CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Maybe this will make it easier. Bob
  2. You should be able to use a #207 w/a #23 needle,what model 145 is it?the H4 high lift uses a longer needle than the H3.We do have needles,parts & etc for it as we are a Pfaff Dealer. Bob
  3. My guess is the inside foot parts are worn allowing the inside foot to move left & right as your sewing.Turn the machine around by hand & see if it moves left to right. Bob
  4. Look @ page #8 http://parts.singerco.com/IPinstManuals/7.pdf
  5. Carol, The 7-9 was replaced by model# 7-34 you mighjt find more info under that #,years ago we used to modify these to sew to 3/4" of leather as they come from the factory they will sew 1/2" they were made for general heavy sewing like tarps & etc & can use a real large thread. We still have some parts & needles in stock. Bob
  6. The 30-7 could handle 10mm easy the 30-1 might in a soft leather.
  7. This is a model 30,very commonly used for shoe repair & we sell alot of them for sewing on patches on biker jackets,the foot swivels & sews in any direction.The problem is if your sewing on a finished good that you want to look nice on top you'll find that the teeth that pull the leather will dig in & leave marks. Let me know the model# on the little brass plate on the front as it's either a 30-1 or a 30-7 Bob
  8. Scott, Trox is correct in saying you can use the newer manual,your machine might adjust different but it still needs to look like the last page of the manual,it shows the shuttle driver & needle relationship. Bob
  9. Hello,Sorry I missed your call earlier,
    I seemed to have lost your info with your order & address on it.
    Can you please send it back & I'll get back to you real soon.
    Best Regards,
    Bob Kovar
    1-866-362-7397
    419-380-8540
  10. Doug, We have the slotted plate in stock that eliminates the feed dog & is great as it won't mark the bottom side. Bob
  11. Char, I think one of these could be torn apart,cleaned ,painted & put back together in 10hrs. Yes,the 227 & the 206 feet interchange. Bob
  12. That pin is a taper pin that you hammer out from the back ,you might want to put a small round pipe in front w/a hammer behind it then hit from the back. Bob
  13. It's to bad your having a problem as that should be a good machine for you as long as you thread it & put the needle in correctly.We always try to get the customer to test the machine before it leaves & the we can also watch them thread it to make sure it sewing to their satisfaction,you should take it back & tell them it isn't sewing like it should & maybe it just needs some minor adjustment. Bob
  14. Wiz, I doubt if the gears in these could take much more power,I haven't had any break yet & maybe that's why they keep it @ 300 w.? Bob
  15. CustomDoug, We have put the 300w. Sewpro on our 3500 Cowboy & it works pretty good sewing to 3/4",BUT if your consistantly sewing 3/4"+ I would recommend getting a seperate reducer setup you'll have more torque & better speed control.We sell alot of the SewPros to people that have smaller machine like a 31-15,111W & etc they work great for these machines. Bob
  16. I'll have to agree with Darren on this #1 you can't buy the parts(Singer hasn't had them for years) unless someone has a broken machine laying around,then when you get it done you'll have a machine that will sew just under 1/2" & will leave feed dog marks on the bottom of the leather. We converted some years ago & found out it's not real easy as some casting didn't have all the holes drilled & tapped for the screws & shafts that had to be put in them so it is alot of work to do.
  17. The clear oil is the only oil that won't stain,the oil you got is possibly a littler heavier.Try a little test out some clear on a scrap piece of leather & next to it put some of the new oil on & let us know what happens. Bob
  18. Wow!That sure looks like one we stretched years ago.My cousin is a machinist & we would strip all the parts out just take the shafts & bars to him,no needle plate & he was so good that when we put the needle bar in & went to line up the hole in the needle plate they hardly ever needed to be adjusted.He also put some allen screws on leftside for adjustment & made the casting a tight fit around the heavy walled tubing that we used to extend the arm. So, what size thread are you using?That will determine your needle size. On this machine you need to wrap the thread around the second tension(lower one) 1&1/2x We have a manual,needles & most other parts too. Bob Just for the heck of it could you tilt the machine back & take a pic of the bottom side & post it? Thanks, Bob
  19. Ok,I took a pic here of a sample on a 2500,the first pic is right off the machine & the 2nd is after I rubbed it w/a spoon. Both pics are of the bottomside. Bob
  20. I think your biggest problem is trying to use to 346 to sew so thin,you should try 138 or maybe 207 on the thinner leather.Your leather has to be thick enough for the threads to cross in the center. Bob
  21. Those portables don't like the 138 thread. Bob
  22. Josh, I'll be going to the show @ Wichita Falls next week on 9/30&10/1 & if you want to p/u there & save shipping let me know so I have one on board for you. Thanks, Bob
  23. Ok,I took a pic here of a sample on a 2500,the first pic is right off the machine & the 2nd is after I rubbed it w/a spoon. I hope this helps you. Bob
  24. Ken, Years ago we used to modify them to sew 3/4" of leather & sold alot of them,but from the factory as-is they'll do 1/2",it has a very large bobbin & can take large thread the biggest problem with them is the feet,they are large & will probably have to be narrowed down so you can sew close to things assuming of course you want to sew leather. We have most parts,needles & thread in stock for it. Bob
  25. Hey guys I want to thank you both for the kind words & for buying a Cowboy machine from me.You both are great to work with. Bob
