CowboyBob
Contributing Member-
Everything posted by CowboyBob
You might have it threaded wrong or else the TOP tension is to loose.You need to wipe off the foot & foot bar b4 u start sewing w/a paper towel after oiling.It's best to leave something under the foot to catch the oil.It will stop soon.
Singer Needle Bar - I Could Use Some Help
CowboyBob replied to Constabulary's topic in Leather Sewing Machines
The 16,17 & 18 should all be the same since they are all like a 16 class,the 31 bar is .283 & 91/4" long,the 17 is .283 81/4"long ,the 96-80 is .250 ,6" long Let me know if you need info on anything else. -
Uwe,that is a Pearson,not a landis#1 in our showroom.We do not have any Landis#1 parts or needles.
I'm glad to hear ur making some stitches.The spool isn't supposed to spin.You are supposed to pull the thread off the top of the spool so it doesn't have any drag.
There's 4-screws that fasten the head to the stand,take them out & it's a lot easier to go up steps with.Also less prone to breakage in transport.
You can't on most Ind types you wind the bobbin while sewing,that's why the threadstand holds 2-spools.
Cowboy 3200 - Thread Wrapping Around Bobbin/shuttle
CowboyBob replied to GaryNunn's topic in Leather Sewing Machines
Gary,A problem like this is almost always a threading issue.Is the thread through 2-holes in the spool pin on top?This puts alittle pre-tension on the thread to help it stay in the first tension as your sewing and are you sure it's wrapped around the 2nd tension 1 & 1/2x ?- 6 replies
- cowboy 3200
- problem
(and 2 more)
There's a screw in the center of the wheel(look from the outside) rightside, that is probably holding it on.
Techsew 5100 Thread Tension Issues- Stiff Veg Retan
CowboyBob replied to TinkerTailor's topic in Leather Sewing Machines
Try #23 needle w/207,are you using the S point? -
You might be able to loosen the foot pressure knob on the top left hand corner of the machine will help,these marks can also be rubbed out w/a spoon.Be careful you don't loosen it too much or the machine will start skipping stitches.
When you turn the machine backwards it's possible to jam the thread up in the hook(bobbin case) it won't happen everytime & you might need to turn it backwards alttle if you over run when you wanted to stop.The main thing to do & try to always stop & start with the take up lever @ the highest point.
Yes turn the speed up a little,on some of these motors when you turn down the speed it reduces the starting torque .
Any oil is better than no oil.
Years ago when I first started repairing sewing machines my neighbor wanted me to look @ his mothers machine.I went there & it was a real old White treadle machine.So I looked it over oiled it,threaded it & started to sew & it started getting tighter,so I oiled it again & then it tied up & wouldn't turn.The she started yelling to him in Italian & he started getting upset w/me saying she thought I ruined her machine.I didn't know what to do so I said let me take it with me & fix it.She didn't like the idea but he convinced her it'll be ok.So I took it to work & told the old mechanic what happened & he just started laughing & thought it was really funny.Then he said that's what happens after years of 3 in 1.It builds up a waxing shellac type of crap in the bearings & when I oiled it it expanded & tied it up.He said take to kerosene & put in the bearings,so I did & it freed up.Took it back & she was smiling when I left.So after that I don't want to think about using 3 n1 on anything.ATF,motor oil,gear lube isn't good for most machines either,if it drips off the machine onto what your sewing it'll stain.It is best to use clear sewing machine oil or mineral oil.Even then if someone has used the wrong oil n the past it might stain for a while until it gets worked out of the machine.
Bobbin Winder #3 Tinker Edition.
Wow Tinker that looks great! Here's our not so fancy setup a 12-24 screw w/a nut on it about 2&1/2" long and a drill.We often need to wind different sizes so this works great for us. -
Nice looking machine.The 16 cl needlebar #2050 is 183 mm long -
I just thought I'd show these machines off. The smallest one is Singers first model of Industrial Machine & then in later models they had a longer arm,The longest machine is a model3-1,the shorter one in the middle they called standard.All 3 models used a wooden pitman arm to run them instead of a belt.I do have the treadles for them & they don't treadle real easy.
Yes,the singer 16 is .285 BUT the 34K we have here measures .373 & is like a 45K upper arm?I noticed yours is a SV maybe that's why? -
Quick Question For Anyone With A Singer 95 Or 96 Class
CowboyBob replied to Marcusstratus's topic in Leather Sewing Machines
Turn up the radio,the gears always make a noise on these machines. -
Adjusting Presset Foot Tension On 206Rb-5?
CowboyBob replied to jk215's topic in Leather Sewing Machines
There is a hole behind the spool pin on top of the machine that you put a screwdriver in & turn to the left to loosen.If you look @ the back of the machine you can see the long flat spring & where the screw makes contact w/it. -
There's a flat tension release lever on the back of the tension hold on w/2 screws(it's what pushes on the pin),you can bend it towards the pin to eliminate the gap in the pin,then the discs will open.You need alittle gap between the pin & this lever or it'll hold the tension discs open & you'll get no tension.
Chinese Jack Jk-6380 Is It Worth Buying It?
CowboyBob replied to Doru's topic in Leather Sewing Machines
This machine would work great for canvas or nylon webbing BUT both the feet & feed dogs have teeth that will mark the leather. -
Rex 800-2 Blind Stitch Industrial Sewing Machine
CowboyBob replied to dfrancorr's topic in Sewing Leather
It was made for thin clothing type of material like mens dress pants bottom hem.There isn't any use for this machine in leather sewing. -
Yes,you can turn the foot while sewing & sew a circle.
The best & easiest way is to take the long belt from the reducer to the machine off & loosen the motor belt alittle by using the adjustment on it & then when you push the speed reducer down just 1/4" or so it will push real easy then tighten everything back,put the belts on & try it.
