shoepatcher
Everything posted by shoepatcher
  1. I prefer the hollow ploy belts with the aluminum burr. Even better than the solid belts. glenn
  2. 441 feet compatible with most all 441 clones. The damn blanket foot that come on the genuine 441 is useless. Whoever designed that and it is very big and wide should be shot.! Piece of junk as far as I am concerned. Not usable on most projuects. glenn
  3. Buy a used 1341 then. glenn
  4. Hook you do not want to fool with. Anyway to lower the roller foot? glenn
  5. Can you lower the roller foot anymore so as to be tighter to the roller feed ring? glenn
  6. pull balance wheel and clean that. Looks great so far! remark all oil holes with red paint stick. glenn
  7. Also look at the Juki 2341. 3rd generation machines. glenn
  8. Not interested in buying the machine if that is what you asking.
    glenn
  9. Sandt and Shoen were German made clickers. One bought the other but I do not know who bought who. I would research in Germany for the manuals. glenn
  10. feet out of sync with the feed dog. Feed dog supposed to be coming up when inner presser foot and needle come down. They all should meet at the top of the throat plate. glenn
  11. That is what I am thinking. They made an HL high lift version and a HHL high high lift version with I think a 1 3/8" clearance of lift. glenn
  12. Ferdinand used both Adler 205-64 and Consew 754 heads to make the Bull. This one looks a lot like and Adler 205-64 except for the bobbin winder. That is a Consew 754 feature. If and Adler head, $2500.. all day long with a little clean up. glenn
  13. Ferdinand used both Adler 205-64 and Consew 754 heads to make the bull. This one looks a lot like an Adler 205-64 except for the bobbin winder. If so, $2500.00 all day long cleaned up. glenn
  14. call or text Hoffman Brothers again. glenn
  15. Contact Puritan in Mass. They are still in business. They can help you. glenn
  16. same bobbin as a 168 W101 Singer post. glenn
  17. Lots of practice. You get the parts list and operations manual with it? read both well before sewing. glenn
  18. I have hard copy only of a service manual for a 8346 Claes. glenn
  19. Rock frame has to be adjusted. glenn
  20. DA is Durkopp Adler America. They are in Georgia. You can call and order parts from them via a credit card. You must have part numbers available for them. You want to talk to Denise in parts. I think it is ext. #3. I think you will need to order the the bushing part # 167-00-067-0, stitch length plate cover #068-16-047-0, and another tension assembly for the other needle thread. You want to find parts list for a 167-273. Superior Sewing and College sewing have the parts list for Adler 167-372,373 single needle and that will work. glenn
  21. Good machines. Parts will not be cheap if you have to buy genuine. Feet from 67,167,267 are all interchangeable. Kwok Hing should be able to help you with feet. Other parts might have form DA. Still good machines to sew on. I would restore it. Look for parts list, operations manual and a mechanics manual if available. glenn
  22. Still the Juki LU562,563 are good machines. They are improved copies of the Singer 111w155. glenn
  23. Yes the flip down roller guides will fit both machines. You will need and adapter plate on the back to mount the guides. Weaver leather has them as does Kwok Hing in Hong Kong. Flip down roller guides are as cheap as $30.00 US on eBay but do NOT include the adapter plates! glenn
  24. Goldshot Ron, Each spacer is numbered with the size of the needle. 180 needle will use a 180 spacer, 200 uses a 200 spacer and so on. You can use a bigger spacer on a smaller needle but NOT a smaller spacer on a bigger needle!!! glenn
