CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. James, Clutchmotors have a feature where you can turn the end & have the clutch arm any direction you want it,if you put a servo on your machine the mounting bracket needs to be horizontal instead of verticle like your is because the arm isn't adjustable on the servos. It probably wouldn't be to hard to make a different mounting bracket.
  2. Constabulary is right there is no way it will even come close to sewing 1" thick.The brand is Union Special,it looks like it might be a needlefeed machine,try searching for union special model# 61200,61300,61400,61900,63400,63900 it's one of these models.There should be a plate on the back with the model# on it.It should sew 1/4" ok.
  3. Ok,now I've seen a pic & have to tell you with that type of hook & bobbin case it is a light duty machine.You will probably be able to use #69 & maybe #92 but that would be it.
  4. If you want the stitch to look nice,I would use a leather point.
  5. The model# is on the oval tag on the front.Constabulary is right on about everything,it looks to have an air foot lift & also a needle postion motor,is the motor 3-phase?At least parts & a manual are easy to get for it.For a manual try 111w155
  6. When you thread your machine do you wrap around the lower tension(one in pic) 1 & 1/2 times? Also the arm you thread through is called a takeup lever & you always want to make sure it is @ the top when you start & stop sewing.
  7. Do a search for Alpha-Sew mini walker,Thompson mini walker,Sailrites are the same machine w/a different name & a much higher price tag do to their markup & promotion of it.They did develop a larger wheel for it that gives it alittle more power.They usually wion't handle thread larger than #92.
  8. They both are correct,keep the Juki feet & other accessories are a lot easier & lower priced for it because it is a very common machine.
  9. I've tried them on heavier leather & they won't sew it,they would make a great chap machine or lighter weight leather for purses & wallets.They have a walking foot,needlefeed that pulls it through pretty good.
  10. The feed dogs are different between them ,the needle plate from one won't even fasten to the other.
  11. Sorry I didn't see your posting earlier,it sounds like a great buy for a couple hundred.Keep it well oiled & it might last another 100 yrs.
  12. This machine is called a serger.It is used for finishing the edges of material.When you look @ ebay it seems like people call anything & everything a leather machine even little hame machines !! This one looks like a Chinese copy of a Singer 81 you might look one Singer site for threading info,it uses 3 spools.
  13. We hardly ever get a used heavy machine like this in.The few I picked up @ auction this summer were in a lot worse shape than I thought when I bought them & beyond repair so they went back to the auction.I'd know I would have nothing but trouble from them.
  14. Hey Colt,Your doing a great job there!Looks very professional.
  15. The only parts you can get are the needles,bobbins & shuttle.
  16. It has a foot that lifts up as the needle goes in the material & then comes down as the needle pulls out & then it swings back with the lower feed dog,it also should have a large heavy wheel & sews easy 1/2" thick.
  17. Yes,we have them but you will have to drill & tap 2-holes to mount it.There is no template either,so you have to line it up, hold it where it mounts & mark it & drill & tap.
  18. It is metric M6x14
  19. We have needles & awls for the Champion & they also fit the landis #3 & 16 BUT they won't work in all of the ASN's,they are alittle larger & won't fit in all the machines so I don't try selling them for ASN.I forgot about New England Needle I know they sell Groz-Beckart & would probably have a better price than Pilgrim.
  20. Try Pilgrim Shoe 800-343-2202
  21. Hey Colt, That's what happens in leatherworking,you end up finding thicker projects to sew.At least if you get a bigger machine you'll have the best of both worlds & be able to use #69 & 92 w/o any trouble on the 206RB & then use the larger #138& up on the bigger machine. It is pretty hard to adjust the big machine to use 69 & 92. HTH Bob
  22. Are you using a leather point needle?I don't know which foot a 2318 takes either but like Constabulary said post a pic & I'm sure we can help you.
  23. & we had a problem with the connecter not holding,so we just stick with selling the leather belting.
  24. Yes,the 206 has a larger bobbin,it is also easier to adjust the stitch length than on the 226.
  25. On these 211's there should be a button to adjust the amount of lift the feet have.It's on the top cover of the machine,right in the middle,it's black & it works like the stitch length,you push the button down & turn the machine until the button goes into a groove,keep holding it down & turn the handwheel towards you to make the feet lift higher.
