CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. The roller foot that everyone buys for the 31-15 was standard on some 17 class,like 17-30 (I think) that have a higher shank,that's why you have to raise the pressure bar to install it on a 31-15.If your doing designs where you need to make tight turns the smaller roller works better & the larger roller is what the shoe people like to go over seams.
  2. Yes,you loosen the 4-bolts,it helps to have someone holding onto the table top so it doesn't drop all the way down.
  3. That's a great way to change a belt,I always would take the nut off & do it the slow way & then adjust with the washers!
  4. I would much rather have you call than fight a problem that you don't know or understand how to fix! Looping underneath is usually a threading issue,you need to make sure you have the thread wrapped around the 2nd tension 1&1/2x,also ALWAYS hold your needle thread when you start sewing the first 3-4 stitches so it doesn't loop underneath too.Many times when it loops underneath people loosen the top tension thinking it's too tight when all it was is the threading or not holding the needle thread.
  5. If I don't answer it's cuz I'm talking on the phone ..so leave your ph # & I'll call back ASAP !! Thx
  6. They called me towards the end of the day yesterday wondering why the belt pulley was turning & the machine wasn't.I asked them if they were sure to line the 2-bolts in the grooves before tightening the handwheel,she didn't know.Apparently it wasn't.All these larger machines are shipped w/the handwheel off.
  7. The belt tension is pre-set,so it's best not to loosenthe reducer or motor.Just take your hand & start pulling the belt off on the back & turn the handwheel towards you & it'll slide off,you can also roll it back on the way by starting it on as far as it will go & trun the wheel towards you.
  8. Yes,the split threads on the upper tension got pinched together alittle & the nut won't grip it good enough now.If your real lucky you might5 be able to pry it apart to work,it might break but it needs replacing anyways .You probably aren't getting enough upper tension so it loops underneath.
  9. I shoulda asked you what have you done to the machine?? But you can see the difference now.
  10. Since there's no electronics involved a simple one is real easy to make.I made one for our Bridgeport mill yrs ago & it still is working.All you need is an old 3 ph motor large than your motor ,run 2-110 v separate lines to it & continue on the the clicker motor.Then we hooked up a starter motor that spins the convertor motor.So we get the starter motor spinning first ,then turn the 220 on ,shut the starter off & the 220v convertor motor keeps running & as it runs it puts out the 3 phase.This does only work w/Deltawound motors(for the convertor).But the spare motor we had laying around just happened to work after we got it wired up. PS. I did try a static convertor w/condenser in it & had some much power loss it wouldn't work,did an online search about convertors & found out about this.
  11. If the hook screw isn't tight it won't pull it down enough to clear the arm.If the machine binds up with it tight you must have some old thread or dirt under it that needs to be cleaned out.
  12. With #69 thread it's 48 yds,#92 is 35 yds.
  13. New belts will shred sometimes until they get the coating worn off. Yes,hold on to the threads(esp.the needle thread) to first 3-4 stitches,towards the back or rightside. On the bobbin thread you will probably end up knowing afterwhile how much you can sew before it runs out,but for now you'll just have to pull it out & look @ it once in a while.
  14. Yes ,a #26 is the correct size & when you thread it make sure you go around the 2nd tension 1 & 1/2x,Also you will probably need to tighten the upper tension for this 346 also.Also did you hold the needle thread for the first 3-4 stitches?
  15. I'm glad to hear you got it out.
  16. No, no hole all the way through,best thing to do is take the needle set screw out & blow air the screw hole.
  17. Have you taken the end cover off(needlebar end) & oiled everything lately?
  18. There's some 281 parts manuals here http://parts.singerco.com/IPpartCharts/
  19. I set a needlefeed 111W up once for an Amish guy that wanted to sew belts & worked but was pretty hard to treadle ,we stuck a walking foot 111w in the stand & it really took alot more foot power than the needlefeed.The walking foot 111w has alot of resistance going on when it walks it makes it hard to treadle.The older mchine like 29 & 42-3 have large wheels & the walking foot works different & they will spin & go around -3 x when you do it if they are oiled good.It might help a 111 treadle easier if you could find a heavier handwheel w/a small pulley.One like what's on the 42-5.
  20. No,it won't you need a Juki 562,563,Consew206, 225,226,Singer 111w155,154,153 will all do it much better than a garment machine.
  21. Do both of the machines have the same amount of tension on the check spring?(The one that moves while your sewing)
  22. Which bobbins are you using,I've had people w/the same problem that bought cheap bobbin off flea-bay,they were out of round.Try pulling on the bobbin thread n& see if there's any tight spots.
  23. If you want to nice looking straight stitch use a D point,if you want a hand stitch (zig-zag) look use the LR point.
  24. Singer had an oil can that would set there.
