Everything posted by koreric75
Adhesive Question
koreric75 replied to Russ498's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
permanent bond spray adhesive...check the local auto parts or amazon? Honestly though, if I'm gluing up something that i want to last I still only trust contact cement on both layers, but some of the 3M and associated spray adhesives work well depending on use. I used this for a custom made portfolio to attach the backer to the foam before stitching around the rolled edges...https://imgur.com/a/XHor9kx -
So the boy decided he would make a wallet he's had for awhile. I got it in a clearance sale at Tandy, the classic trifold kit. He decided he'd use the thicker white braided nylon and went with a light British tan sunburst with the air brush. Other than helping him get a few of the stitches worked out after he pierced the thread he did a great job. He was a little disappointed the edges didn't line up perfect to burnish, I told him with a kit and no glue the pockets and layers will move with use and folding/unfolding the wallet. He still hot the edges with some saddle soap and canvas... And they polished up nice, just not flush looking he wanted... Son's first wallet/leather project... https://imgur.com/a/M8WhbiT
cool, now just need some steel plate and a welder...or a buddy that can weld ( haven't tried and don't think i'm ready to undertake another artform) and some dies and you'll be rocking and rollin
That is awesome, one couldn't ask for more, even with the containers...I will look into this as i've found some projects need something other than the resolene although i use this most with the airbrush. I need to learn more patience and let the dyed project set overnight and rebuff before spraying though...lol
The Harbor Freight presses are fairly inexpensive and go on sale often, not sure if there's one near you as i'm not sure about shipping one. I simply just don't have the room to put one together yet.
Newest cowboy holster
koreric75 replied to Boing's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Cool inlay, this was what i was imagining when responding to a post about cross-stitch punches for leather...can't remember who was asking, but my suggestion was pretty much what you have here. -
hmmm...that's a good idea. I use the weld wood contact cement that comes in cans with the paint can type lid, but i have some older bottles that have the threaded cap with the brush attached I could transfer some into and keep the paint can lid on good and tight and just use out of the threaded bottle. Thanks for the idea c/o chuck dorsett, but i hadn't seen it before.
Acrylic aquarella paint used on leather edges!
koreric75 replied to RusticLeatherShop's topic in How Do I Do That?
Any thing done half-assed will look just like that, half-assed, all the lipstick in the world doesn't make a pig more attractive...lol. A poor job of joining or preparing the edges will show even with binding. The point to binding is to cover raw edges, still want them as even and neat as possible. I use this for leather and material that doesn't burnish well or fold well...or benefits from the strength of binding the two together like stress points of a bag, but mostly to cover the raw edge. When binding depending on the thickness you may find skiving the joined material will help cut down on bulk when adding binding material as well. For some of your softer garment leathers that you use, have you tried saddle soap and canvas on the edges...it works for some that would just fold or crinkle with a rub stick? I have some thinner garment leather that i found comes to a nice burnish this way after previously trying the slicker on it. For some it has helped to stick it between a couple pieces of straight edge material...granite, marble, even a couple nice smooth boards, yardsticks etc and just leave the very edge of the two edges hanging out. -
You should be able to mix in whatever the base is, all that has happened is that enough has evaporated over time and left your glue thicker...always try to keep the lid on tight when not using and in between uses, same with dye, if left open the base evaporates faster and can ruin a dye job, for alcohol based dye I will dilute with denatured alcohol, water based dye w/ water, resolene w/ water acrylic w/ water etc... I have a few cans that i use, for long straps and big projects i grab the newer or thinner of the glues as it's not been exposed as long and gives me more time to work, or i'll pour a good amount into my glue pot but if i don't get it right it's a pita to put back in the can and even sealed the pot seems to keep shorter time than the can.
I usually mix with a new can, I use weld wood, and it's a little too runny for some things so I have a can of new that I use for easier spreading and a can of less runny for more consistency
Problems with ferdco pro bull
koreric75 replied to BaroqueLeatherGal's topic in Leather Sewing Machines
True, I have had the thread take a funny twist and loop around the tension spring... -
Good morning, just following up to see if you've made any progress? It looks like a beautiful machine and i love my HD stitcher and would be lost without it. -
did similar, i used my dremel and the "screw on" post for buffing pads to turn the little wooden knobs that are flat with raised edges, it takes a few seconds to swap one out for another and i can control the speed to suit the material. I have a drill press, and a 24" section of oak dowel "closet rod" just haven't chopped and put a gouge to it yet...the dremel takes up way less space, but i have to hold the material and the dremel . I had an idea awhile ago to use a variable speed router mounted in a benchtop router table with a turned groove to do belts and sand edges...you could adjust the fence and the height with the table and router adjustments, just haven't tried it out yet.
does it happen on different thread spools, if the needle hole is too big it may not be enough friction to hold and cause the loop to form? Need more specs so if someone that knows sewing machines better can better assist you...needle: size, point type, new/old/tried different needle types, sizes thread:size, composition (nylon, poly etc) age if it's been sitting awhile or not, tried different thread sizes, types etc.. material: leather, veg, garment, thickness, weight, if none of these seem to help fix the problem then may need to look at hook timing, tensions etc...it's helpful if you have someone take a video of you sewing slow with the side cover open to see how the thread is looping or not...of course it's like that weird noise you get in a car, take it to the mechanic and it doesn't do it at all then on the way home it comes back...lol, i'm sure the sewing machine gurus will have more to offer, in the mean time try to address the first things i mentioned...if you haven't change the needle...if that doesn't help try a smaller size, wouldn't say looking you'd need a bigger size, just try to make sure the needle size and thread match and match the material you're sewing... my old adler was skipping like crazy when i got it, but i was using a #22 round needle and #69 & #207 thread because that's what i had...i was testing it on veg tan or heavier foot leather scraps, but with some softer garment leather same thickness the #22 round and the #207 it sewed a few 20" long french seams beautifully...when if finally got in my leather point needles a #23 & the same #207 thread sews beautifully and i haven't had a skip since, one full belt double 6oz glued back to back and some of the previous test strips...no problem -
Rushing around a curve before the thread makes a loop will cause that, does it happen on straight runs as well? -
I haven't tried this, so can't expand on the procedure... from the video it does seem it is a trial and error process...I would try making a paper gauge like @Uwe has to test the fwd and reverse stitches...
- 10 replies
- juki
- adjustment
(and 1 more)
stitch length if max at 4 spi, will shorten with taller material, I'm not much help for the fwd/rev, but there should be an adjustment for that...maybe @uwe has a video covering something like this...i searched like this site:www.youtube.com juki lu-563 reverse stitch adjustment and first vid popped up...tada..., if you've already watched this and tried the adjustment, may just take some more tweaking...
- 10 replies
- juki
- adjustment
(and 1 more)
- 10 replies
- juki
- adjustment
(and 1 more)
Is this for head only or head, table & motor (what motor btw ie. clutch or servo), thanks..
Ditto, took awhile but was worth the wait, I'm thinking of getting another condensed size for smaller items... Have you shot him an email? I have no insight to his operation, ie, if he's a sole crafter or what not, but was always easy to communicate with, just the time difference from here to there... Threw me off but he's actually French, just lives in v.n.... He also helped in my design, he caught the font I used originally would not make as much of an impression as a deep cut, he adjusted and sent me a revised graphic and didn't ask for a penny more...
No worries at all, you gotta go with what makes you happy, I would also like a set of those crimson hides, one day after I've recouped some of my investments in machines, leather and other tools perhaps...my poor harley must feel neglected, all my fun money used to go there...lol
That's the one...
Thank you for the clarification, I am not sure how that works, the seller name on Amazon is C.S. Osbourne Co, link below... Osborne #144-43 Stitching Awl with 1-1/4" Diamond Shape Blade https://www.amazon.com/dp/B00L6M39I6/ref=cm_sw_r_cp_apa_oyxKBbJ313MWW so I thought I was buying from the company proper... I've done a little research on drop shipping though and have found a few other sellers that do this, although I'm not sure how they can without some sort of blessing from the company and as such ensure quality. I know I would not want my business name associated with a seller like this, this awl has a three star overall review history, allot of 5 star and allot of 1 star... And in between. Until now I would have no reason to think the C's Osbourne selling awls on Amazon is any different form your distributors, and I can't be the only one there. I'm not trying to give you a hard time, but wish this information would have been known to me prior...I can handle the $10 dud, and the metal seems to be good enough to Sharon and work, just wasn't what I intended when I bought it. I realize now why there are so many $100 awl sellers out there, I reckon you pay for the labor of sharpening and shaping up front...
leather oz binding for bags help...
koreric75 replied to cbriansew's topic in Leatherwork Conversation
I use the same leather as the body or accent color, cut in to strips and if necessary (almost always is) skived as thin as possible to allow a double folded edge that will cover the seam edge and give ~1/4" seam allowance on both sides...there are places that you can purchase leather binding material on spools if you have a machine with a binder attachment, i have yet to get one so i use contact cement to do the folds and bond the binding then stitch with the cb3200 or hand.
