CowboyBob
Contributing Member-
Everything posted by CowboyBob
The plate on a Pfaff has a hole in it to put the oil into this wick area.
Yes,they are there to hold oil & release as needed,this area of the hook spins around & the other part is stationary so it needs a drop of oil everytime you change the bobbin but in factories @ higher speeds it's good to have oil there all the time.All these Pfaff hooks are very expensive so they don't want them to wear out.
Juki/Ferdco "Bobbin Case Spring"
CowboyBob replied to JerseyFirefighter's topic in Leather Sewing Machines
Yes,all the Cowboys we sell CB3200,3500,4500,5500 with that type of hook come from the factory with that spring in them,that's why we carry them because they do fall out once in a while & people need them.When you get one you can pinch the inside coil together alittle & make it fit tighter so maybe it won't fall out so easy. -
Some old motors will start backwards,just spin it counterclockwise when you start it to get it spinning the right way.
I recommend #138 but know of people that use larger but it will tend to jam easier when you go over 138. What's that motorcycle you have?
Yes,they take the same feet,bobbins & needles as your 111w,the only difference between the W & K is K stands for being made in the UK & the W machine was made in Bridgeport,CT.Give them both a real good lube job & try to sew on them & see what happens & yes,that stand should work for you too.
I once made up a treadle stand with a 111w100 needlefeed for an Amish customer that wanted it to sew belts & it didn't treadle real easy sewing the belts.Your 211 will have a smaller pulley & might work better. That stand came out real nice!
Odd Neeple Tips & KOOLTORR Needles - WFT
CowboyBob replied to Constabulary's topic in Leather Sewing Machines
They are for High-Speed sewing esp in denser material that heat the needle. -
If your machine has a small handwheel under 3 1/2" go with at least a 3-1 reduction,we use a 4-1 on our box style & it works great,other people have also made reducers from the old-style belt driven grinder arbors. arbor.html
Here's one we had made up with a 2"small pulley & a 8" large pulley,they work great! I've seen pulleys like this in clothes dryers that could be adaptable real easy.
Yes,Max is right it's like a DU-214H also look up Nakajima 280,WMC used to sell them using that Mercury name. I just found the old price sheet from 1994 & we used to buy them for $450.00 for the head & always bought extra gears since the ones the factory put in them usually broke soon if they jammed it up.It has a large-bobbin,walking foot & reverse.
If you lift the foot up & push it front to back how much play does it have?However much it has is causing it to not pull the feet front to back making the stitch shorter.It's a very common problem with these machines.Part # 82167 has a little tongue that fits in a groove of #82053 & gets worn.
Yes,we have them priced @ $160.00 BUT sell them @ discount & have never sold one @ that price.Cowboys plate is stainless steel,most others are chrome plated & the chrome peels off after while.
That's a great deal,your very lucky usually when the put the motor on they throw the treadle wheel in a corner & it probably ends up thrown away.We get people calling all the time for them! Nice looking machine for the $$
No,trust me on this one,I would doubt if it would handle # 69 thread & it won't ever sew as thick as a 31-15.It was one of Singers 1st high-speed machines for garment factories.
Singer 45K - Unsual Needleplate + Feed Dog
I worked on a lot of 45's over the years & have never seen that one.It might of been custom made.I'd say it's for sewing a narrow strap or ?? it looks like 6-8 mm from the needle hole to the rightside? -
Have them tilt the head back to drain the oil out of the head before you get there.Then take a funnel & a container that holds a quart to drain the oil from the pan.Then like Madmaxx said take the head out & when you lay it down in your vehicle put it on the backside because if you lay the front down you can break the take up lever & tension. Also lay the table on the backside & it'll slide right in most SUV's or pickups.
No,too long & shank won't fit in needlebar,use 16x2 for leather they are shorter,use 16x257,231 for cloth & vinyl.
Alot of times the cork dries out,we have always told people to smear about a teaspoon of grease on the clutch pad & run the belt as loose as you can!
Yes Sir,Colt your doing a great job on them bags!
Juki DNU-241, Consew 206rb, request for advice
CowboyBob replied to pattyharrington's topic in Leather Sewing Machines
Uwe is correct it will tend to give you problems with #207.We used to sell them new years ago & had a customer come in wanting one for nylon halters & using #207,I showed him what we had & he didn't want to spend $5,000.00 on a new Adler & pointed to the Juki 241,I said we can try the thread & see what happens but I didn't recommend it for a long term.He says just to get started then go to a bigger machine,I told him he pushing it & might have problems.We I sewed on it ,it worked great.He bought it & was back in less than a week,he jammed it up.I guess he didn't hold the thread.We fixed it & showed him again how to hold the threads when first start.He came back maybe 3 wks later & broke the hook on it.So now he starting to understand what I told him & bought a Singer 97-10 for the large thread & kept this for the chaps & thinner sewing. Moral of story it's best to get the right machine for the job your doing or you'll end up spending more later . The only problem with the model 241 is it doesn't have a bobbin case opener like Juki's newer model 1541S has & that helps prevent the machine from jamming up esp when your using large thread otherwise when you use #138 or thinner on this machine it should give you years of trouble-free service.- 24 replies
- juki
- consew 206rb
(and 1 more)
Most of the questions are answered here.http://www.tolindsewmach.com/cb2500.html
Pedal for Servo Motor? Mine is missing.
CowboyBob replied to Ian1783's topic in Leather Sewing Machines
Yes,there are pedals that fit that style of leg. -
I've never done this on the 107 BUT you could drill a hole in it to use the #12361 hinge pins,I'm pretty sure there's enough thickness there to allow for a hole,it would easier than modifying the table(which I've done before & it doesn't look pretty)
Hello, I haven't seen that plate...YET ! LOL
