shoepatcher
Everything posted by shoepatcher
  1. You have the instructions for oiling the machine? if not get them. Also, see if there are illustrations of the parts to oil. I would study all the oiling parts and oil the piss out of it. Make sure the pressure on the feet is not too high. I am always amazed on how many sewers do not get the operations manual, parts manual and if available, the mechanics or engineering manual. These are critical if you are sewing on a a sewing machine. I have preached this to so may sewers over the years. You need the manuals!!. Not a question of if but WHEN. I am not saying you are one of the them DBZ456. But this info is essential if you what to learn your machine. Really helps on locating the oiling points.
  2. show me pics of the binder front and back not on the machine please. glenn
  3. That thread is bigger than 277 I believe. You do not want to exceed 207. glenn
  4. A whine at high speed might indicate a bearing going bad. I would oil the snot out it, let it set for 24 hours and then try it again. There may be an area that was missed when oiling so check the manual. Should be the same as a Singer 111W155. glenn
  5. Tell me what you are looking for in a binder specially. I have set up binders on and off for over 30 plus years glenn
  6. Nakajima 280 became Juki DU-241. Hope that helps. glenn
  7. Binder may have to be custom made. Check to see what Kwok Hing has in Hong Kong. Your Seiko should be same as Consew 277 machine. glenn
  8. Yes as to the photo. You can adjust the feed dog left to right to center the needle in the middle of the hole in the feed dog. Move the cover plate and that gets you access to the feed dog screws. Pics of the head on your machine please. The SL-71 was one Landis had built. It is a clone of a 29K71. Parts should be interchangeable. glenn
  9. Pics of the head first please so I can see the feet and the cover pate set up. If it is 335-17, that is the binder machine. For repalming, you need it set up to sew on the edge of the of the fingers. A binder will do binding but will make sewing other parts very hard. send me a few pics please. I can help you set it corcrrectly. Bend doing to it a few years. You may need the plain sewing parts. I also repair shoepatchers. glenn miller
  10. Turn the dial it all the way and test it for the amount of take up lift in the lever. Then turn it all the other way and check. This should tell you which end of the scale it for less and greater. Choose somethin in the middle. Singer engineers in their stupid thought over engineered this part so that it it way to complicated to dial it in. The older way was much simpler on the early versions of the 29K58,60,62. None of the clone machines made today use the complicated dial on the later machines. Keep it simple stupid as they say. Anybody needing parts to the more modern take up lever adjustment, I found a source for them. glenn
  11. The Genuine Nakajima 341 became the Juki 341. Neither was a hybrid. glenn
  12. So sorry to hear that.
  13. cdthayer, You get the 205-370 rebuilt??? glenn
  14. Contact Randall Campbell in Texas for info and help. glenn
  15. That one set up for a binder. Feet, throat plate, feed dog. You need that set up? glenn
  16. 341 feed dog and throat plates and their clones. glenn
  17. Try replacing the bobbin tension spring with a new tension spring. Make sure the old spring does not have a groove worn in the back of the spring. glenn
  18. Advantage better sewing on the corners with a moveable binder. Disadvantage- changing out from binder to no binder. glenn
  19. your location and phone number in Indiana for Erik Robinson. glenn
  20. Contact Erik Roberson 3124933140. Tell him Glenn Miller told you to call him. glenn
  21. I have an illustrated parts list. That what you looking for? glenn
  22. that seems high for generic feet set glenn
  23. I have someone else checking on parts as well. He has 211 parts as well. glenn
  24. pics of the machine please. glenn
