Everything posted by Dwight
Crossdraw Slim Jim Holster for Hunting ?
Dwight replied to bcraig's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Making a chest holster is really pretty simple as long as one does not get all wrapped up in technicalities. Take this simple picture of a slim jim . . . instead of a flap going down over the belt . . . a slight oval or round part is cut in the pattern to allow the back of the pistol to lay against your chest. Into this oval . . . three tabs are made that simply go thru a "D" ring . . . and on each side of the holster . . . and are riveted thru the oval. I like an inch and a quarter belt going from the D ring as you see it on the right side . . . it goes all the way around your back . . . and attaches with a snap hook to the D ring you see on the left of the picture. Just make it adjustable enough to wear with a Tee shirt or your favorite cold weather hunting coat. Attached to the top D ring is another strap that goes up over your left shoulder if you want to wear it off center . . . or over your right shoulder if you want it to point pretty much straight down between your legs. Personally . . . I prefer the left shoulder . . . it is more comfortable for me. You can put a thumb break . . . a hammer loop . . . or a suicide strap on it to retain the gun . . . and some guys like a loop that goes down to their britches belt to hold it from flopping if you are running or going down hill in the brush. Seriously . . . this is a simple rig to make . . . and I've never had anyone say it is seriously un-comfortable . . . while I have heard that with cross draw holsters. I've also included a similar rig I did for a guy who wanted one for his plastic fantastic pistola. May God bless, Dwight -
The Boss is lifetime warranty as well. The "cast iron" is just advertising gimmikery . . . the aluminum body on mine has lasted a full 25 years . . . has never had a problem . . . and when I have to move it . . . I'm darn sure glad it is aluminum . . . Probably best thought there . . . can you drive to either location for service. I'm 2 hours from Tippmann . . . I call em . . . they tell me they're waiting for me to get there. May God bless, Dwight
We have a lot of the same things going for us. I'm 80 . . . and while I can walk pretty good . . . I don't add extra if I don't have to. Given all of the particulars you mentioned . . . I would not do a cross draw . . . I would do a chest holster . . . with probably a hammer thong to hold it in place. I think could be made so it would fit the 45 as well as the Remington clone. Laugh if you will . . . but I would make the holster for the larger of the two (I'm thinking the Remington would be) . . . and letting it also be used for the 45. If there is a big difference in the barrel length . . . a short piece of wooden dowel could be dropped in the toe of the holster to keep the 45 from falling all the way down in. Tie a slim leather thong to that piece of wood . . . and it could be pulled out for the Remington. Cross draw holsters for large pistols are uncomfortable for me . . . chest holsters are much better . . . but you'll have to make that decision. Making the holster standard or rough out . . . makes little difference unless the flesh side is really rough. Don't add a lot of finish to the inside of the holster . . . as the finish is harder than the leather. Also never leave your weapon in the holster when you come back in. Also keep them minimally oiled . . . as the excessive oil will be picked up by the leather . . . then dust . . . and it will act like sandpaper. For what you are doing you should not need to line it . . . just make it and use it . . . Have fun. May God bless, Dwight -
In 2000 . . . I made a deal with a retailer that after the Christmas season . . . he would sell me his used Tippmann Boss for a thousand bucks . . . and put out a new one for display. Christmas came and went . . . I got my cash together and went to see him. Some kids had jammed up the machine . . . and it needed to go back to Tippmann for repair . . . SOOOOooooo . . . he went in the back . . . grabbed a brand new machine . . . and gave it to me for the thousand bucks price. A Tippmann Boss. I still have it . . . have sewn everything from about 3/32 of an inch (207 thread probably) to 3/4 inch . . . (no thread . . . just punched the holes . . . cowboy stitched that holster later) . . . and the number of belts and holsters I've done with 95% 346 thred . . . is well . . . beyond calculation . . . there were so many. I've looked at the others and will give them a possibility of being worth while . . . but the Boss is definitely so. I've also needed work a couple times . . . took it to them . . . they sat it on the desk . . . an hour later . . . me and the Boss are headed home to do more work. And of course there was no charge for their work . . . including once putting in new parts . . . even though we were not 100% convinced that it was necessary. Tippmann ponied up the cost as a Just In Case scenario to keep an old client happy. And I still am. I also have a Cowboy 4500 . . . which now does most of the work . . . but the Boss is there when needed. And I have no doubt it will answer the call when needed to do so. May God bless, Dwight PS: Remember . . . the Boss is the one with the proven track record . . . the others are the new kids on the block. Where do you want to put your money . . . proven track record . . . or possibly good performance. That is the bet you make . . . either way.
Help Needed:About wiping the glue and edge paint
Dwight replied to kellyswanson's topic in How Do I Do That?
First thing I would say is toss the glue . . . go to Weldwood contact cement. Much easier and quicker . . . and . . . more accurate to use as far as getting the result you wanted. A note worth thinking about . . . dye will not penetrate glue successfully. Sometimes a bit . . . most times not at all . . . so learn to be careful where you put it. I use cheap little acid brushes . . . get a 100 for 3 bucks or so . . . use one a day . . . get fresh one tomorrow. Edge paint . . . I don't bother with it. My customers in 20 years have never mentioned it one time . . . so for me . . . it's not worth the hassle . . . But on the very very seldom time I do it . . . little round wool dauber on a metal handle . . . dip in the dye . . . shake off most of it . . . and very light short strokes . . . and if you hold your mouth right . . . if the moon is in the right position . . . and if the Ohio river isn't flooding . . . it might work. May God bless, Dwight -
Look on Ebay . . . copper rivets . . . https://www.ebay.com/itm/352511867169?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20231107084023%26meid%3D0d1f268ea5e74b5c84712fb55d99b4c2%26pid%3D101875%26rk%3D4%26rkt%3D4%26sd%3D352656754562%26itm%3D352511867169%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecallReplaceKnnV4WithVectorDbNsOptHotPlRecallCIICentroidCoviewCPCAuto%26brand%3DUnbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A3525118671690d1f268ea5e74b5c84712fb55d99b4c2|enc%3AAQAKAAABkG96wQ16jds4VFcrhy1F3d4mbwZUJI9Fs%2BgdXYAHIzlX2e3YaNh7x%2BEnKA3G%2BCqSl1Xn4McfcWFK1GytmS2qxJ87mtE8Gm3iR1Ja4WBwh0hNHJrJx3Ki5mp04ow4CO7lP%2BooCybZDDU%2BbbSwmg7CbTin%2BBzBzbCYVnbjvyQAHu6--HI4MB7SvJl5IJqlyvomgoLMlgT6qAJzX0SANJhty2dLNihoUJlF8VqAlqljdRi835uzdT%2FRw2dvDZ%2FKGbQCHYRB14v0kGwE3cSXw%2B2qhe%2B0H%2F1j8myQUlVEX3joNhwh7qOrSJOdzneyRFZuDtxGj41Mo4ttFpvmPdZnY7DNvrzgPZCIDLjXsrwahFpin7FtgWogJyNJJFhlkZOSSgeqjgV%2FE6qC577KxRtf3aqZZ0MdG4rIUuSNO3m0nywm82cOYvXRVnn69oHwxBnnQ0KjnMpyrigJIETey1stdnFqzITxjP1rL6sGbvwarZEpOM1iVBWuTfedF6PWlN7ZXF9L4SBY50J8Wnr10iexzh033FM%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JX5ZZDZP9HHYXS3MDAEYDAG9 Cut a piece of 8 or 10 oz . . . about 7 inches long. Push the ends together . . . . then overlap the top corners . . . and swing the bottom corners of each end up so they are level with the top edge of the loop of leather. Put three rivets in it . . . in a triangle pattern . . . with the point at the top. That is the VERY BEST way to hang a hammer loop off a nail apron. I usually put a 8 or 9 inch piece that goes straight up from the loop we talked about . . . and fold it over the belt . . . with two snaps. it's THE most comfortable and easiest to use May God bless, Dwight
Harbor Freight has a plastic pouch with like 10 different files . . . they're all little guys . . . perfect for this kind of work. Sign up on line . . . . you may hit their 50% off deal. May God bless, Dwight
This idea will not get you thru a dozen belts . . . but it should get you thru 1 anyway. Take a look on youtube . . . making things out of HDPE . . . which is gobbledygook for milk jugs. You can melt the milk jug and put it into a mold you have made that is about 1 inch square and 4 inches long. Once you have that piece . . . cut it with a sander to the correct width and depth . . . then get a set of fine files . . . there's about 10 in the set at Harbor Freight . . . you can use those smaller files to make the lines in the HDPE. If you take your time . . . you should get at least one belt out of it . . . and if the tip messes up . . . sand it off . . . and make another one. OR second . . . find someone who has a laser engraver . . . that is strong enough to cut 1/8 inch steel . . . He should be able to duplicate one for you . . . that will last a long time. One of the keys to being successful in almost any hand work these days . . . think out of the box . . . and be resourceful May God bless, Dwight
That's good . . . the new Bat Masterson . . . lol May God bless, Dwight
You can't do much better than dealing with one of the sponsors here . . . Toledo Industrial Sewing Machine Co . . . call em at 866-362-7397 I've done business with them for a number of years . . . always good folks to work with May God bless, Dwight
Weaver leather. . . in Ohio . . . their handbag section may have them too. I've used Tandy's brass rivets for 20+ yrs . . . never had any major problem with them. Not meaning to be disrespectful . . . but setting technique is the key to good rivet use. May God bless, Dwight
Resolene is THE sealer . . . May God bless, Dwight
- 7 replies
- finish coat
- sealer
(and 2 more)
For 20+ years . . . I have put the Chicago screw together with my fingers . . . Picked up the leather piece . . . and grabbed the back piece of the Chicago screw with the leading edge of a pair of professional lineman pliers. Left hand puts the squeeze on the screw head . . . and if you have enough ooomph in your left hand . . . you can shake the holster and it won't let go. If not . . . eat some Wheaties. Right hand picks up the screwdriver . . . and when it's job is done . . . that Chicago screw is "there" . . . and just maybe forever. Works for me. May God bless, Dwight
I've made that mistake . . . I take a deep breath . . . get out the razor knife . . . cut the stitches . . . pull out the thread pieces . . . Sew the belt piece . . . go get a coffee . . . and double check to see that I sewed it. I don't use that greasy kid stuff glue . . . I use Weldwood contact cement . . . Start at the toe end . . . stick a needle in that end hole . . . down into a piece of rigid foam . . . come up about 10 holes . . . stick another needle . . . and squeeze that piece between the needles together . . . move up 10 more . . . squeeze together . . . and so forth. Take it to the same sewing machine I did it with the first time . . . stick that needle down in the first hole . . . and VERY CAREFULLY sew it back together again. So far it has worked every time. May God bless, Dwight
How should I store my leather jacket during off season?
Dwight replied to davidmicheal's topic in Member Gallery
Don't laugh . . . but you could move to Ohio . . . I have several leather jackets . . . I keep em all on good hangers . . . in my hall closet . . . knowing that July and August are the only months I may go completely thru and not need one of them. Today is the 22nd of May . . . all afternoon I'll be wearing leather . . . 50 degrees at 10 AM . . . yeah . . . leather May God bless, Dwight -
Problem with leather splitter/skiving machines
Dwight replied to Coloradoguy's topic in How Do I Do That?
Uhh . . . yeah . . . reading it myself again . . . I don't know . . . brain out in left field . . . I guess I was just going as I usually do . . . as I always take the blade off . . . clean the grease off it . . . put it back on . . . then adjust the depth . . . as most of the time, what I did last time isn't what I need this time. And that is why the blade is not over the center . . . I just stuck it back on from the last use . . . after I greased it up. I actually used to use it a lot more than I have lately . . . as I've been taking a micrometer with me to see truly what thickness leather I'm buying . . . and it has cut down on my time on the splitter. Thanks for both points . . . especially the blade position as I know better . . . just didn't do it last time I put it back on. Glad someone is watching over me . . . May God bless, Dwight -
That is my second mat like that . . . and I've already turned it around. I love the thing . . . Wish the splitter was as easy to use as the mat is . . . lol May God bless, Dwight -
Well . . . to start from the beginning . . . first determine how thick you want this piece of leather to be. Then loosen the large allen screws on each side of the blade . . . then by turning the black plactic knobs . . . you can raise or lower the blade . . . and when you have it where you want it . . . tighten the large allen screws. Now you are ready to go. Loosen the knob on the right side of the skiver . . . and you can then use the lever to lift or drop the roller . . . drop it and insert the leather piece you want to skive. Pull thru about an inch or two while holding the lever down. You will notice it drop as you begin your cut . . . as it pulls the roller up to the proper position. Once you have that inch or two skived . . . tighten the knob on the right hand side of the machine . . . while holding the lever down . . . that will keep the thickness even. You can then lay a board or something on the bail . . . to keep it from allowing the leather to jump up . . . jumping up gives you the bad skiving experience. Pull the whole piece thru . . . loosen the knob . . . insert the stub end . . . about an inch or two from where you need to start . . . again under the bail . . . and tighten the knob . . . pull the stub end thru and you are done. May God bless, Dwight -
I use my Tandy splitter almost exclusively for belts . . . generally I leave a little extra on each end . . . I grab it with a pair of vise grips . . . and pull it thru. I actually start about 10 or 12 inches in from one end . . . then turn it around and do that section last so the whole blank is the same thickness. You are probably having two problems . . . The first is your blade is not sharp. Coming from the factory . . . none of those blades are SHARP . . . they are kind of a dull sharp . . . but not sharp type sharp. Your blade should be able to be held in one hand and shave 1/2 inch slices of a piece of copy paper . . . just like you might do with a straight razor or a pocket knife. If it is not that sharp . . . you need to work on it. I sharpen mine with several stones . . . ending up with a 3000 grit . . . and then I strop it . . . and I strop each side. When I get done . . . you do not want to touch that blade for any reason except to cut leather. Your second problem is in the picture . . . my hand it on the bail. Your leather needs to be under that bail . . . and as you pull the leather thru with your right hand . . . hold the bail down with the left hand . . . or lay a 2 x 4 edge on it to keep it down. If you don't . . . your leather will ride up and you will cut completely thru your blank. If you take a good look at the picture . . . my blade will appear to be rusty . . . it is not . . . believe me. It is greasy . . . that is just plain old axle grease on it . . . and it is on both sides . . . it keeps the sharpness from going away between uses. I wipe the grease off the blade . . . then run a piece of scrap thru it to check for sharpness . . . before I use it. When I get done for the day . . . unless I know for certain I will use it the next day . . . I grease it up and set it off my work bench. Hope this helps . . . may God bless, Dwight -
Let's talk about how you use resolene . . . I had problems similar when I first used it . . . because I used it too strong . . . and used too much of it. First . . . mix it 50 / 50 with COLD water . . . not ice water . . . just tap water from the cold side. I actually don't mix it . . . I shake it . . . mixes real good that way. I use a cheap 1 inch bristle brush I got from harbor freight . . . cost about 30 cents each or so . . . maybe more now . . . have not bought any in a while. Dip the brush fully . . . and start wetting the belt . . . or whatever you are doing . . . process is the same for all items. As you wet it . . . swirl the brush in little circles . . . building a light froth . . . you definitely want to see them there bubbles. Once you have gone end to end with the froth . . . the start end will be trying to dry out . . . hit it again . . . this time using long strokes . . . then cross wise strokes . . . then long strokes . . . then cross wise . . . Keep this up until there seems to be no change in the finish. Hang it up for a couple hours . . . get it down then and play with it . . . you want to flex it a bit . . . not seriously . . . just a bit . . . Last thing . . . especially with belts . . . find a 3/8 or 1/2 inch steel bar . . . roll the belt over that rod . . . pull the belt up close to your stomach . . . roll it across the rod . . . and pull it down sharply . . . flexing it the full length . . . and do it both ways. Give it an hour or two to rest . . . and then just use it. Using this process . . . I have no more trouble with my belts or the resolene. I will have to say though . . . I make very few single layer . . . most all are double. May God bless,, Dwight
If there is a powered skiving or leather splitting device there . . . it would be the first thing I would go for. Horse related items fall into two categories . . . plain functional . . . and decorated functional. Thickness is not a big deal on the plain functional . . . as long as it works . . . it is good. If she is doing decorated bridles . . . reigns . . . breast straps . . . etc . . . the thickness makes it move from good to great quality . . . and without that tool . . . her inventory of leather has to be tremendous compared to that needed for a person with the powered skiver or leather splitter. A fellow I know picked up one at an auction years ago . . . cute little dude . . . does up to 2 inches wide . . . about 1 foot every 30 seconds . . . but it sure makes life a lot easier if you need longer pieces done. May God bless, Dwight
You simply pull the left arm in . . . it doesn't go any place . . . yanks out like it was supposed to. The belt anchor is both good and bad . . . actually it is good if it is anchored on both sides . . . kind of acts like a pair of suspenders. But if it is loose under the left arm . . . it is more comfortable for me May God bless, Dwight
For straight holes . . . hands and punches will be hard pressed to beat a drill press. Remove the drill bit . . . put a needle in it's place . . . unplug the machine . . . and punch your holes. If you really . . . REALLY . . . want them to look good . . . punch them from the top first . . . into a piece of hard wood . . . with the drill press stop set 1/8 of an inch below your bottom edge of the sheath. Then turn the sheath over and punch from the back side all the way thru. Makes right real pur-teeee holes for stitching May God bless, Dwight
The answer to that question is the simple addition of a thumb break on the holster . . . the good thing about one of those is your thumb is heading in that very same direction anyway . . . and all you have to remember to do is have it ready to do it's job which is simply to separate the two pieces of leather by a downward push of the thumb as you push back a tad into your hip . . . it breaks the snap loose at the same time you fingers are surrounding the grip . . . and you are in great shape. As for the G3C . . . of all those you have mentioned so far . . . it would be your best carry option in my opinion. I owned a G3C for a while . . . got talked out of it by a young man . . . his dad had a G3 which I had made a holster for . . . and they both loved it . . . he didn't have enough money to buy a G3C . . . so he kind of begged me out of the G3C and the holster for it. He doesn't carry it . . . it's his home defense weapon. I never had any trouble carrying it as my CCW . . . other than I just simply am not a 9mm fan . . . I like the .45ACP . . . feel comfortable with it . . . which is a big part of feeling comfortable with your CCW. I can get it back . . . make you a holster for it . . . send it to you . . . you can wear it for a week . . . if you don't like it . . . your only cost is the return shipping. I can put it on Ebay . . . it'll be gone in a week. May God bless, Dwight
