right hand thumb. Hold the string level and tight . . . lift your right hand while you lower your left hand. The needle should slide all the way down (fairly quickly as well) to your left hand long before you are holding the thread at a 45 degree angle. If it hesitates . . . go up one needle size and try that again. So far it had worked for me virtually every time. May God bless, Dwight
Tippmann "BOSS" Hand-stitcher for Belts?
Dwight replied to LMullins's topic in Leather Sewing Machines
I did not read all the other posts . . . but I'll comment my thoughts. #1 . . . I made and sold belts . . . holsters . . . western gun rigs . . . knife sheaths . . . billfolds . . . and whatever with a Boss for 18 years . . . using 346 thread almost exclusively. Never had any problem except that at 6 stitches per inch . . . they way I make a 40 inch belt . . . puts me at just about 600 stitches total. 600 pulls on the handle . . . and 600 pushes up on the handle. Generally that was about a 20 minute endeavor. #2 . . . I would still be using it had not a good samaritan not reached out and helped me buy my 4500 electric. #3 . . . I would not sell you my Boss (its 24 yrs old) . . . for anything less than 750 dollars. Go from there my friend. May God bless, Dwight -
Trash can would already have happened for me. I'm of the opinion that I'm not going to let 10 bucks worth of raw material destroy 50 dollars or more of material and labor . . . I'll pitch it first. May God bless Dwight
In a one word answer . . . no . . . It doesn't. But then again . . . this is laced on there TIGHT . . . TIGHT Plus . . . if it moved it would have to move forward . . . and mine is designed to end at that skinny part of the stock . . . so it would have to jump over the hand grip . . . ain't gonna happen. May God bless, Dwight
I have relatively high cheek bones . . . when I want a cheek weld . . . I want it hooked on that riser. My M14 . . . with my 50 mm scope . . . and my cheek riser. Decoration is the logo for Destroyer Squadron 7 out of San Diego . . . I rode two ships in that group. I have sold a number of these . . . mostly one guy sees it . . . wants one. I make em in basically any height . . . this one is one of my higher ones. May God bless, Dwight
Go to Lowes . . . in their metal aisle . . . you will find aluminum and steel angle iron. Buy their 1/2 inch aluminum . . . cut it down to maybe 12 inch pieces (2) . . . Put masking tape on the bottom of each . . . and trim it with a razor knife. Aluminum can mark damp or wet leather . . . the tape stops that. Put your stamps in a row in the order you need them . . . and tape around the angle iron . . . For 1/4 and 3/8 stamps . . . forget the press . . . use a small mallet . . . Tape the angle iron down on the leather where you want it . . . stamp it . . . you're done. Small stamps like those do not need a press of any size. May God bless, Dwight
If it were me . . . the horse's head itself would stand out . . . Eyes, mane, nostrils and outline would be depressed . . . and if your machine is that good . . . all lines that show the outline of the head . . . should taper away from it . . . But that is just my opinion . . . and if it were really me . . . I would laser engrave them . . . much more detailed, once you get it dialed in . . . and totally 100% uniform. PLUS . . . you could cut out the fobs . . . dress the sides . . . and set up your engraver right there at the show . . . and you could hand it to them . . . and they would enjoy it more knowing it was done on the spot. At least that was my experience at shows I used to do. May God bless, Dwight
It was not a good picture . . . so I could not tell if it was a single layer or double layer collar. For a single layer collar . . . a rotating punch . . . mallet . . . razor knife . . . bag of brass rivets . . . and a piece of 1/4 inch steel . . . about 4 inches square . . . and a cork back ruler either 18 or 24 inches long . . . and a rivet stamping tool. And you can do double layer collars by adding a quart of Weldwood contact cement and a bag of acid brushes from Harbor Freight. Instead of sewing the layers together . . . brass rivets will put them together in fine fashion . . . but if your sewing machine will sew 5/32 of an inch of leather . . . that is two 5 ounce layers . . . or one 10 ounce layer . . . which is good for all but the German Shepherd and larger dogs. May God bless, Dwight
Need some advice on IWB holster
Dwight replied to BroodyLeathercraft's topic in Gun Holsters, Rifle Slings and Knife Sheathes
You do not say what kind of gun is going in this holster . . . which is THE deciding factor on the thickness. I would never do a double thick IWB for a S&W Shield . . . but I might do it for a full size Kimber 1911. Most of my IWB holsters are 6 to 8 oz . . . and like AIZilla said . . . works out fine . . . my signature holster is in my avatar . . . a long eared pancake . . . Ii call a cactus. The added piece on the front of it makes it very stable . . . without needing to be double thick. My carry holster is almost 20 yrs old . . . gets used at least once a week . . . May God bless, Dwight -
Handbag finish
Dwight replied to NewbieHobbyist's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I mix white resolene with water 50/50 . . . and put it on with a 1 inch . . . cheap . . . bristle brush. I put on enough so that as I scrub the brush around it creates a little bubbly lather . . . then I just keep brushing . . . left right up down etc . . . until the bubbles are all gone. For just getting it "rub off proof" . . . one coat is plenty. Successive coats will make the product stiff . . . but 2 to 3 coats makes it darn near waterproof . . . I use it on holsters . . . and belts . . . have never had a "ruboff" complaint. Just be a tad careful going over any antiquing . . . make sure it is 100% fully and positively dry . . . then use a bit of care like I said. It can dissolve some antiquing . . . but won't if you are careful. May God bless, Dwight -
On all my work shoes / boots . . . I have laces just like "normal" guys wear. But I put those lace up zippers in them . . . and they can be made as tight or loose as you want them. Pull the boot on . . . pull the zipper up . . . you're good to go . Bought em off ebay . . . search for "lace in boot zipper" May God bless, Dwight
Ya got a lot more patience than me . . . good job though May God bless, Dwight
Years ago I bought all my thread from Tandy . . . they sold a white thread and I don't know if it was poly or nylon . . . I think it was nylon . . . At any rate . . . I was using a Tippmann Boss then (that I still have) . . . and together they worked great. The thread was waxed . . . and at times it did kind of clog up the enterprise . . . but a quick cleaning and we were back in business. I'd love to find that again . . . I only use size 346 May God bless, Dwight
Putting on the oil and deglazing with alcohol . . . an analogy would be taking a bath then rolling in a mud puddle. The alcohol will screw up the oil . . . and the leather probably would have been better off had you done neither. The NFO simply replaces some of the natural oil in the skin . . . that was removed in the tanning process. Far as I'm concerned . . . the deglazing products were developed for a problem that does not exist . . . kind of like you and I taking a supplement to keep our bald eagle feathers from falling out of our heads. I'd lost a couple of projects when I was earlier in leather . . . taken raw leather . . . made a project . . . especially had wet molded it . . . then dyed it . . . and when I went to bend a part for a buckle or something . . . the outside hair layer cracked and broke. Once I started oiling everything before dying it . . . that problem pretty much went away. May God bless, Dwight
I use a brush so I don't get it on my hands . . . no other reason. I've done leather for over 20 years . . . never found a reason to deglaze anything . . . other than when I'm gluing the hair side to something . . . then I seriously "deglaze" with a wire brush and some elbow grease. Far as I'm concerned . . . deglazing products were invented to sell a product that fulfills an imaginary need. Kind of like selling blinker fluid. May God bless, Dwight
Leather Holsters and Striker Fired Pistols
Dwight replied to Gosut's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That is why I am presently carrying a Springfield 3 inch barreled 1911 in .45ACP . . . If I laid it on a table . . . most gun guys would think it is an EMP . . . it just looks like one. 9mm modern ammo will expand to basically 1/2inch . . . (.19 square inches) putting a hurt on the bad guy. Modern 45ACP ammo will expand to almost 1 inch . . . (.78 square inches) putting 4 times the hurt on the bad guy. I carried a P365 for a while . . . couple different Shield's . . . Ruger p89 . . . Taurus G3C . . . never, never felt secure and comfortable with them. This little baby does the trick. But as Chuck said . . . get what is best for you . . . I like this one . . . and it will never find a home in a plastic fantastic holster. Leather all the way . . . or Mexican carry at certain times. May God bless, Dwight -
If you want an inexpensive "best of both worlds" go to Harbor freight and spend 50 bucks for this little sander. Round sanders have a habit of digging in . . . and you have to really spend a lot of time learning how to not allow it to do that . . . and even then . . . if you are not paying attention . . . if you run into a hard bit of leather it will not take off what you wanted . . . if it gets soft on you . . . you will have a half moon indentation in your project. This little belt sander does not allow that to happen any where near as bad . . . especially if you use 120 or higher grit belts. You can remove the little clear plastic piece on the top of the top pully . . . as I did . . . and if you have an inside curve piece that needs sanding . . . that little curve will do it nicely . . . Plus . . . it has a hole in the side for a power vac . . . sucks the sanded leather (mostly) out of your way. I own two of them . . . have never seen anything any better. May God bless, Dwight
Your answer is right there in that statement. Light brown. I do not know why . . . only know it happens . . . light browns . . . especially saddle tan . . . have a habit for some reason to like to come out a bit splotchy. The cure I found for that is to get a 1 inch bristle brush . . . some genuine neatsfoot oil . . . put a light but wet coat on the hair side of the leather . . . leave it for 24 hours . . . come back and dye it. I've had no more splotchy dye jobs since I started this. May God bless, Dwight
Whatever you use . . . I would plan on doing the whole table top. I doubt you will get the two to match up . . . using a different product. I'm not familiar with gilding other than I've seen it done . . . And whatever you decide upon . . . were it me . . . I'd plan on masking off all not leather areas . . . and using a small air sprayer . . . I'd spray the finish on . . . rubbing might mess up the gilding I would think. May God bless, Dwight
