CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. My eyes were looking @ the machine & missed the heater LOL!
  2. The story I've been told is they couldn't get enamel paint during WW2.
  3. Looks good.Have you ever had a problem where it didn't wrinkle ?I've painted a lot of them & found it wrinkles better if you warm the machine up.I used to put a heat lamp on the base & cover the head with ali foil to hold the heat in for 3-4 hrs,OR if it a hot summer day will work too.
  4. It's a high-speed garmet sewing machine for sewing shirts & dresses.NOT for leather at all.
  5. If the stitch is that long your lucky,because the max length on the newer models is only 7 pr in.The part that gets worn is called a bell crank lever,I call the part a tongue it's part #8167 & fits in the ring part.All the 29-4 parts are the same except the hand lift lever AFAIK.There's a hole in the ring of part#82053 that needs oiled once in a while to prevent this from getting wornout. Here's a 29-4 parts listhttp://parts.singerco.com/IPpartCharts/29-4.pdf Here's the operators manual f/a 29-4 29-4 Parts List from Singer.pdf
  6. On my 34K11 it has the upper arm of a 45K & has all the upper parts of it.It has foot # 82513 like a 45K25 has ,I've seen some of the 34's will a smaller 16,17 class upper arm on them too.
  7. Chris, You need a welt foot for that,I do have some in stock for the CB3200BUT a 1206 with a welt foot would do a better job in something that thin.You probably want to use a #69 thread for a finer looking stitch?
  8. It should work great,just don't plan on moving anytime soon.LOL
  9. Well it's a double needle so it has a wide foot on it because of the needle.I suppose there's times when a double needle would be handy on making straps(as long as it has a wider guage 3/8"to 1/2" in it) but when you take a needle out to use a single needle the wide foot will be in the way.
  10. Hey Colt,Looks Great.I'd quit selling machines if I could make leather look that purty!
  11. Great Deal !! Yes.it will fit,we've even put the stands in smaller vehicles like a Honda CRV.
  12. Maybe the hook guard(metal under hook) is hitting the needle causing you to move the needle a little too far left.
  13. If the screws the hold the hook saddle in position aren't tight enough it will move do to the force of the gears as your sewing.
  14. I always recommend using the clear sewing machine oil.It has no additives so it won't stain the material.Grease isn't good to use even on the gears of most machines because it'll dry up after while & the lint will stick to it & build-up.The clear oil takes most of the lint with it.Just one drop everywhere otherwise you'll have dripping & them not want to oil for awhile. It's best to wipe the oil off of the foot & pressure & needlebar after it's been setting ,before you start sewing& you might even leave a towel under the foot so the feed dogs don't get oily while setting.
  15. Maybe this will help?
  16. Looks so nice I'll bet you won't want to use it? (Might scratch it)
  17. It will depend on the leather but it should sew just a little over 1/4" maybe 5/16" & uses thread up to size #138 thread.
  18. I recommend 138 as the largest for this machine.
  19. On the last pic it looks like it is just some metal burrs from sharpening that could be taken off by running your stick on it.
  20. You could send me a PM here.
  21. The smaller machines like the Consew 227R,Singer 95,96,241 & etc have rotary hooks that were designed for higher speeds & thinner materials were the smaller thread is used.Machine that use the larger thread are slower running & the barrel shuttles have larger clearances that allow the larger thread to be used.Also the smaller machines can't use thick thread it takes a lot of adjusting the get a big machine to use thin thread.
  22. Hello Jeff, That's a great looking first sheath there.Since your not sewing that thick you might try loosening up the foot pressure a couple of turns that will lessen the marking.(The black knob on top)
  23. Great looking setup you have there! 108's are great binding machines.
  24. This machine looks like a Singer 34 & has the same type of shuttle that looks like a patcher only larger than the big bobbin 29.It has to spin for the machine to sew.
