kgg
Contributing Member
Everything posted by kgg
  1. They are decent enough, better then some I have seen for sale. Suggestion: Add a stitch line along the edge to help reduce stretching. kgg
  2. The water based with one coat is Very interesting. The problem with the Aquilim 315 is the cost. It is about 1.6 times the cost of a heavy duty clear contact cement from your local hardware store. kgg
  3. I would be interested in seeing the belts. Me I have two belts. A store bought "genuine" leather black dress belt which I figure I have worn maybe a dozen times in the last 8 years and my daily 13 oz medium brown chrome tan. kgg
  4. I find getting chrome tan to another colour can be a challenge. There are a lot of factors, who the manufacturer of the leather was, the original dying process, the colour you are trying to change, who the manufacturer of the dye is, etc. I have some medium brown pre-dyed 6 1/2 oz chrome tan that I want to redye to a colour close to Oxblood. I have experimented with a few cutoffs with different colours (rouge, wine and oxblood), and dye from three manufacturers. What I finally settle on was oiling first with Promise 100% Pure Organic Jojoba Oil, leaving it for 24 hours to soak in, then wiping the excess oil off and then applying Fiebings Oxblood dye so far is giving me a decent result. kgg
  5. The centre. Personally I am more hands on then my example. I hand cut my leather with a utility knife, use a standard oblong, round or corner punch with a hammer but I do use templates when I can and I do use a sewing machine as I don't have the temperament needed to sew by hand. Since I am artistically challenged I will use an embosser once I complete building it. To me hand sewn is literally when needles and thread are used manually to create a seam not a sewing machine. kgg
  6. What I would suggest is that you choose a colour for your chrome tan leather that will go with any colour you decide to use with your veg tan leather. Think of colours like black or grey or use a colour wheel. I wouldn't go with a leather stain as it will probably sit on top of the leather and rub off with use. kgg
  7. The definition, according to Wikipedia, of Artisan according to (from French: artisan, Italian: artigiano) is a skilled craft worker who makes or creates material objects partly or entirely by hand. The problem then arises would I consider myself a Artisan if I constructed a belt in this manner: i) used a leather cutter machine to cut the length and width of leather ii) used a skiver machine to cut the buckle fold over down iii) used a leather tongue hole punch machine to put the 5 holes in iv) used a levered punch/grommet setter to set the double side rivets that hold the buckle in place v) used a rivet setting machine to install the double sided rivets for the belt buckle vi) used a stapler for the belt loop vii) used a leather embosser machine to put the pattern in the leather viii) used a airbrush to apply the dye ix) used a motorized burnisher to finish the edges x) used a sewing machine to stitch around the edge of the belt The belt would look professional, functional and be able to be consistently repeatable but what part did I make by hand? To me anything with Artisan in it just means expensive. Hand made is in a completely different level / category particularly hand embossed, hand sewn, hand cut, hand dyed, hand burnished, etc... kgg
  8. I would suggest: i) use a motorized leather strap cutter ii) contacting the suppliers of motorized leather strap cutters like Campbell Randall ( https://campbell-randall.com/shop/strap-cutting ) iii) once you have the straps cut to the width you need it would be a matter of gluing and sewing them together. Could you possibly cut back the thickness to 9 / 10 oz as you have an easier job finding a manual leather strap cutter like Tandy ( tandyleather.ca ) ??? kgg
  9. This is a couple of photo's of the bobbin assembly from a fellow member who recently bought a 341 machine from them. Yours looks like a Juki style. kgg
  10. I like that one. kgg
  11. Most machines have two spots to hook the return spring into. You should check to see if yours has a second location to give a softer return. Possible solutions: a. The internal rubber wheel that drives the winder needs to be adjusted so it only engages when you want to wind a bobbin. However if you wind a bobbin while sewing it can create a problem of unwinding the thread from the bobbin. There seems to be a couple of versions of this model some with the bobbin winder on the top of the machine and others driven with the main belt. I would just cut to the chase and buy a winder that runs of the main belt which probably would cost about $16 USD off Amazon. The dial should have a set set so you could move the dial to the correct position. Most machines are that way. I know some of those machines came with a smaller top thread pin with only two holes. As a note the hook assembly in the Jianglong 341 seems to come in couple of favours one that looks like the old old Nakajima 341L which was similar to the Singer 111 and another that is like the Juki LS-341. Which one do you have??? Just my thoughts. kgg Juki bought Nakajima and renamed it the Juki LS-341.
  12. I use Leather Work to describe what I do. To me it is easier for the average Joe to sorta kinda have a idea of what my hobby is about. To me a "crafter" would be more like "master" as in a master electrician / plumber / tailor etc. having far better skills and knowledge then myself. kgg
  13. Post on the front page move down the list as new ones appear but are still in the sub Forum they were created in like a question related to a sewing machine would have been created in the Leather Sewing Machines sub forum but would also appear on the right side of the front forum page. As new topics appear it would move down the list and off the front page but be still listed in the Leather Sewing Machines sub forum. If someone posts a answer to your topic it would reappear on the front page of the forum and then move down the list once again. Your post: Questions on tooling English Bridle is still available in the "How do I do that?" sub forum on page 2 with one response from @TomE. kgg
  14. Most times it is not a problem but have a seniors moment, be distracted, tired or whatever and Murphy's Law is always at the ready to kick in. You screw up and you want to kick yourself in the butt as you just screwed up the work piece. Someone else my not notice but you will. @toxo I agree. Having a simple centre point ruler of any configuration is easier and correct everytime. Also the fractional measurements in the imperial system are not as easily divided in half as compared to the metric system. I did have a digital mic that read in both metric and imperial which is typical but this particular mic automatically showed half of the actual measurement. kgg
  15. The logo for this ruler is a square with a centre point arrow and the brand name of the ruler is Center Point which is sold by US Tape Company. I figure it was placed at the 5.5" mark just to confuse the hell out of people as it has nothing to do with measurements. kgg Nah, it's a short foot sorta like a short ton (2000lbs). kgg
  16. @toxo and @fredk The more options the better. Like when I am doing a dog lead I use a 6' steel ruler. kgg
  17. I finally got tired of doing calculations in my head when trying to find the centre of something. Since I was taught, trained and worked in the Imperial and US systems until Canada converted supposedly to the Metric system. Normally the Imperial system is my go to for everyday type measurements. So I finally broke down and bought a 12" centre finding ruler sometimes called a doubling ruler. The ruler: i) Imperial measurements up to 12" or a you can get a larger 24" version ii) Two scales. A measuring scale and a centre point scale iii) Material: Tempered Stainless Steel iv) Sold by US Tape Company (https://www.ustape.com/product/centerpoint-straight-edge-rulers/) v) Made in China vi) patent number: 5,251,382 which is for a tape measure not a ruler???? vii) Status: Expired - Lifetime viii) Cost: I paid $18.90 CAD plus tax for total of $21.35 CAD ( $15.35 ) from Lee Valley This is a very simple design. You just measure the item say 8 1/4" and find 8 1/4" on the bottom scale and that is the centerpoint location. Anyone with a laser or 3d printer could easily make one. To bad they don't have a metric version for better accuracy. kgg
  18. Servo motors: You can use either a brushed or brushless servo motor on any industrial sewing machine and it is a straight swap out as the mounting hole pattern is the same. You may have to move the "go" pedal slightly to the left or right. You can buy from a vendor or from Amazon / Temu / Ebay but you are not limited to the dealer should you want / have to change the motor. Brushless servo motors come in typically three puke flavours. Cheap ones have 6 internal coils for the servo motor, mid grade have 9 internal coils and the better ones have 12 internal coils typical wattage ratings of 1/2 hp to 1 hp. The more internal coils the better. Brushed servo motors are simpler to repair with no computer controls, longer lasting with typical wattage ratings of 1/2 hp to 1 hp so less frustration. kgg
  19. Carefully and with two people. The strongest one on the heavy end. I would suggest making another table and avoid swapping them back and forth??? kgg
  20. I'm glad the you got it freed up. As far as I'm concerned there's nothing better then good old fashion Diesel. It works better then any of the "penetrating oils" just smells a bit. I would now flush/soak the area with synthetic transmission fluid. That will soak in and flush out the old garbage while lubing. Sorry, can't help with the amount of movement you should have. kgg
  21. kgg
    XDS iwb
    Thank you. Looks uncomfortable but I have never worn one that way, always worn one on the outside. kgg
  22. Maybe a vise and a couple of boards. kgg
  23. kgg
    XDS iwb
    I am going to ask two dumb. Why are the clips on the front of the holster and how does it attach to your belt??? kgg
  24. I have had great success with diesel and so so with penetrating oils. Once you give it a go with synthetic transmission oil the smell usually is gone. Another suggestion is to use heat like from a heat gun or propane touch and when it is hot hit it with oil for a fast cool down. That may free it. kgg
  25. I would get a wire brush and scrap all round the unit particularly around the feed eccentric seam and then add a few drops of good old fashion diesel around the feed eccentric seam. Wait about 24 hours to let it soak in, a few light tabs with a hammer and without any needle or bobbin run it at different speeds for a few minutes. If it hasn't freed up start over with a few more drops of diesel. Once freed oil the heck out of it with some synthetic transmission oil. If you can't get it freed like @CowboyBob has suggest replace the unit. kgg
