Mocivnik
Everything posted by Mocivnik
  1. Thank you very much for the comment, but i have something to say. Thanks for the comment on what to be where - helps alot!! I use also wooden tools and nonmetalic ones, i think i will use loops. And the last one - i cant attach it to the wall, but have to the desk :/
  2. So, since all the literature is out of me, here's the real question: Should I add the wooden board to the back of my workbench to hold tools or not? What is all about? I just moved to another appartment, where I created myself a working bench - leatherwork. Below is the photo of it. The desk is 30mm (or 1 3/16) plywood, which was covered with 2 thin layers of oil (used for cooking woodies and toys). Now I would like to get rid of the "mess" with the tools all around and add a board to the back. The desk itself is 56x141cm (or 23"x 56"). I would like to add the board at right angle at the back of height 43cm (17") and only 15mm thick (or 19/32"). Here's also the question: would 30mm part (or 1 3/16) hold enough with several screws onto the desk, if I would screw it at the right angle? Or should I cut it in 2 or even 3 pieces by the lenght? And to simplify stuff - here's the sketch of what I had in my mind. Dark brown are legs of the desk, yellow is the desk. I wanna set up the blue board (56x141cm or 23"x 56", thickness 15mm or 19/32") and use only several screws, RED sticks portrayed on the photo below. Will this work and be stable enough? PS: All that I wrote had huge sense in my head. If there's anything confusing - please let me know, I'd be more than glad to explain myself (again or more into details).
  3. My new workshop. After 1 month of keeping the stuff and 2 months of moving, finally managed to set the working table as it is seen now. I've changed location now. I am still on 90% of work here done, as I'm waiting for a kilogram of rivets yet to come (to fill outter assortiment boxes under table, each color each box - gold, brass, silver and black. One is for "rarely used items".). I am still unsure, whether should I add a wooden board behind the desk upwards, to tape some leather straps to it to put my tools on the board (like here CLICK ). What do you think?
  4. The thing is, I've seen that video and still was confused as I can find many sellers sell "oil dye" on amazon and ebay, but I always got pro dye. But it's okay now, now I know what I got. PS: I've been using it all the time (pro dye) and it's quite good one. Best penetrating so far (although I had some difficulties for not penetrating enough - after DUNKING and it still is quite pale, using walnut or brown dye). Will consider more experimenting (but it's expensive AF!!!).
  5. I know there has been much talk about this topic, but nowhere I could find info about renaming actual dyes. Long story short: fiebing's OIL DYE doesn't exist anymore, it "transformed" into pro dye, right? Both, pro dye and leather dye are alcohol carrier dyes, while LEATHER DYE is alcohol based dye including powdered coloring. EX oil dye is now called PRO DYE and is still including some alcohol while it's made on oil base. Is there anything wrong with what I've written or did I understood it right? And since OIL DYE was renamed into PRO DYE, did the consistency of the dye changed?
  6. So this is my first bag I've created, I'd set it into bikers equipment, although It's ment to be worn as bag over shoulders. Could be attached to bike aswell. Been sewing it for about 12-14 hours all together. Will post more pics soon. All comments welcome, please critique my work!
  7. Yes, but..scabbard or sheath is just a "leather device to keep knife safe" and not a combination of multiple things such as knife, axe, compass, etc. :/ Sorry, the link was broken and the photo I inserted was wrong one. I repaired it now. I am looking for "packages" which goes on belt or backpack and they keep axe, knife and few more utility items. Combo might be tried. Thanks. But still, anyone seen anything like this before aswell?
  8. I need one for my axe, knife and few smaller components aswell, but before I start making one, I'd like to (at least!) google for more of them, to get more ideas and become more creative at it aswell. I got stuck at googling them - cant google by any kind of name it.
  9. if I can help out here, buy a press like this. This is mine, I got used for 100€ or 86 GBP or 113$. I added the laser-cut measure guide with caliper-like scale (i draw it fast and just cut it out) so I can use different tools and just read out the number, how high has to be lifted the front part. The piston has hole in middle of 12mm or 12.7mm ( I don't remember) and I just turned the adapter for M6 inner thread (for my dies). Adapter could be seen just the tip. On the bottom, there is silver plate, which has hole of 12mm through, as all my dies have diameter of 11.9mm or 12.0mm. I planned to do just the "tip of the 24mm hole" for some other dies, but some things happened recently so I just abandoned further work in this workshop and moved to another. The press work through eccentrical mechanism and more you press it (down) easier it gets, the force gets bigger (but the movement is getting smaller). It's a bit complicated to explain, but this works like a charm. I still own it (this is from my ex. workbench) but due to some difficulties I'm facing, I can't reach it. (lifehack: sacrifice a wrench for a tool - like I did. I bought an extra one just for this press, driller 2 holes through it and attached 2 strong magnets. Everytime I need it, I know where I can find it. And I use it just for this press and nothing else. Both sides.)
  10. @Constabulary: Well, actually..quite common here. Dies comes from Italy and I don't really know why they use this system. Company called MOVI, from this site http://www.fbg-italy.com/ . The press was bought in Slovenia, but I believe it comes from Italy aswell, as I could find it in their catalogue. I don't mind very much about it, since I had bigger press and had to re-do taps on my dies (some time ago) so they were compatible as much as 1/4-24 as with M6 (the difference is really small, 1.4mm on 1 inch). I will buy tap and dye and just make all of them on same size (1/4-24) and hope never to change any system (as it's going to be VERY expensive).
  11. @JLSleather: You had me for 5 mins now. I went to workshop downstairs and tested - it fits, but loose. Probably because the diameter of screw is 6.2mm instead of 7.0mm(as for M7). I think that 1/4-24 is the right one. And it's the same problem for M6 screw, which has pitch of 1mm (25.4 threads per inch). It fits first two turns, but then it gets stucked. (And as we all knows, dies should sit NOT on thread.)
  12. Haha :D I had already opened this one in my bookmark :D https://www.ebay.com/itm/1set-1-4-0-25-inch-American-Standard-thread-HSS-Machine-Plug-Tap-Die-Tool/113597039233?hash=item1a72e94281:m:m3VtHpyglUBMi6wmV1XySjg 8$ isn't so much for a tap + dye while i have to make 2 handles for dyes and cut ~10 taps on my tools, which aren't compatibile with press (yet). I've measured it before. But I cannot measure the gauge on the inside, as it's too small hole. I can measure it on "screw" part because it's outside.
  13. Not just possible, 99% it is. As soon as I've finished this post I figured out that this is probably the right thread (but having a problem, since I don't find it by any standard..especially not on maryland metrics).
  14. I've got myself a hand press(bottom pic, nr. 2), where all the dyes have this unusual(and unknown to me) thread on them, to fit inside (top). At first, I thought it's M6 (as it's very standard thread!) but by closer inspection, I noticed it's not. It's close, but it's not M6. I measured the pitch of the thread and it's 24, while diameter (of screw) is 6.2mm. Does anyone knows what thread this is? (I need to know what thread is so I can edit some other dies to it)
  15. Whenever I want to go to /forum/discover/content-posted/ I get kicked onto https://leatherworker.net/forum/index.php I don't like it either.
  16. I got these stamps as a gift not knowing I already have most of them. Looking for 15€ (17$) + 8€ shipping worldwide (9$) OBO. I accept trade aswell (make me an offer or show what you have to sell/trade). Numbers: X503S (E684) Z-U853 Z-V407 Z-A104 Z-Q431 Z-B701 Z-V707 Z-S706 V407 Z-P217 +
  17. Barely used, end strap cutter 1 3/4". Looking for 35€ OBO. Can ship worldwide.
  18. I'm searching for pliers or something simmilar tool to "hand-rivet" leather. Anyone knows where to buy some or even at least, full name of this tool?
  19. @fredk: Not a problem. @Scoutmom103: I could find only this. But this doesn't help a lot. Thanks anyway.
  20. I'd be very grateful to you, if you could do that Thank you very much so far!
  21. I'd like to make a present for a friend of mine, who owns a Olympus trip 35 camera, a leather pouch with strap around the neck. But the problem is, that I cannot get this camera nor pattern for it. Therefore, I'm asking on this forum in hope of getting any useful information for it.
  22. I know this is >10 years old post, but..where the hell did you get those bullet rivets? :D they look outstanding!!!!
  23. @rockyasussie: that's exactly what was I up to. To just engrave the holes. I think this is the way to do it from here on
  24. Yes I do, but I use the knot as close to the needle. Never actually thought of it, might use it. Thanks for the hint! Secondly: where do you even get unwaxed thread? All i could find on ebay is waxed..
  25. @RickyAussie: Yeah, I just got that hint now aswell. I wasn't thinking that this should be a problem, because I thought only "edges" of holes could produce dirt, but they were covered with resolene. Certanly something to remember, thank you! @Vabax: Yes, laser cut -> dye -> resolene. I can't really say much about this: I'm doing mostly in dark brown or only neatsfoot oil color, both times thread gets dirty. I'd say it's 99.9% of the charcoal in the holes. I never thought of it before. What about spirit based/oil based dye change? Should that affect aswell? I've always been using fiebing's pro dyes.
