CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. I would need to toss a coin to decide between a 66 or 500.I guess if you need zig-zag keep the 500,if you need $$ the 500 will bring more then you'll have a straight stitch left.It seems though that most people that sew end up with extra machines & like to keep them for backup. HTH
  2. Yes,it's a big heavy machine that is used mainly on nylon webbing because it has big feet with teeth on the bottom & a feed dog that pulls the leather through it'll leave some nasty looking marks as you sew.
  3. You could paint the edge & of course if you want it real nice you'll could get some wood putty & fill in the slot & sand it smooth before you paint it.
  4. I'm not saying this because I sell them BUT a servo is the best way to go.When you use a clutchmotor you have to learn to pump the pedal,meaning once the machine starts sewing you need to leave up or else it'll take off,a servo runs a lot like a home machine when you press on the pedal & starts off slower & doesn't get away from you.
  5. No,you don't want the belt to slip,adj it so it has 1" of play,a smaller motor pulley 2" will help too.
  6. Yes,it will stop the grabbing & taking off,make sure too that the belt isn't too tight.
  7. Here's the cure for a grabbing clutchmotor.Take the 3-screws off the end of the motor that holds the clutch on & smear a teaspoon of vasoline or wheel bearing grease on the flywheel & re-install the clutch & end of chatter.
  8. You could probably do some upholstery easier if you ground off one side of the foot so you could get closer to the needle.
  9. I'm thinking the same the military would throw it away & since we are talking over 50 yrs since they've been made I really doubt you'll find anything.
  10. I've never seen one because it wouldn't feed properly since only the top foot pulls the material.When your sewing upholstery you'll be sewing at least 4 plys of material & it'll shift with just the top feed.
  11. I thought it might of been inverted but look @ the woman in the middle of the pic,if it was an inverted pic she should be on the otherside?? The handwheel on this machine is on the left?
  12. That's very interesting pic because I've never seen a Singer 11 class left-handed before.They have the center handwheel on what is normally the back & even the walking foot parts are on the other side.
  13. Don't forget when you sell something to include the price in the ad.
  14. No,I don't think you want to strip it!! You need to fix it !! If you take the race off (it's held on by 2-screws) there's a screw on the back that holds a u-shaped spring & it holds a ring on,take it all apart & clean it,put it back together & see if the side play is better ,if not you need to buy a new race.Over here they sell for $20.00.Someone has adjusted the needlebar to take a longer needle,if you want the 16x2 to work loosen the set screw on the needlebar & lower it so the needle is just below point of the shuttle point as it passes by the needle as you turn the machine in the direction that it runs.
  15. These are just like a 31-15 machine.you can use 16x2 leather points,or 16x257 round points.all the common parts interchange with 31-15.
  16. We have a customer using the long-arm 2-machines w/o reverse & they have a foot pedal lifter they lift the foot & pull the tarp towards them while sewing.It sure wouldn't look pretty in leather though.
  17. Darren,the problem with this model is Ferdco made some special parts for it & it's a needlefeed w/a jumpfoot that takes a special foot that only a Ferdco like this model takes.The more common parts aren't a problem I've ordered parts from Consew for people in the past, the machine it was modified from is the model 754R.
  18. When your @ o-stitch length the feed dog needs to be centered (front to back) yours is too far back.
  19. Here's a Singer 98-3,which is built similar to a 97 that was made for recapping tires (in 1915)
  20. Yes,the 95-1 has that belt,there is someone making the belts now.I have seen them on ebay.
  21. We had a customer buy a long-arm double needle with the hopes of using it as a single.I tried to explain to him how it would be awkward & hard to use BUT he thought the one machine would do both his single & double needle work.He even had Tennessee Attachment make some cording feet & zipper feet.The poor guy dumped a lot of $$ in this & then after about a year called back & let me know I was right.Then he wanted to sell it back to me because he's getting out of tarps & just doing upholstery work.I sent him a few people wanting it & I guess he finally sold it.
  22. Great looking belt !!
  23. l2bravo, It's been reported to me that IF you talk to your machine nice BOTH when you make your sample & when you move on to the finished products you'll have much nicer results!!
  24. Great !! Give us a call if you ever have any questions.
  25. The 1000H are approx. 1/4" longer than the 97 needle so they can be shortened to work.We have some in stock in #26 & 28 & they only come in a round point.
