CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. You mainly need to lube the thread For 3 reasons I can think of is when your sewing real fast,it helps cool the needle so you don't burn the thread,#2 if your sewing dry & or old leather & #3 is when the leather is real thick or if your thickness close to the max for your machine it prevents skipped stitches.
  2. Yes,Joe is still servicing machines,I meant blow air in the needle screw hole.The soldering gun might help too.
  3. Blow some air in the top hole sometimes gets them out.
  4. I just sold a CB4500 yesterday to a customer that bought a 3200 a year or so ago & he got into heavier sewing than what the CB3200 could handle & he wants to sell it,He's in VA by DC.If your interested give me a call or message me for his ph#,I don't want to post it here.
  5. Ok,I just got back from Weavers & bought 32 machines!But I'll be in tomorrow.
  6. Nice looking machine you have there,you have something to be proud of.
  7. Hey Jeff, Thanks for the kind words,glad you got it so quick. We do as hard as we try not to make a mistake once in a while like anyone can BUT we work on them & TRY not to do it again. Thanks, for your order. Bob
  8. Oh,one thing about the 1000h is they only come in a round point,the 331LR only comes in a twisted leather point.
  9. I'm not @ the shop & can back to you tomorrow w/a measurement since we have them in stock.If I remember correctly they are 3&1/4" long.
  10. That's what happens when you make something you noticed all the little mistakes.I had to go back & look @ it again to notice it.LOL!
  11. Hey Gary,Great looking job there.
  12. It's a Rex 26-188 a copy of the Singer 16-188 on the Rex has reverse.Yes it's good for upholstery,canvas & thin leather.Most parts & feet are still available for it.I guess the price $3-450.00 BUT you'll probably have to buy a servo motor so you can control the speed approx $135.00
  13. Your Welcome.Glad to know you got it fixed.
  14. Look for this screw behind the back cover & tighten it just alittle.
  15. Ok,so the only cam to adjust for the hook is the one on the left that takes a 6mm.IF it isn't correct you turn it one way & will notice it'll get closer or further away from the way it's supposed to be.
  16. I hope you can understand this,i'll try to explain this the best I can.The cam on the top shaft for the shuttle timing needs to be adjusted so that when you turn the machine & the needle bar is all the way down the shuttle is all the way back & coming forward just as the needle bar is coming up.Now when you do this you need to run the needle bar all the way down & watch it come up & then turn it backwards so that when the needle bar is all the way down & you turn the handwheel 2" either way it stars to come forward a the same position when the bar is all the way down.It helps to put the stitch length on 0.
  17. Welcome to the site & don't forget to post some pics.
  18. Looping is almost always upper tension.Double check that you have the thread wrapped around the second tension 1&1/2x. It's looping because the upper thread tension is too loose.
  19. Yes,it is a nice looking machine BUT the price is about 2x what it should be & the biggest problem for this machine like a lot of the older ones is getting parts,we do stock needles & awls but that's all you can buy for it.
  20. Probably knocked the clutch out,push the button the the rightside of the bed down & turn the handwheel backwards should get it sewing again.
  21. If you want to sew over a 1" you better get a 97-10.The Singer 7 head needs to be cut under where the needle comes out & a longer than standard needle is used.For the reverse we took all the stitch length parts out & had a special bracket made that goes out the back & also had to heat & bend the feed back to make it go back in the same holes,which was hit or miss because the feed dogs might not get a good grip causing the length to vary.That is the advantage of a walking foot needlefeed.
  22. How thick is the leather?Sometimes to large a thread gives you problems on thinner leather because it isn't thick enough to hide the knot.
