CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. The best way to find out is bring some leather & we'll try it out,the 6 oz & we can try it on the CB3500,I'm sure it'll work w/the #138 thread on the bags & then you'll also have it for the heavier leather too.We do have both machines on the floor ready to go.Your more than welcome to come in anytime during our normal business hours 8-4 during the week & Sat 8-12.
  2. Yes,it should sew close to a total of 20oz of leather.You'll need to use #69 thread to sew the 2-3 oz & maybe even loosen the tension alittle but it should handle that too.What is nice about this machine is we have all the parts,screws,feet,needles & etc in stock for it.
  3. I have a customer that has bought at least 5 of our little 550 watt Family-Sew motors & mounted them on Landis#12,so a 1000w would surely work.
  4. Wiz,do you notice a difference in the way the slow speed operates as you push on the pedal?Also did the brushless ones you have make a noise?
  5. We have some that have hardened blades on them that seem to last a long time for$2.00 ea.Or $20.00 a Dz.we have a lot of repeat customers on them too.
  6. Looks pretty nice to me,excellent stitching & tooling too!! Great job!
  7. Yes,the brushes seem to last a long time,IDK of anyone who's had to change them yet & we have a lot of people using them.It comes w/a extra set of brushes & the brush covers are on the outside & might takes 1-minute each to change IF or when needed.But there is a lot of brushless motors out there to choose from.
  8. You might have some thread or lint under the bobbin tension spring or the spring might have gotten bent.You could try to take the bobbincase out,take the spring off & bend it in alittle & it might not hurt to get a couple of new spare ones just for times like this.Do you have a backlash spring in the bobbincase?
  9. No,it has brushes,we used to sell them BUT they make alittle more noise when running,didn't have a smooth acceleration when pushing on the pedal,a pain to program & the main reason approx. 2 out of 10 would quit working do to the circuit board burning out.The motor we sell has brushes,is very quiet,has a knob for speed control & accelerates very smoothly as you push on the pedal.I haven't sold the brushless type in 3 yrs & they might have improved the circuit board & the speed control but these have been so truble-free for us that I don't want to change.
  10. A smaller needle can cause the thread to hang up in the eye,when sewing webbing you can use a size or 2 larger than recommended for your thread size because the hole closes up after sewing @ you'll end up breaking less needles too.I have customers using #138 & #24 needle in webbing.You might have either too much check spring travel or it could be set too tight .But tyr a larger needle first.Then move on to loosening the pressure on the check spring & or shorten the travel,BUT just one thing @ a time.
  11. Yes,it would be easier to take the head off,I can't tell you what to do,I have done them before but it's something you can look at & see what connects from the top to the bottom.one thing when you take it off is the tension mechanism will be hanging underneath by 3-4 in & you need to set it down & lay it on the backside so you don't damage it.There's 4 head bolts ,a screw through the foot lift arm to takeoff(or maybe a cable) IDK if it's that heavy,I once delivered a Landis Model E myself,wheeled it out of my trailer on a ramp & into the shoe repair shop on the 2-wheel cart.
  12. Yes,the 153's have a stitch length dial on the side because there isn't room underneath the small arm for the 111w type. For adjusting the bobbincase opener,which might not need adjusting look @ # 24 in this manual.http://www.consew.com/Files/112347/PartsBooks/227R-2.pdf You need to have the plate on when adjusting it & it always needs alittle gap even when it's pulled all the way counterclockwise,I've seen people adjust way too tight & it'll bind the thread. We have a nice easy to operate 3/4HP servo motor w/a dial speed control that will work real nice on this machine. The cloth is probably there to hold oil in the bearing,it isn't needed & can be taken out,i've never seen anything like that & have worked on 100's of these over the yrs. The hole to the right of the screw is for oil.
  13. We have them in Organ in sizes #21,22,23 & 24.$4.00 a pk of (10)+ shpg
  14. Ok,Patricia the 3300 is good on lightweight & thin canvas,it inot good on leather as the feed dogs & feet will mark of course the teeth can be ground off on the feet,but you still have the feed dogs marking the bottom.The Pfaff is a good machine except parts,feets & etc will cost more than 111w,the way the bobbincase is it'll run larger thread easier than the 111w will .
  15. Yes,it's an early one before they made the beam improvement on the top & is the back open on it? Google "Singer UFA" for more info.
  16. Don't worry,the casting can take it,I've straightened out a lot of them over the years.Just turn it slowly,find the exact high spot & give it alittle push,just alittle @ a time.
  17. Here's a few things to check #1 check the needlebar thread guide,take a short piece of thread put it through the needlebar thread guide & pull it back & forth & see if it gets cut or shreds,also how does the hole in the feed dog look?Alot of times it can get chewed up from needles hitting it.Last check the bottom of the inside foot for a groove ,this can cut thread too.Last thing when you loosen the needle when you change it does it have much play left to right when you tighten it?There more but start with this.
  18. Get a long piece of pipe & try to straighten the shaft.Alittle wobble won't hurt(LOL)BUT if you have to replace the shaft get one from another machine will be a lot easier.The big cam on the rightside is set @ the factory for that shaft & machine.They adjust the timing & hold it & test sew on on it until it's right & then,it drilled & pinned.No 2-shafts will have this hole in the same spot.So if you can find a shaft w/a cam that belongs on it will be best.If you have to drill another hole in the shaft to get the correct timing you'll weaken it.
  19. A small screwdriver would work to push on the latch.Yes,Singer did have a special tool that the machine came with BUT you do not need it .
  20. It seems like the shuttle would have to almost float free for the thread to pass. Billy,Yes that's what happens on all lockstitch ,the loop of thread goes on both sides of the shuttle on the 29's & around the bobbincase holder & bobbincase on other machines like on your Consew 206 Look at this; https://boingboing.net/2016/02/10/how-a-sewing-machine-works-gi.html
  21. Looks great, can't wait to see it finished.
  22. Nice,a person could get real artistic with aluminum & leather.
  23. Do you know if you push on the reverse handle when you make your stitches shorter it relieves the pressure off of the knob .
  24. It is a spring loaded jump foot.Singer did make some 7 class with a driven foot but with the way the mechanism works it limits the foot lift..
  25. You should try googling ,Jeep off-road forums ,there's a lot of them where you can find what you need to know. Hope you keep the greasey side down!!
