CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Ok, now my $0.02. It appears to me that the needle is in backwards,you want to long groove on the left & the notch above the eye on the right.
  2. Back when we sold them all you could buy was the Adler 205-370 f/$5,000.00 & we sold these f/$1,850.00,it might be a good way to get started.It's priced cheap enough too that you'll never get hurt.
  3. Yes,it's a workhorse BUT it's more suited for webbing & canvas since it has feed dogs in it & the feet are awful large too.Years ago we used to rebuild a lot of these & even modify them to sew over 3/4" & also used to put reverse on them.I think this might be one we worked on since it has a thread lock the same handwheel on it & we used to paint them gray.Some of the parts are getting hard to find.Since the 441 style sew with better looking results we stopped selling the Singer 7's years ago.
  4. You would need to buy extra ones if you want to use them because you can't buy parts anymore.
  5. You have to get the notch & finger back in place & then rock the handwheel back & forth & it should unjam . Put some oil in the area where your finger is pointing,that will help it unjam easier. Also be sure to hold on to your needle thread when you start to sew(first 3 stitches) esp w/the larger thread your using.
  6. Yes,they called BUT it's very heavy to ship(costs $145.00 by UPS) & cost a lot too.We used to gave the lower priced ones like in the pic & probably should get some on the next order.
  7. NO,it won't work,the gears for the 29K51 are real fine teeth & haven't been available for over 40 yrs.
  8. Yes,that is a real nice stand!
  9. No,that's a portable Consew,it has feed dogs & feet w/teeth that will mark + it isn't the type of machine you would want to use for eceryday sewing.
  10. Great Pic! Knee deep in shoe repairs! Looks like they are giving the good old 29-4's a workout!
  11. http://parts.singerco.com/IPinstManuals/132B26.pdf
  12. You might want to take the tension plates apart & look for dirt,old thread or grooves on them.
  13. I've bought,fixed & sold quite a few of these over the years & back in the day they were a great machine but gave on up on them do to the lack of parts. They do not have a tension release like most machines so you have to pull some slack thread from the take up lever then when you lift the foot you won't bend your needle when you pull the leather out. The pressure foot tension is the large screw towards the right of center on the top of the machine.Look on the backside & you see a long horizontal flat spring about a foot long & you'll see where the big screw pushes on it. The part you need is called a needle guide,there's 2 of them for different sizes of needles they are # 58874 & #58910
  14. The upper shaft has a threaded end on it & a lot of times the threads get broken,BUT you can stil push the shaft all the way in & turn the scres from above to change stitch length as needed.
  15. I've never seen one,nice looking machine though!
  16. Well I was thinking since the feed dog doesn't go down as it goes foward & you have just the left toe foot on when the inside foot goes up the outside foot goes down & the feed dog goes foward the top left edge of the feed dog is being pushed into the leather underneath.The only fix would be to round off the whole edge or top corner of the feed dog.
  17. Is the marking worse or only on the leftside of the needle?
  18. Good choice & great price.Now the fun begins!
  19. Your welcome Steve !
  20. You might want to pull it out,it could be bent on the inside.It's been quite a few yrs since I worked on one so I'm alittle rusty on them.
  21. Juki 441
  22. The linen or cotton thread with lube(we've even used sewing machine oil) is all that will work,the nylon doesn't make a good loop & gets caught in the needle eye when sewing.You probably need to put some wax cleaner or kerosene down the shaft where the cast-off runs in, it might have some old wax in it & then oil it too.You could have a weak spring too.
  23. I'd go with the Pfaff first,then the 111w it'll sew smoother & better since it has a slightly larger & heavier handwheel than a 211 which is more for canvas & upholstery.Both are good machines BUT a few of the 211 parts are getting hard to find where 111w parts are all still available.
  24. Take some #138 thread with you & try before you buy it,I'd say it's the max size thread that it will handle.
