shoepatcher
Everything posted by shoepatcher
  1. same bobbin as a 168 W101 Singer post. glenn
  2. Lots of practice. You get the parts list and operations manual with it? read both well before sewing. glenn
  3. I have hard copy only of a service manual for a 8346 Claes. glenn
  4. Rock frame has to be adjusted. glenn
  5. DA is Durkopp Adler America. They are in Georgia. You can call and order parts from them via a credit card. You must have part numbers available for them. You want to talk to Denise in parts. I think it is ext. #3. I think you will need to order the the bushing part # 167-00-067-0, stitch length plate cover #068-16-047-0, and another tension assembly for the other needle thread. You want to find parts list for a 167-273. Superior Sewing and College sewing have the parts list for Adler 167-372,373 single needle and that will work. glenn
  6. Good machines. Parts will not be cheap if you have to buy genuine. Feet from 67,167,267 are all interchangeable. Kwok Hing should be able to help you with feet. Other parts might have form DA. Still good machines to sew on. I would restore it. Look for parts list, operations manual and a mechanics manual if available. glenn
  7. Still the Juki LU562,563 are good machines. They are improved copies of the Singer 111w155. glenn
  8. Yes the flip down roller guides will fit both machines. You will need and adapter plate on the back to mount the guides. Weaver leather has them as does Kwok Hing in Hong Kong. Flip down roller guides are as cheap as $30.00 US on eBay but do NOT include the adapter plates! glenn
  9. Goldshot Ron, Each spacer is numbered with the size of the needle. 180 needle will use a 180 spacer, 200 uses a 200 spacer and so on. You can use a bigger spacer on a smaller needle but NOT a smaller spacer on a bigger needle!!! glenn
  10. Medium duty binder the 335-17 is. May be able to use 138 thread but will have to do a little work on the machine. glenn
  11. Yep Walk on the feet height is out of sync. glenn
  12. The Hirose number hook number is HSH-12-15, HSH-12-15(A). Hirose and Cerliani make great aftermarket hooks and bobbin cases. You could try one from a 111w155 glenn
  13. The gears and racks look good with very little wear on them. I would take out all the gears and racks from the horn and degrease and remove all the old oil and grease from those parts. I would also wire wheel all the parts so they look new. I do all the parts when I rebuild one. She is pretty dirty. Clean everything really well before you reassemble and try to get it to sew. Gears and racks look like those out of a 29K58. New style. Get me any parts numbers off the parts that you can. Can I see a pic of the balance wheel and the treadle stand if it has one. Thank you. glenn miller You got the old parts that were in it. If so, can I see pics of them?
  14. Should use same hook and bobbin case as a 112W116. glenn
  15. #138 thread and #23/160 needle, not #22/140 Needle system is 134-35. glenn
  16. Pics of set screw for the drive gear . Also pics of driver gear and drive rack! In fact, send us pics of the entire machine as well glenn
  17. Contact Bob Kovar at Toledo Sewing. glenn
  18. I have 5 Durkopp 17 and 1 18 to restore. Use lots of penetrating oil on it. May want to put it into an electrolysis tank to de-rust it and get parts loose. Constabulary uses the electrolysis tanks a lot with great results. Looks mostly all there. Is there a hook and bobbin in it? Great project to pursue. I have manuals on it. glenn
  19. The 29K57 is a rare one. It came out after the 29K51-56 series and before the 29K58,60,62 series. I have one. Certain parts will be almost unobtainable. If your hook is a generic one, it may be a few thousands too big or small over an original one. You got any manuals on that particular model? I would be very interested in getting copies if you have them. I have original Simanco hooks if you need one. glenn
  20. No the first pic is 4 motion drop feed. In skiff feed, the feed dog goes back and forth but does not drop. glenn
  21. Constabulary on this site rebuilt one years ago and there is a post about it. Also, there is one I think on Utube as to how to sew on it. In my opinion and I rebuild shoepatchers, that one needs some serious cleaning before I would attempt to sew and time it. It needs cleaning in the head and thread path. Too much grease build up and old oil on it. I think I have a manual on it. On a good note, You have the slide on table and drawer which are rare to find these days. glenn
  22. Need a pic or to of the machine please
  23. It has skiff feed instead of 4 motion drop feed. H4 high lift and possibly a 10 mm max. stitch length stitch length which were special order and rare. It should still sew and feed well. If it does indeed have a 10mm max. stitch length, buy it and buy it NOW! glenn
