shoepatcher
Everything posted by shoepatcher
You need a narrow center foot and a Left toe outer foot. glenn
I am some what. Call Shoe System Plus in New York and they can walk you thru the retiming. glenn
- 1 reply
- shuttle timing
- broken cam follower
(and 2 more)
Dürkopp 18 Patcher Restoration - long journey...
shoepatcher replied to Constabulary's topic in Leather Sewing Machines
The correct needle system for that machine is System 88, the same needle used in the #3 or #30 big bobbin Claes shoepatcher. They are available and ZI have some of the smaller sizes. glenn -
generic feet work fine. I have used them for years. Which feet are you looking for? glenn
great Auction. I went last year and bought my Adler 669 head for 10% off cash and carry. They had more machinery last year for sale than in any previous year. Could not get it all under the tent! You need a machine go. You can test sew any of the new machines they have. Well worth the trip. glenn
The selling point on this 1341 was that it has a 9mm maximum stitch length where as the 341 was 6mm. glenn
I think all 3 of these machines are made in the same factory in China. You might give W.S. Bessett a call and ask for Mickey. They are in Maine. I just purchased a used 1341 Juki from him. This is a newer and better version of the 341. glenn
I talked to Allen at Weaver this morning. The first Cub is off the line and being tested. Still some work to do and they will not release it until they are satisfied. Should be a good machine. Like I stated earlier, will have a crank on it vs. pulling a lever down. glenn
yes, machine going to be made in the US. Contact Weaver Leather to see where they are on the machine. glenn
The 135x16 is 1/3 the height of the eye longer from top of eye to top of shank and the point from the bottom of the eye to the tip is ever so slightly longer. I set up my two Adler's with 135x17 needles because they come in more sizes, titanium coated I can get in size #180 vs. #160 for 134-35. To use 135x17 needles, I have to adjust the needle bar ever so slightly. This way, I only need to carry one system of needle for most all my machines, i.e. Juki. singer, Adler.
I think the 335-G hook will work in your machine. Not positive. We found the Cerliani hook to be the best price for generic hooks. Hirose also makes great aftermarket hooks. That is the route I would take. Where are you located. If in the states, I would contact Yamata in California and see if they can help with a part number and if the hooks are compatible with Pfaff.
You could get the motor rewound or as Bob stated, get a new motor. I have some needles for that machine if you need some. glenn
That is a tail that the bobbin thread is supposed to go thru
same as Consew 206rb made in Japan by Seiko I believe. Consew manuals and parts should work for it. glenn
Thread size for Adler needle bar screw
shoepatcher replied to jegenes's topic in Leather Sewing Machines
This is a special screw. Hardware store will not have it and the needle bar is hardened so do not try to re-tap it. I an just headed off to holiday so I cannot get you a part number until early you next week. I suggest you check on line to see where you can order Adler parts in your neck of the woods. Is the machine grey colored or white? DAP which is Durkopp, Adler ,Pfaff has a large parts dept. near Atlanta Georgia. They will ship from there. glenn -
call Toledo Sewing and ask for Bob Kovar. He can help you with thread, oil and needles. glenn
I need to see pics of the bobbin case out of the machine and the bobbin out of the machine. glenn
It should be the same as a front plate used on a Singer111W155. Consew copied that machine when they designed the 226. glenn
Contact Weaver Leather and as to speak to Allen Burkholder. He has worked on these machines for over 25 years and is probably the best mechanic on them in America. He can walk you thru the timing. glenn
Backlash springs work no matter how fast you are sewing. I use one in my Juki 1508 and it does make a difference despite some earlier comments. We used them in all our 767 and 867 Adler's. They do help. Cheap to try. glenn
Some companies paints are available from dealers. I might give Consew a buzz in NY to see if they carry anything. The silver grey hammertones were built by Seiko for Consew. Try Hoffman Brothers in Chicago. Primary Seiko dealer and distributor in the US. glenn
Claes 8346 restoration questions
shoepatcher replied to johnnyblaze's topic in Leather Sewing Machines
I just sent you an email. Disregard it. I have only seen on Claes with a foot lift and that took some time to set it up but it was nice. -
John I set them up on an off the arm stand with a servo motor and speed reducer. I can text you some pics if you would like to see it. What are you planning on sewing with the machine? You are missing the spool pin and thread holder that is below the bobbin winder. Can you send me a pic or two of the back of the machine. It looks like you have the zigzag attachment on it. sorry for the late reply. Computer been down for two weeks and no WIFI too boot. glenn -
Just so you know, the tip of the needle, feed dog and inner presser foot should reach the top of the throat plate all at the same time. In your machine, the tip of the needle is way late. That adjustment needs to be made. The feed dog looks like it is coming up a little to high. Feed dog should never rise more than the bottom of the teeth are above the top of the throat plate. glenn
