CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. There is one model of 111w that has reverse it's a 111G156 & many models of the 211's have reverse but parts are getting harder to get for it,along with the fact that the 111's sew leather better make them a better choice. There's also Consew 226R & Juki 562 that are very much like a 111w.
  2. Tony is right the model# is on the tag,I can't read it but I'd guess it's a 29-4 Bob
  3. Yes, All 29's take the same needles some of the internal parts are different but it makes it nice.It makes it easier for us too when we sell them,some brands have different subclass's the take longer needles. Bob
  4. For sewing webbing & cloth use 135x17 for leather use 135x16 which has a cutting point for#46 nylon use#14,f/#69 use#16 or18,f/#92 use #18 or#20,f/#138#20 or#22
  5. Hello Arno, I will try to find the dealer contact info for a Cowboy Machine in Europe for you. Bob
  6. Ok,you knpow the part that holds the race in follow it over the the right & it looks like a bushing just underneath it is the screw to loosen.
  7. I forgot to mention that I don't know of a repair manual for the 7 class. Bob
  8. Christopher, How much side play does the hook have?The race(the part that holds the hook)has a plate on the backside that sometimes gets old thread & dirt behind it,so you can take out the 2-screws that hold itin & take the screw out of the back that holds the spring & this plate on & clean it out.#2 If there's still alot of play the race can be wornout. #3 looking underneath just to the laft of the hook area you'll see a screw w/a big head on it that goes into a clamp you can loosen this & move the whole race left & right re-tighten the scew as tight as you can get it when your done. Bob
  9. Hello, do you want new or used?
  10. CowboyBob
    Singer 29 K
    I guess the a first time for everything so here's the pic you wanted. Bob
  11. CowboyBob
    Singer 29 K
    I have a new one for $49.00 + shpg
  12. Well if a flatbed will work for you & you can get it for under $1,000.00 it might be worth getting because for $2,095.00 +shpg you can buy a brand new Cyl arm machine. Bob
  13. Forget that model of Juki & get the Singer (take your leather along & see how it works)
  14. Wiz is correct it's a tacker,it sews the length on the slot it looks like maybe 4" long.This machine is used in draperies. I just sold one like this a couple of weeks ago to a Drapery Shop. So don't even think about tyring to sew leather on it. Bob
  15. Marie, I just checked & have 3)packs of#20's in stock & also have some #21 too. Bob
  16. Have you adjusted the lift yet?You should have to raise the pressure bar up approx 1/4" this will give more lift under the roller>The reason the foot swings is so you can thread ur needle,because as you swing it down it goes lower by way it's made. Bob
  17. Marie, I'm pretty sure I have them & will let you know tomorrow when I get back in the shop. Bob
  18. When you time the hook do you have the needlebar go up 3/32"before the point of the hook is at the needle?
  19. Heck Yeah!! I'd give her $200./00 too!!That's a great deal.
  20. Art is correct it's a Pfaff & it's a high lift either 145 or 545 depending on bobbin size.Great machines. Bob
  21. Blindhem is used on pants,dress pants you sew on the inside & the stitches don't show on the outside.
  22. This is a blindhem machine for pants & draperies most parts are still available.
  23. Mimi, I just thought I'd get my $.02 in here.Most of the time the pulley comes off w/o any problem,just be sure to loosen the set screw first.IF it doesn't want to cooperate you can put a larger wrench between the back of the pulley & the motor & pull the clutch arm down & it acts like a puller & after it slide off a little you can lift the arm up & put a screwdriver behind the wrech to fill the gap & pull the arm down again. This is how we've done it for years if they are tight. HTH, Bob
  24. The 11w151 wouldn't be to bad of a machine for leather as itll sew to 5/16"thick & with the needlefeed it can pull it through.The 111w or alittle better than the 211 because they have a larger heavier handwheel. There are some feet available for them too like a zipper foot with the toe on the left or right & also a foot w/a nylon bottom that helps the leather feed better. Bob
  25. Alot of older machines needed the thread lubed because all they had was cotton & linen thread that had to be lubed to sew,nowadays nylon thread you really don't need it until your sewing around 3/4". There is silicone thread lube avaiable .
