CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. The best way to find out is to take your leather your going to use ( some types of leather sew different than others)& try it on the 205 first,it's the better one for leather,it will be sewing at it's max so you might even have to lube the thread to help it sew. Bob
  2. The only thing different is the stitch length. Bob
  3. The 128x2 are small @ the top & 11/2" long,I have that needle in stock in sizes #12,16,18,19,20,21,23,24. Bob
  4. I would say to stay away from these machines,They were made for sewing clothing with household weight thread. Bob
  5. Your stopping it in the wrong spot,try stopping right after the needle picks up the thread,let the needle come out of the material & then pull alittle slack thread & pull out the material you've sewn. Bob
  6. Yes,this sounds like a good buy.They take the 138 w/o any problems & you'll also like the larger bobbin.The feet from your 111w wil;l fit on it too. Also when replacing the bobbin you don't have to pull it up through the needle plate like on the 111w,just leave approx 1" tail of thread put it in & start sewing. Bob
  7. It's been a while since I ran one ,but I think it'll handle chap weight material ok using #69 or 92 thread. We probably have the needle but on a machine this old have found out that alot of times people change them for something different & would like to see an old one if you have an extra to mail us. Bob
  8. Kevin, Usually I click on the pic & it'll expand. Bob
  9. I found this old manual in my collection of a postbed that threads the same. Bob
  10. I couldn't find a diagram so maybe this will help. Bob
  11. Wiz is correct it's a 9" 441 style. Bob
  12. That sounds like it will really slow it down.Great Job. Bob
  13. It should sew up to 20 oz of leather real easy & use #207 thread if you want to. We have most of the parts in stock for it. Bob
  14. I've seen one way treadle brakes & think they would be pretty easy to make.
  15. A machine w/o a bobbin makes a chainstitch that will have loops on th bottom of the stitch that looks like the under side of a potato bag,very unsightly in leather. There are machine like Singer 300w that make a chainstitch & used in tarp & canvas & even some auto upholstery. Bob
  16. Ann,I usually tell people the max is around 20 oz or 5/16" thick & 138 thread will be the largest. Bob
  17. You might want to take the needle plate off & see how close the hook is to it,it might be hitting do this to much & you'll be needing a new hook,you might try adjusting the hook guard to just touch the needle. Bob
  18. Well this machine is for sewing thin material like clothing,it might sew thin leather like pocketbooks,wallets with # 69 thread maybe up to 1/4" thick. Bob
  19. Knut, I'm glad to hear you got it going. Bob
  20. Nice machines you have there.That one look similar to this Singer 98-2 I have,which was made for rebooting car tires (back in 1915) I think it would sew leather easily to 1/2" Bob
  21. It will be good enough to sew chaps as long as you get a teflon foot so it can feed better,max thread size is #92 Bob
  22. Ok,take the needle plate off,turn the machine around so the needlebar is all the way down & turn the machine in the direction it runs & let the needlebar rise up 3.6mm & the point of should be @ the needle.Let me know what happens. Bob
  23. There should be a brass plate on the back that has the model# on it like 463,483,a 230 is a household machine.
  24. Here's a pic of the pad that was supposed to hold the oil.I've marked the 3-spots that you should oil.If you fill this well up you have a big mess,so if you oil these 3-spots often the excess will run down in the well anyways. Bob
  25. Years ago when this machine was made they had bobbincases that has a felt on them,they haven't made them with it on for years so just put the oil in the groove were the bobbincase sets give it a drop maybe once every 1/2hr of sewing,& put some oil on the 2 pivot points under the hook & you'll be OK. Bob
