CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. If you go behind the machine,,open the plate just to the left of where the foot lift chain fastens on.
  2. From your pics it looks like a standard onmodified 72w19.It is made to sew real thin materials like chiffon & fine tapestries I don't know what they would be doing with this machine sewing shoe uppers.
  3. Here's an Adler we welded with electric & nickle rod,we ground the welded part thinner,pre-heated welded an inch peened it ,kept it hot & weled more & it's still holding after 10yrs. welded Adler.pdf
  4. I would recommend(for future reference) if you use #207 on top to use #138 in the bobbin,it is hard for these machines with this type of hook to pull the bobbin thread into the material for a better looking stitch,so the smaller thread is needed in the bobbin.
  5. Yes,it does hemstitching,you might want to look on utube for some videos.We do stock needles & bobbins for them.
  6. Try turning the screw the other way,it's left hand threads.
  7. Hey Bob,Ok thx for the definition,your right it does have quite a bit of mass too! But to me the "flywheel" is aka the handwheel, it is quite a bit heavier & didn't want anyone to misinterpret it which one you meant!
  8. Wasn't that bearing in the speed reducer?
  9. Yes,you can by adding a piece of plywood underneath the back of the table(where the head mounts & run the motor belt to one of the pulleys underneath ,disconnect the treadle rod off the bearing & add a piece to it to connect to the motor. Probably won't any sense to you until you get a motor in your hand & then you should be able to figure it out .
  10. Ok,we had some that chattered @ low speed something like the OP.
  11. @Wiz,didn't some of the servos I sold you yrs ago with the digital readout do that?
  12. The 135x17 or 135x16D (for leather) are the same length as the 16x99 & 100.I can't seem to find any welt feet anymore BUT do have some standard flat feet in stock. Have you seen this yet?http://parts.singerco.com/IPpartCharts/78-1.pdf
  13. The problem with alot of the older needles is the eye in the needle are smaller than the newer ones,so you might have to bump up a size or two so the eye of the needle is large enough for the thread you want to use.The easiest way to check is thread the needle through a piece of thread & hold it vertical & see if it slides down the thread w/o hanging up,if it does then it'll work.
  14. Yes,the Consew 205 is the same as this except the 337 doesn't have an oil pump.We used to sell these years ago ,be careful not to jam it up,unless they've been replaced(which they probably have by now)the hook gears tend to break pretty easy . y
  15. Here's the screw you need to tighten just a little at a time until it holds.
  16. Yes,it would be good for lighter leathersup to 20 oz.,about 10yrs ago I bought 20 of them from a warehouse & found it they hold up a lot better than they look.They take standard needles,bobbins , bobbincases & feet.
  17. Yes,it was a spring loaded foot that walks back with the feed dog & then the spring piushed it forward as the needle pulls out of the material. It should sew over 20 oz of leather 5/16" depending on the leather. Yes,you can put a servo on it. We do stock a lot of parts for it too.
  18. I did similar to what Dwight.I built a 30x56 building w/large rollup door on leftside,small 36"door on right w/one window on the front & 2-on the sides & built a 14x40 shop inside of it w/6"insulation on top & 4"sidewalls,I have a gas furnace(50,000 btu) in it,but this winter I put a small electric(look like a radiator heater) set it on low & it keeps the chill off & prevents condensation.What's nice is the storage on the top of the room.Oh,and I put a sliding door on the side 7'x8' in case I want to work on a car.
  19. Some leathers do this more than others & a smaller needle & thread would make it look better since it will slice through with less force.
  20. Wiz,I hate to hijack this thread but since needles came up I been meaning to ask how you like those 135x16 S points I sent you? I think the stich would look real nice on wallets?
  21. You can loosen the pressure on the foot & buff(sand) the feed dog,a smaller pulley will help slow it down.Here's a needle & thread charthttp://www.tolindsewmach.com/thread-chart.html
  22. Are you sure your going around the 2nd tension on the side 1& 1/2x?
  23. Maybe I should of added to just put it in the bearing or bearings that might be gummed up as it will dissolve the old oil.
  24. Some WD40 or some other type of penetrate will or should cut through the old oil,then use regular sewing machine oil after that.
  25. Oil all the way around the groove the bobbincase sets in,then you should be able to turn it counter-clockwise to get the thread out,once in a while you can use a screwdriver & tap on the tab lightly to break it loose,(counter-clockwise only).
