Handstitched
Everything posted by Handstitched
  1. Forgive me Chuck for I have sinned. When I was medically lazy and couldn't be f***ed cooking , , I went to McSlops and had a burger , a large chips...(sorry, fries) , and a coffee . Sorry I have paid for my sins, I can't see my ..? .....feet ..anymore Theres no ' junk food joints' , tuck shops or deli's where I live, thankfully . The nearest ' McSlops' is over an hour away. Just as well, a food sinner like myself could easily be tempted More seriously, its good to see large corporates doing their bit. Will it work ? perhaps not. One can only hope . HS
  2. O'h dear , quite like that
  3. Which may explain why I can't understand a word they're saying. ' What does a Scotsman wear under his kilt? Nothing, its all in perfect working order '
  4. While I have never used a drill, I have used my machine without thread on occasion on the really thick stuff, like 8 -10 mm . And there are times when my hands get quite sore especially in my knuckles ,a bit of ' Arthur Ritis' setting in I guess, making it difficult for me to use an awl , the joints in my hands also seize up on occasion . Very noticeable when using a rotary hole punch. HS
  5. I highlighted one of the pics: Theres some extra holes. Two near the bolt at the top, and one closer to the adjustable hex bolt . Does it go around the leg for some medieval torture? mmmmnah, looks more like a tool for removing bearings/ pulleys /mechanical something that was fitted with heat??
  6. I googled that, fair dinkum ..... I got no results
  7. Thats just weird. My first thoughts go straight to the tensions, but that looks quite good ? And why only on the corners?
  8. perhaps you're right. It may not be sewing machine related. Looks like a tool to remove/extract ....something serious , looking at the hex bolt .
  9. I always dye the back as well as the top. I use a sealer that doesn't allow the dye from getting onto the clothing. HS
  10. @MtlBiker I use a nat veg tan Torino. The Torino I get comes from Italy. Not sure if your supplier gets it from the same exporter/wholesaler . Some other hides I use is called ' Capri' also from Italy . Quite good stuff. I use the ' Torino' nat veg tan ( 1 -1.2mm) for wallets, custom cases etc. I can wet mould it and dye it myself. Had no issues with it. HS
  11. Yeh I thought the same. Thankfully the local hospital is only 10 mins away . Its a lovely apron, it really is, its heaps good, but its too nice to use. Wouldn't take long for me to mess it up . HS
  12. Thats a domestic machine from memory? Similar to the early Singer domestics . Any pics ? Have you bought one or thinking of buying one ? It'll be a nice machine if its what I'm thinking of. . HS
  13. Well said. Might have a beer for that too with my lunch My ye 'olde Seiko does just that.... and quite frankly, I don't care . The machine works just fine , but the moment I start fiddling with it, I'm bound to stuff it up, I'm happy to leave it the way it is. I have yet to find a customer say to me " your stitches don't line up " . HS
  14. Seems to work OK for me ....and I'm using XP ....don't laugh HS
  15. You may wish to try a rotary cutter . I have the same issue when cutting soft leathers. Unless the knife is super sharp, you can end up ' dragging ' the leather rather than cutting it, so a rotary cutter may help. Get a good one , not a cheapy . I tried that, it fell to bits. But some of the more experienced on here may be able to choose a quality one with out breaking the bank. HS
  16. Anyone near you that makes or sharpens knives, you local hardware perhaps? Perhaps they can help you sharpen the one you have? I've had my groover for quite some years, never had to sharpen it . HS
  17. I've had this bag for many years now, but never really found out where it came from. Its been hanging in my workshop all these years and I just can't stop staring at it . I can only guess its from perhaps North Africa ? I did do bit of research on sort of similar looking bags and it looked similar to a ' Taurareg' bag ( African tribe ??) I saw during my research . Value wise going by the one I saw , is anywhere around $300- $500 . I only paid $10 at a local market. The bag is a one piece leather draw string/strap bag , made from the rear end of a goat (?) turned inside out, and where the twisted leather strap is attached,,it does feel like bones ( from the goat?) I can feel the knuckle ends. The tassels are all hand cut. Its well used and well made, it is quite functional. Nice wide opening. The grain side is on the inside. The straps are not too long or short, I put it over my shoulder . Probably ideal for a traveler . Any ideas ? HS
  18. I'd be doing all sorts of historical research on those, maybe get a metal detector search the area , if permitted. . What type of trains ran on them, any surviving locals or families of the sawmill ? etc. .So much history in old stuff, and history should be preserved for future generations IMO, no offence to Frodos' nephew. HS
  19. I have seen a anvil made from a piece of RR at a leather shop in Perth WA ( closed down now) . It was shaped, down to an ' anvil' point at one end. That must taken some cutting/ grinding . That's a great idea, so I thought. It might be cheaper and less work just to buy one. We do have a bit of a railroad history in my town. I have a few pieces in my workshop " museum" , as I call it. A few pieces of clinker from the steam trains that went through once upon a time, some spikes, and a track joiner . They're all welded these days not bolted. That removed the ' click clack' sound that puts people to sleep when traveling. I miss that. HS
  20. I was thinking the same thing. However, if its machine sewing sheep skin..... good luck . I try to part the fleece as I'm sewing. Sometimes the fleece gets caught around the feet or needle . Have some bubble wrap on stand-by to ' relieve the tension'....in your head. HS P.S. I'm glad its not just me that uses pliers when hand stitching , phew !
  21. For plain belts, no lining. Tooled belts, occasionally some lining, but if concho's, studs or any embellishments are to be used, then I might line them . I have made belts with either Croc or Cane toad. The lining helps to cover up any untidy bits on the back . Well said I'm still proud to put on my old grotty , rough looking frequently repaired stained leather apron to carry on a century's old craft HS
  22. It depends how lazy I'm feeling at the time, and sometimes on the size of the job. If I'm lazy, I just give the thread a little twist on itself , the wax seems to hold it together, or on a small job, I twist it. On a large job, the full length of both arms, thread the needles, & put back through the thread once. So there HS
  23. Here ya go. I'm sure I've posted these before somewhere on here, but anyway. A Seiko STW 28B ,set up as a single needle, not twin, mostly #40 thread Juki clone with 180 #24, needle, I use mostly 277M10 thread standard feet & dog, I use other threads too , and a Singer 29K patcher on stand-by. The rubber mat is to stop it moving. And in the far background covered up, is a Pfaff 60 for thin leather , wallet liners, fiddly jobs etc , and a drawer full of assorted threads, some more in the drawer above it. Tools etc in the top drawer . Ignore the mess...please HS
  24. Its been years since I've used a chocolate antique, or seen it anywhere. Look out for a mahogany antique. No good to you there in AZ , but I get my mahogany antiques from Mac-Lace Leather Queensland , Australia . Its a bit ' chocolaty ' . You could also try experimenting by mixing a few other colours . HS
  25. Right there with you , Amen Peace HS
