Everything posted by Dwight
This Week's Challenges
Dwight replied to Lobo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Plus in addition to the "things that went wrong", . . . now he has to start getting ready for: Year end inventory so he can pay his personal property tax Assimilate all the sales for the last sales tax reporting period (mine is twice a year) File and pay his unemployment compensation Determine which Obamacare he will support this year, unless he gets a deferrment, or a pass, or is dropped until 2015 File his federal income tax File his state income tax File his worker's comp paperwork I probably forgot a few, . . . but then again, . . . that's what lawyers and 'countants are for. Good luck, . . . may God bless, Dwight PS: I'm sorta glad I'm still working on rebuilding my shop, . . . might be able to stretch that out to 2014 -
And the total, . . . shipped to my door price is:__________?? May God bless, Dwight
My sheath is only sewn, . . . no rivets. If I drop it straight down on the edge, . . . it will cut the threads, . . . but won't mess up the edge with the rivets. I don't use it much, . . . and absolutely hate sharpening the thing, . . . so I take care of it as best I know how. May God bless, Dwight
I saw one tool I would get if I were you, . . . it is called a plastic bone folder. It sells for about 6 bucks. It will allow you to burnish the edges of your project, . . . and there looks like a lot of edge work on that particular type folder. Some folks don't do anything but edge their leather projects, . . . I burnish mine also, giving them a smooth appearance, and making them smooth to the touch, which in the long run will make them much less apt to fray, get rough, and look like a hobo's grub sack. That tool is real easy to use also, . . . after you have edged and sanded the project, . . . lay it flesh side down on your work surface, . . . select the right trough for the leather to ride in, . . . dampen the leather edge with water, . . . rub the tool back and forth, . . . it slicks the edge right nicely. The tool looks (a side view) like the drawing, and it does a really nice job on 8 oz or lighter veggie tanned leather. May God bless, Dwight
Storing And Organizing Scrap Material
Dwight replied to horseplay's topic in Leatherwork Conversation
My discipline apparently doesn't exist. I finally get my scrap drawer so full that I have to take an hour out and sort and pitch. So that is kinda my program, . . . fill up, . . . sort, . . . pitch, . . . repeat as necessary. May God bless, Dwight -
Actually, . . . not thinking about a push pin, . . . but rather the pins that a seamstress uses to hold stuff together. Mom called em "stick pins" when I was growing up, . . . she got all she ever needed from the packages which our shirts came in. With Pop and 4 boys, . . . she bought enough shirts to have a small mountain of pins. They easily slide into the edge of 3/4 oz leather . . . lay the leather down on a flat surface, . . . put a putty knife on it flat side down, . . . insert your pin with the string already attached, . . . voila. OR, . . . rabbit wire will work, . . . just make sure that the side not seen by the consumer is always placed down as there will be lines. I actually dry a lot of my stuff on newspaper. May God bless, Dwight
My first inclination would be to oil the blank hide before anything else is done. You'ld just have to experiment with the oil/wax combo, . . . my guess is it wouldn't work as it is probably too thick, . . . but someone more knowledgeable than myself may say differently. May God bless, Dwight
I would start with a sanding block, . . . and sand both edges, . . . until they all looked the same from end to end. I would then re-dye the edges, . . . VERY CAREFULLY, . . . with a folded up piece of a paper towel being held in the jaws of a clothes pin. I might even be tempted to dye the edges black, . . . it would depend on how uniformly straight the sanding job turned out. The sanding will remove the soap/wax etc from the original burnishing attempt. May God bless, Dwight
Painting Stamped Letters And Will This Dye/finish Hold Up
Dwight replied to FireFighter25's topic in How Do I Do That?
I do very little "coloring" of leather projects, . . . but of the few I do, . . . the acrylic paints Tandy sells were recommended highly. I'm told they are basically the same type product as Resolene, . . . but are pigmented to give color, . . . and don't need anything over top of them after they dry. Realizing your firefighter environment is not "genteel" to your equipment, . . . I'd say "Good Luck", . . . but that is the way I would start. Take a look on my website, . . . on the Product Example page, . . . lower right hand corner, . . . an IWB holster done with those paints. May God bless, Dwight -
RiverCity gave you the best answer, . . . But you can burnish your edges first, . . . if you only use water. No soap, . . no wax, . . . just water and a burnisher. I usually do that, . . . especially with belts, . . . as they will then "re-burnish" really nicely after they dye dries. What actually happens is that the soap or wax used in the burnishing or slicking process will clog the pores and not allow the dye to penetrate. If you only use water, . . . it will penetrate well. Two cautions: don't dye until well after the edges have dried, . . . DRY, . . . and don't re-burnish until the dye has dried, . . . DRY May God bless, Dwight
You need to add a bunch of details, my friend. Are you putting oil on a Roman shield to be used in the arena, . . . a billfold, . . . a cattle whip? Are you trying to use candle wax, . . . Johnson's paste, . . . ??? No, . . . dipping is not out of the question, . . . I personally dip all my dog leashes, . . . for oil and for dye. May God bless, Dwight
Let me suggest that if you have a Tandy store local, . . . go there and ask if they have any classes available. We could write all day, . . . and they can show you in 30 minutes, . . . twice what you would absorb here. May God bless, Dwight -
Rather than for me to re-write it, . . . read what Chief31794 said again, . . . it's all right on my experience as well. I still have a bottle of USMC, . . . but will only use it when it is specifically asked for. And, . . . yes, . . . dip dyeing has for me been THE preferred manner of dying. Browns I cut 50/50, . . . blacks I don't cut at all. May God bless, Dwight
My first inclination would be to adapt a single point sling like some of our young men are using in the sandbox on their M4's or M14's. That would take care of you during the stalk. For across the back, . . . I'm partial to shoulder straps, . . . kinda like pack straps, . . . as your crossbow is like my muzzle loader, . . . wants to slide off the shoulder and down under, . . . With a little ingenuity, . . . you could probably combine the two straps / sets, . . . into one "rig". May God bless, Dwight
Sizing A Piece Of Leather Slightly Bigger To Fit Something Inside
Dwight replied to mtrain17's topic in How Do I Do That?
The kinda sorta simple way is to simply lay the cell phone down on the back piece, . . . lay a piece of heavy paper on it, . . . form the paper down around the cell phone the way you want the leather to fit, . . . mark the paper, . . . cut the paper, . . . and you then have THE pattern for your cell phone case. You may goof up on trying to transfer measurements, . . . we all have, . . . but if you outline a pattern, . . . cut that, . . . it should fit. The arch rule, . . . rule numero uno, . . . never cut a piece of leather without first having a pattern. Make the pattern first. I buy legal size manila file folders from the office supply store expressly for this purpose, . . . it is my pattern material, . . . and it works great. A master holster maker, John Bianchi, taught me that trick, . . . using manila file folders, . . . a razor knife, . . . and 1 inch wide masking tape. If you cut a pattern and you cut it too small, . . . tape the piece back on with the masking tape, . . . re-cut it, . . . and go on with life. You will probably not like your first cell phone case, . . . you will be in great company, . . . many of us did the same thing with our first project. Keep it though, . . . it will be a constant reminder to try and do better. May God bless, Dwight -
End Result = Worth It!
Dwight replied to Shooter McGavin's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That's a good looking holster, . . . the smile says it all. May God bless, Dwight -
Double Layer Belt Thickness
Dwight replied to J Hayes's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I literally take a dial caliper with me when I go buying leather. An 8 oz starts at .125 thickness, . . . and a 9 oz could go as high as .155 and not be technically a 10. Putting two pieces of that together will make one heavy belt. I generally shoot for the belt to finish at .200 +, . . . and no greater than .240. I've worn a .250 for a number of years, . . . which also is very rigid and unforgiving at times. I buy my leather accordingly, . . . using my caliper to tell me what it is, . . . regardless of which stack it is in, . . . or what stamp is on it. Sometimes they inadvertently have a fat or skinny one in the stack, . . . it can mess up your whole day if you buy it without noticing it. May God bless, Dwight -
New (To Me) Style, Thanks To Thad Rybka
Dwight replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
If you google Thad Rybka you'll find he's another custom holster maker, and he's from Alabama, I believe. I heard something about his naming that particular design the Rhodesian, . . . because the first one like it went to Rhodesia, . . . may have just been a rumor. Anyway, . . . I've seen several pictures of his work, . . . it is surely top shelf stuff, . . . I like the design because it removes anything at the rear that could possibly interfere with the draw. I dislike it because in its OWB configuration, . . . it does not seem like it would tuck in close to the body, . . . but that is one of those situations where you can have one or the other, . . . but not both. It is also duck soup simple to make one, . . . practically regardless of if it is a .25 colt auto, . . . or a 45-70 wheel gun. The one I made for me serves me well in it's intended form. But from looking at some of the pictures, . . . he tends to use thicker leather than I did on mine, . . . and I'm not sure if he makes an IWB in that style. All I've seen were OWB with a loop for the belt coming directly off the top of the holster, . . . bending down, . . . and sewn in place. May God bless, Dwight -
Thanks, Winterbear, . . . now to distill all the examples into one or two products, . . . I think I need a nap. May God bless, Dwight
First Holster With Sewing Machine!
Dwight replied to Colt Hammerless's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Good job, . . . both on the holster and the machine. Like I tell em, . . . hands are for hamburgers, machines are for stitching. May God bless, Dwight -
Uhhh, . . . US Navy, . . . Navy Reserve, . . . Ohio Army National Guard, . . . never made it to the Corps. Fact of the matter is, . . . when I sincerely did go to see about joining, . . . door was locked, lights were out, nobody home, . . . so I boogied up the street and joined the Navy. But, . . . . yeah, . . . that is one area that would follow along the lines of some of the NA beading that was done. But I'm for now holding out trying to see if I can find any examples of anything done by the Powhatan tribe. I understand they were fairly big into wampum belts and the like, . . . but again I would like to let whatever is done be at least influenced by at least one original design. From what I understand, . . . Powhatan was actually a group that was part of the larger Algonquin nation. May God bless, Dwight
Yes, . . . it is. In addition to a different style, . . . this also was THE first holster I tried using my vacuum system. Not knowing how to use it, . . . experimenting as I went, . . . I used a piece of .110 veggie tan shoulder (just barely 7 oz) and really laid the vacuum to it. The weapon came out "fairly easily", . . . and I hung it up to dry. About 24 hours later, . . . it didn't want to go down in the holster, . . . so I shoved it in. I honestly thought I was going to have to cut the front seam to get it out. BUT, . . . I wiggled and wiggled till I got it out. Long and short of the story, . . . the mag button is seriously protected by a little dimple formed in the vacuum process, . . . I cannot take my thumb and press it hard enough through the holster to get it to realease. Maybe just a curious anomaly, . . . but it works. May God bless, Dwight -
Actually, . . . I'm more of a 3:00 guy, . . . maybe just behind the right seam belt loop. UNLESS, . . . I'm on a longer trip, . . . then that dude swings back to almost 5, . . . and gets buried in the Jeep seat May God bless, Dwight
