Everything posted by hidepounder
Clint, Great job on the site! It looks terrific. Also I want to thank you for your support of a very special group of soldiers!!!! I think what you are doing is pretty special! Bob Park, 7th Special Forces Group E5, 12B4S 1972-1975
Ricky, I use mine a lot also. I used to put my head knives on it but I've gone back sharpening them by hand, then taking them through a couple polishing stages. I recently had to replace my motor and went to Sears and picked up a bench grinder that is variable speed from 1750 to 3500 rpms. That worked out really well. I reversed the base so that I could work on the top of the wheels as they turned away from me, and modified the wheel guards so that they exposed the top of the wheels instead of that the area facing you. The reason I jumped in though is that I used to use the bees wax and have dumped it for a tube of grease that does a better job of lubricating the grit wheel, giving me better cutting and less heat. If you like using the stationary belt....3M makes some really fine belts....my favorite is a 1200 grit belt that does a great job of refining an edge before you start buffing.....just thought I would share that...... Bob
How do you keep your workshop warm?
hidepounder replied to UKRay's topic in Leatherwork Conversation
Troy, I'd be wearing a sweater there, it's 115 here and we haven't hit the highs yet.........what's your address again, Troy.....I might be visiting soon, LOL! Bob -
Looks pretty good Oscar....I like the way you combined the inverted carving with conventional beveling. Good job! Bob
Dustin, I agree with Marlon, practice doing both. The more you learn to control your knife, the better your results will be. You will find that different situations will arise which will force you to cut in one direction or another. It is also important to learn how to bring two cuts together, so that the beginning and end don't show. You can't practice enough, even the pros need to practice from time to time. Something to keep in mind is that practice does not make perfect! Only perfect practice makes perfect! What I mean is, just cutting for the sake of cutting is not going to be as fruitfull as trying to accomplish a specific cut and practicing until you get it right. To do this you need to work from a good example. In other words, don't practice making cuts by copying someone who is only average. Find the very best examples of cuts that you can find and work on copying one cut at a time until you have mastered it. Part of being a good at finger cutting is the ability combine several different cuts into a pleasant looking pattern, so as you begin mastering different cuts, practice putting them together into something that is pleasing to look at. It takes a little while to master the use of the swivel knife, but it is the foundation of everything you carve. I hope you find this useful..... Bob
how do i smooth rough out leather
hidepounder replied to clabouve's topic in Leatherwork Conversation
In this month's LC&SJ Bob Klenda wrote an article where he discussed slicking the flesh side of leather. After wetting he applied saddle soap which helps to bind the fibers together and help them to lay down....same principle as using saddle soap on edges. Bob -
Another good looking rig, JW! Bob
WIDE belt
hidepounder replied to Dolphini's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Dolphini....tapering a belt for a narrower buckle is a commonly accepted practice. Here's an example... Bob -
It's been a long time
hidepounder replied to Rawhide's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Great job Marlon and congratulations on the win!!!!!! Bob -
Requiring a deposit is pretty standard. I require 50% with the balance on completion. On internet sales, I require the balance before I ship. I usually will send a photo of the finished product along with the final invoice. I don't ship until payment is confirmed. I really don't want to insist on full payment at the time of order, but that is probably the safest way to protect yourself. I have a friend in OK who is very successful. He requires a non-refundable deposit which puts that customer in "line". When it is that customers turn, he requires the balance before he starts the project. If he does not receive payment within a certain window, the customers name goes to the bottom of the stack. When it is his turn again, he requests payment a second time. If not received on the second go round, he cancels the order and keeps the deposit. Not a bad policy! Bob
Tooled Briefcase
hidepounder replied to Double U Leather's topic in Satchels, Luggage and Briefcases
Rookie, Don't give up on making the case out of multiple pieces. I like that....it gives you the opportunity to make better use of your leather and to make the case a little fancier (therefore worth more money). The way you attached the flap was okay. An alternative is to extend the back of the flapdown a little farther and hide the seam behind an outside pocket which is handy to use. If you aren't going to add an outside pocket then, yes, the back and flap would be made from a single piece. Many briefcases are made where the gussetts acutally extend from the side, all along the bottom and up the other side. Again, this allows you to use smaller pieces of leather. You did a great job on this one! Keep on strokin'! Bob -
Tooled Briefcase
Rookie!!!!! Great job! It's a really good looking case! I don't want to make many comments on your tooling. I think you're doing a good job....just keep on practicing. I agree with Rick, however, you need to make your petals a little bigger and more elongated to help balance out the background with the foreground. You also oversized a couple of "acnathus" leaves to fill space. They need to be made a little smaller. But a lot of that is purely a matter of style. I am curious however about your choice to run the strap under the flap instead of over it. That is unusual, I'd like to hear how that works out. Keep up the good work! That was a big project...they can be complicated. Bob -
Drying time?
hidepounder replied to ukfossil's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Hi Mick, What you are experiencing is a fairly common problem. Usually cracking occurs when finishes are applied too heavy. I'm with Ross, I'm also a NeatLac fan....it's all I use. But it also can crack on bends and folds. The trick with NeatLac is, like Ross said, to rub it in. I prefer a couple of light coats. In addition, you are more likely to see fine cracking on a smooth belt like you made as opposed to a tooled belt where the tooling hides imperfections in the finish. I don't any experience with the finish you used so I can't comment on your application. I would think any finish which penetrates the leather would be preferable to something which sits on top of it. Bob -
IT'S YOUR DAY! Have a great one!
Glass glue jar with replaceable brushes
hidepounder replied to esantoro's topic in Leatherwork Conversation
Ed, I don't think they will fit, but I probably shouldn't say because I haven't used quarts is such a long time. It's cheaper for me to buy by the gallon and feed into the plastic bottles (I think they are pints). I just replaced the brush on one of my bottles that's been in use for at least 10 years. Bob -
Charlie, I agree with Max....it's conceptually what you need. I too worry that the lamps will do the job. I also discovered that with the one I use I always have to iron the backdrop fabric because the folds in the fabric show in the photos. The fact that is all folds up is handy for storage....I just hate ironing! I always thought it would be handy to have some sort of roll down shade on my bench to use for photos....someday I'll get around to trying it. Bob
Great job Casey! I'll bet that was fun to do. Are these three ring binders? Bob
Add me for Hansens.....haven't tried Wages yet, although we've had some dialog. Bob
Another 3-legged camp stool
hidepounder replied to Double U Leather's topic in Furniture: Inlays and Upholstery
I'm with Art on this one......Good job Rookie! Bob -
This is what works for me... I use the plastic glue bottles with the brush (replaceable) mounted in the lid, that Tandy sells. One for Barge and one for Rubber cement. I can screw the tops down tight and put them away. Because they're plastic, I don't worry about them breaking. I do have to refill them fairly frequently, which is okay with me because it helps to insure I have fairly fresh glue. I also use the squeeze bottlles, but I have been using smaller ones, because the glue was dying up too fast in the large ones....I guess I just don't use it up as fast as shops do. When gluing a very large area, I pour right out of the gallon can and spread with a piece of sheepskin, or a 2" wide disposable brush which I trim short to keep stiff. I always thought the glue pots seemed like a good idea, but they're a little expensive and they dry up too fast for me, because I'm not gluing everyday. Also, they aren't as convenient to put away as the plastic bottles are. I keep the appropriate thinners on hand for all my glues, and monitor each glue bottle to keep it appropriately fresh. When gluing large areas it is sometimes handy to pour glue into a plastic coffee can to thin it slightly....then use the disposable brush. When finished I take what is left over and top off my glue bottles, or return it to the can if it wasn't thinned too much. The plastic coffee can doubles as a good place to store my glue brush once it's cleaned with thinner. Just some of my thoughts on gluing....won't work for everybody. Bob -
Wow Ian....I'm really impressed! Something I've wanted to try for years and will probably never get around to. That is beautiful! Bob
I think Weaver sells it......
Josh, Here's a good source: K & G finishing supplies. www.knifeandgun.com 928/537-8066 They have a lot of good stuff...get their catalog. Bob
