CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. That's the problem to much play ,so mewhere,If you look at the bottom on the back side where the flat gear comes out of the arm,the slot on the backside that's were you shine a torch into & turn the machine around & look for thre little hole in the gearthat's were the screw is you might have to clean out the hiole to get at it,tighten it & see if that helps.
  2. If you take the bobbincase out how much play to the left & right does the shuttle driver have?Sometimes the little screw in the gear loosens up & needs to be tightened up,or the gears could be worn out. Bob
  3. Yes.it's a good machine for chaps,wallets & etc.It has a walking foot needle feed & no lower feed dogs to mark & it was made to sew leather. Bob
  4. Here's the video: That video is with the old style motor as the motors now have a digital readout & 600Watts of power! Bob
  5. Hey Randy,I just thought I'd mention that maybe you might not attend the shows we do as we go to shows @ Sheridan,Whichita Falls,TX,the Harness Makers & that's about it since Wickenburg(2000 mi) & some the the other shows are just to darn far to go. Maybe we'll get to meet you at one of the above along with some other people from this fine board? Thanks,Bob
  6. It looks like a great job there,better than handcrankin it?Have you ever ran one of those machines much?I've always wondered how they hold up? Bob
  7. Okay, Here's a sample underneath sewn on the same CB 4500 S needle on left & D on right. Bob
  8. Since this is the needle section I frequently ask abiout needle points here is a comparison of the D vs S point of Schmetz #1 being the S point & you can see how much finer the needle hole looks .You can plainly see the larger hole in sample#2 that is because there's a cut on the side the S point only make a cut parallel with the line of stitching with alot smaller hole.These were both done w/#277 thread & #25 needle. Bob
  9. Ricardo, Your very welcome,I always try to do the best I can. And if you ever have any questions please call anytime. Thanks, Bob
  10. We have them along with the matching needle plate & feed dog if needed. Bob
  11. Art, You are correct the Pfaff uses the 134-35 & the 135x17 is like 1 mm different & seem the work as well.NOW what I was refering to is the needle package he shows in the picture is the 134 aka 135x5,135x7 which is 11/2" long are the wrong ones for this machine & I felt that that is the one he's using in his machine(since there in the pic) & it looked like the needlebar almost hits the foot & he should adjust for the longer correct needle. Bob
  12. It will not make a difference on your tension but you are using the wrong needle for this machine if you notice the one pic where the needlebar is almost hitting the foot,well as you sew & go over a heavy seam it will hit & break off your needlebar thread guide.You need to have a 135x17 or 135x16 which is a leather point & the correct needle for this machine which is 1/4" longer & will require theneedlebar to be raised up 1/4" then it won't hit the foot. Bob
  13. If you try to make the 135x16 work on a 31-15 you will have to take the needlebar thread guide off & everytime you change needles the needle clamp will fall off,the 135x16 are 13/4" long & the correct needle is 1/1/2" long. Bob
  14. None of the 7's ever had needle feed,this one has a walking foot,it would probably sew the belts ok but it's a little to big of a machine f/wallets & thinner sewing.
  15. http://parts.singerco.com/IPpartCharts/7-1_to_7-55.pdf
  16. There is alot of different models of the 7 class,probaly close to 80,I don't remember seeing a 7-30,do you have a pic? Bob
  17. It can be tweaked a little & get close to 3/8" footlift but it'll never sew that thick & the largest thread is #138. The is a shortarm version of a 31-15 w/a viabrating foot, Bob
  18. I put it on a 29-4 b4 I shipped it & had to move the wheel out on our machine but then Singer has a few different wheels. It's great you got it working,alot easier then winding them by hand. Bob
  19. Chris, I'm glad you got the parts,couldn't the handwheel be moved? Bob
  20. We have some Orange 207 nylon. Bob
  21. The Ferdco 440 is the same as the Cowboy Model#2500 we sell & they take a standard needle & will sew up to 7/16" thick & will a heavy thread.They just have a bottom feed in them that can leave teeth marks on the underneath side of the leather. It's the 97-10 you can't find needles & parts for.
  22. Here you can see the roller in the cam that runs the zigzag. I want you to know I am no expert on these machines,I have worked on them alot & reair & get them sewing but when it comes to doing the change you want to do I think it would be cheaper just to get the machine you want in the first place.I seem the remember asking Consew about these parts before because we wanted the change the 2 step to a 3-step & I think the parts were around $7-800.00 5 yrs ago. Bob
  23. The 199R-2 & 3 machines have the cam on the outside ,the shafts are longer for both the cam & the cam following lever, You will also have the change the gear on the inside,buy longer shafts,the lever & roller that rides in the cam too. Here's a pic of a 199R-2A machine Bob
  24. Ok, so the shafts are pinned,on the far right where the rod comes down to make the shuttle go back & forth sometimes this nut can loosen & the bolt can back out making play in the shaft.
  25. One last thing to check is take the bobbincase,aka shuttle out & spin the shuttle driver to the left & right to check for play in the gears.
