RockyAussie
Contributing Member
Everything posted by RockyAussie
  1. Very nice work there @TomE
  2. Sorry to say but I doubt you will get a lot of joy with that. Try just a little metho or isopropyl alcohol and see if that helps to get you through.
  3. This pattern looks to me to be done without any folded edges and meant to be done in a veg tan leather. I would be doing it with 2mm veg as shown in the video method. If you do not have a lot of skill including skiving skills I would not be trying to do with the materials you describe above. I would also recommend not using a double cap rivet for the handle in the method shown. If the straps were to go through the top the rivets would be a lot less able to come apart. If you decide to use the peltex anyway do not allow any adhesion on the outer piece that goes over the top as it will cause all sorts of wrinkling. Glue to the inside piece only. I don't think it shows in the video but I would not do any gluing between the dotted lines on the pattern shown as the top cover section except about 6 to 10mm in from the edges.
  4. This post I did awhile back may help. I did make the jig in it for going over belts but it could easily be made to go over flat leather as well. Main advantage is that it can be adjusted to whatever stamp size you want and hold firmly in position at the same time.
  5. I think you may still have too much hanging down into the area where it will get caught. The other thing I am not sure about is whether the plastic will have enough back weight to stay down firmly. Only testing will show this I guess but be ready for the leather to get caught right at the start. (Its a bitch if it does) Also extra sharp knives help to avoid it but do not always do such a nice cut as semi sharp knives.
  6. Although these pics look different they work the same in that they go either side of the blade and held down by the weight. - Note that some fingers sitting in the middle on the wide gaps may be better than putting in foam rubber spacers as I did in this case.
  7. No not a waste of time at all. You are definitely on the right track doing as you have. Done right you will not need any washers or spacers at all. You will need to make sure you DO NOT have any of the finger low enough to catch on the leather. Cut the groove for the blade up fairly high to enable easy lifting and moving across when changing size widths. I will load a couple of pics of one of my old ones which should help to confirm you are on the right track asap.
  8. Good looking end result there @CdK every little bit helps. Magnet attached screw driver rack I assume?
  9. @1hpThat is a nice neat looking job and looks a lot better than my effort. Worth the exercise either way though. I think from memory for every 3mm extra in height you move the knob one click to keep the same stitch length.
  10. Nice looking job there Patrick.
  11. Another point that seems to get missed is the foot presser adjuster has a large funnel shape in it. Guess why? A couple of drops can work wonders in there. Also some times the adjuster is not exactly straight with the shaft so it is worth checking by lifting the feet when doing the adjustment to feel for any binding. Doing the lock nut on it can also make it sit crooked and bind up.
  12. Quite a few changes I would think are needed. First when you do thicker thread it often needs the bobbin backed to be looser. Try at least a 1/4 anticlockwise turn.(remember the lock screw needs to be loosened first) The needle should be size 26 for that thread and the s point or LR should look better than the d or tri points. If the needle is too small for the thread you will be getting flagging a lot more because the knot is having a hard time getting up in too small a hole. Lubricating the thread with some machine oil running through some foam can help as it transfers to the needle and makes it slip through better which includes making it easier to pull the knot up. The foot pressure marks would be better if the back foot were the double one that goes on both sides but the narrow set may not be the best in this application anyway. One tip I will offer is get a sample piece ready of the thickness you are wanting to stitch and keep backing of the foot pressure until the job starts to lift then take it down 2 or 3 turns. If You need to run the left foot only then you could do as I have done and tig weld a wider base to it as shown in the pictures.The wider base reduces marks by a lot.
  13. Good thinking on that setup.
  14. Just checking if you know the dealers here make a stainless steel plate one that is not all that expensive. I could print you up a good one but I doubt it would be much cheaper.
  15. If you are wanting to do this as a business then this video may help. Skip to about the 5 minute mark to see a machine I have been using for 20+ years with out problems. Because I do a lot in crocodile leather I can not use burnishing methods so the rest of the video is about edge painting. Some wallets I've made can be seen in it.
  16. That part of the setup is a bit silly really. If the fingers were made out of something heavier (3mm or 1/8") and with a longer back section they would not need to be spaced and locked in place. The weigh at the back would let the front part ride against the cutter shaft. I have an old machine like that and to change position I just lift the finger forward and move it sideways to where I want it. 5 seconds to change each finger.
  17. A lot of finishes will make the gold go dull when applied to it. I would get some of the scrap leather and do some gilding on it before doing any the desk top. I suspect the neutral polish would be the safest but good chance you will need to clean the whole top surface first for shine matching.
  18. This video I did a little while ago could help you on this - https://youtu.be/Q3cVOtCNjEg?si=xrCJA5Rep8YEl89Y
  19. I would just check that the gears are not plastic ones as I have seen some models have them and do not last long cutting thicker than recommended.
  20. Sorry mate but I would ditch the buckle as well. Tongues that are flat on the back like that one are terrible to the holes in even the best real leather belts.
  21. Thanks for the info Bob. I found that getting the magnets on and off a pita so I 3d printed up something that makes them way quicker and easier to deal with. The top is wider which allows me to just lift at the side and attach them all together for storage. Also to expedite the lay down process I run a light cut into some cardboard to give me a pattern for magnet placements as shown below.
  22. Hey bob, I am interested to know what sort of module and set up you have running at the moment if you would care to share. These pics below in case you have not seen them before show how I modified the unit I have at the moment. To get better cooling I used a 50mm fan on top of a shroud to allow cooling all around and over the module as well as giving me an easy way to get Z adjustments.
  23. That size sounds about the same I extended mine to as well. First test on cutting 3mm acrylic I had the same problem cutting right through as well. I will have to try running a higher wattage diode soon as that would shave a lot of time on most jobs I think unless the beam gets too much broader.
  24. I cut the outer part with a bandsaw as my diode is only a 2.5watt. You may have a better chance with a 10 watt though.
  25. For what its worth Bob you can get pretty good results with a diode laser. The one i used in this picture is a 2.5 watt done onto 10mm black acrylic about 2mm deep. Black and white artwork needed.
