kgg
Contributing Member
Everything posted by kgg
  1. I only have two suggestions about your site. Need an "About Us" tell a little story highlighting the main stuff like location (close to the beautiful/historic ...), sole owner/operator, experience those types of things and more "Contact" info where you are located so that people can easily see you are in the US, phone number, hours of operation. All the above due have their pros and cons. kgg
  2. If I remember correctly someone had a Techsew 1460 with a similar problem and Ron at Techsew got him fixed up. kgg
  3. Contact the company you purchased the machine from. It looks like it was dropped hard to go through the packing and create holes in the plywood. kgg
  4. I like your glue pot, simple and effective. All you need to do now is get the cost of the top down. Wow what a difference between the Amazon US and Canadian sites for the same simple item. That is why some of us Canadians who live close to the border (1/2 hour drive) have a American address for companies who won't ship to Canada and for companies who offer free shipping within the US. It wouldn't be feasible for one small purchase but on the larger or multi items it can save you a lot. kgg
  5. I would pass on the offered domestic portable machines. Yes all three can on occasion get you out of a bind but that would be it. You can even get a walking foot thingie for some of them. I think going to a domestic and trying to make it work will be at best a frustrating venture. I do agree that RJLamie does need a different machine for light weight leather work and machines being offered are what someone has in their store but neither are going to be suitable for a number of reasons (thread limitations / reliability / durability / feed mechanism). If budget or space are a concern I do agree with chrisash that a low cost portable walking foot machine capable of using the 135 X 16 needles would be better suited for light industrial use. For the price of a Sailrite portable walking foot you could probably get a new clone industrial walking foot machine / table/ servo motor but for under $500 new there are many other options available like a Consew CP206R, Reliable Baracuda, Techsew 611 to name a few. Then there is of course the used market. The minimum requirement I think would be that the machine be a walking foot. kgg
  6. Is this a new machine to you or a recent problem? I would unthread everything both top thread and bobbin. Check that the needle is installed correctly with the scarf in the right direction and fully seated. Reinstall top thread checking thread removal from the spool, tension / paths from the spool to eye of the needle. The needle must have the long groove on the left and threaded from left to right. Then thread a different fresh bobbin checking for correct thread tension and correct direction of how the thread is being removed from the bobbin in the bobbin holder. Then I would hand wheel it through a dozen cycles with fabric under the foot while holding both threads for the first couple of stitches. kgg
  7. Assuming that both machines are producing good stitches and in roughly the same condition I would base my decision on which one has the most repair parts readily available and at reasonable prices. I do know that the cobbler in Perth, Ontario a couple of months ago was getting rid of his Adler patcher's for $500 Canadian each due to the lack of both repair and parts support. kgg
  8. Different continents and different climates have different construction needs. I am curious as to why you are going to paint the pressure treated timber the 2x4's and 2x6's which may in fact cause moisture to be retained in the timber. Over here the newer methods of pressure treatment of timber does not go to the core of the timber, just a mild penetration so the majority of the timber is still natural which will still have moisture. My thought process would be that painting the whole exterior of the timber you may prevent the core moisture from escaping and it would rot from within. You also mentioned that you are planning on joist hanging the 2x 6 floor joists and the plans show their attachment to a 2x 4 bottom plate and the 4x6 sill plate. Why not just place 3/4" threaded bolts in the centre of the 12" x12" concrete foundation spaced every couple of feet when pouring and leave them protruding about 6" above the top of the concrete foundation. Then the next day when the concrete is solid enough install your damp proof membrane then bolt two 2"x6" on their flat all the way around on top of the concrete. Usually done so the second layer of 2"x6" joist plate overlaps the seams particularly in the corners left by the first layer of joist plate. The 2"x6" floor joists would then rest on the joist plates extending to the outside edge of the joist plate and then toe nailed to the double 2"x6" joist plate. This would be a lot less work, increase head room (very slightly) and provide a structurally stronger floor. Then deck over and install the walls on top of the floor. Depending on the load of what you are putting in there you may need to go with a 12" joist spacing or larger joists. I am assuming you are planning on using 5/8" or 3/4" tongue and groove plywood decking / floor. Plywood would be stronger structurally, smoother surface and wear better. I would still consider putting down a vapour barrier over your sand and stone in the centre of your foundation to help prevent ground moisture from getting to the floor. kgg
  9. I have a couple of suggestions on your construction. In Ontario what is starting to become more common home construction is called wrap and strap. Starting from the interior of the building: 1/2" gyproc (just substitute 1/2" OSB for your needs), super 6 vapour barrier (vapour barrier needs to be on the winter warm side), 2x4 horizontal studs spaced 16" up from the floor to ceiling, 2x6 vertical studs with cavity between the vertical studs insulated, exterior OSB, 2" of rigid insulation and then the siding. The advantage of the wrap and strap for your needs would be the horizontal studding, it would offer better structural strength for hanging stuff off the walls and for routing electrical / water lines in the walls. In your floor I would recommend rigid insulation to keep the cold and dampness from coming up through the floor. However an insulated concrete slab-on-grade would be much more structurally sound and warmer (10" compacted crushed stone, two layers of 2" rigid one going north to south and the other east to west then concrete). As far as the roof goes you should put insulation and vapour in to keep the summer heat and winter cold out. The more you can get in there correctly will make a huge difference which may affect your roof design. I don't personally like blown in foam insulation as if it is not done properly it will not cure properly and the place will smell like rotten fish as it off gases. kgg
  10. Got them off Kijiji there were 50 - 1 lb rolls individually factory sealed from someone who bought a shop and didn't need / want them. So since I was looking to replace the bonded nylon with something that would stand up better I gave it a try. For the price not much to lose if it didn't work. kgg
  11. I like bonded polyester for a couple of reasons. It comes off the spool / bobbin more evenly and stands up to bleach much better then bonded nylon did. My stuff is mostly dog related items of thick multi layered, multi type material that does push the limit of what I can stuff under the foot of my machine (Juki 1541s). The thread has to be able to withstand multiple washing/disinfecting/drying cycles (50 -60) in a eight week period. I would be lucky to get one 8 week cycle period out of bonded nylon before some items would need thread repair or replacement. Changing to Coates Dabond bonded polyester thread has significantly reduced thread fraying / failure and now items get at least 3 eight week cycle periods before they need thread repair or replacement. Just my experience. kgg
  12. It is good to be little cautious and maybe with a touch of paranoia thrown in when making a large investment of money into a machine or machines. Don't forget to bring some of the material and thread in the sizes you want to work with along with you to those dealers. By doing that there will be a fair comparison between machines. Some machines don't work as well with a particular material thickness / toughness, type or thread size then others do. kgg
  13. Work tables which are comfortable to work at vary from person to person depending on the task at hand and their height. What I have found to be a comfortable height of the top of the work surface is the measurement to the floor as measured from the top of my belt buckle to the floor wearing the footwear that I normally wear. Some people even through they my be the same height one person my have shorter or longer legs. My table would be to high for my wife (5'-4" stretched) too comfortably stand and work at while it would be to low for my son (6'-1"). My work table is normally 48" x 48" with two 8" wide sides that are hinged to the main table that I can raise to extend the width out to 64" when needed. At present my total area for my stuff (materials/ equipment) is a 10' x 12' spare room. kgg
  14. Very nice job of showing its abilities. Did you decide on a sewing machine? kgg
  15. That is great news. kgg
  16. Just give them a call and see how that goes. I spoke with them a while back about some edge binding material but was able to use some scrap ripstop instead that I had around. I haven't purchased from them yet but I am going to need some V92 bonded polyester in the near future but for now I have plenty of #69 (bonded polyester) and #138 (bonded nylon). I prefer the bonded polyester over the bonded nylon. kgg
  17. You may want to try Cansew for the thread they are also in Montreal. I can understand you not wanting to drive in Montreal. I hate it every time I have to go there or through there especially with an Ontario plated vehicle. kgg
  18. I also can only see two pictures. Have you thought of using really thin HDPE as reinforcement. The drawback with rigid reinforcement that I would be concerned about is that would need to be attached to the leather, sewn or glued, and as the leather ages it probably would stretch with use. That may lead to wear through from the inside. kgg
  19. Bill this youtube video maybe of some help. As far as adjusting bobbin tension I think there is a screw on the side of the bobbin case holder around the five o'clock position that you screw in to add bobbin tension or out for less tension, make small adjustments like 1/16 of a turn. From an engineering point of view all sewing machines are intriguing marvels of machinery that basicly haven't changed in the last hundred years. Particularly when come to think of how everything has to be in perfect sink to lock together two simple pieces of thread to form a simple tough stitch to attach pieces of material together. What would be a nice improvement to sewing machine engineering wouldn't be more efficient motors, more computer controls or stitches but the elimination of having too wind bobbins and have the bobbin thread come off a large thread spool from underneath the machine. kgg
  20. We all have to start from somewhere. This site is a great resource. Enjoy your Christmas dinner, just put ours in the oven and hopefully it's going to be great as it is my first time, yes my first go ever cooking Christmas dinner. Should be a chuckle. kgg
  21. The owner must have miss listed the info as the manufacturer of the machine is "Consew" the model is probably a 227 so just do a search for Consew 227. The Consew 225 is a flatbed not cylinder machine. Merry Xmas kgg
  22. I looked at your video and what I noticed was that I think you may have threaded the needle incorrectly. It is a little hard to see blue thread on blue material. The needle has to be threaded from the left side of the needle with the scarf (long scratch on the needle) facing directly away from the bobbin then through the hole in the needle towards the bobbin. I think what's happening is that the top thread is actually breaking around the bobbin hook area or being pulled back through the eye of the needle as the hook passes and then getting wrapped around the bobbin case. Also I would recheck the installation of the bobbin in the bobbin case to make sure it is correct. To check, remove the bobbin from the bobbin holder and with the bobbin in your right hand grab the thread with your left hand. Pull the thread to unwind some thread from the bobbin. The bobbin has to rotate counter clock wise in your right hand. If it does then drop it over the centre pin of the bobbin case and lock the centre pin down over the bobbin and rethread. kgg
  23. You never mentioned what size of thread you are using on top and in the bobbin or the type and size of the needles that you are using. My first thoughts would be to unthread everything top thread and bobbin. Reinstall top thread checking thread tension / paths from the spool to eye of the needle checking needle is installed correctly (right direction of scarf and needle fully seated). I would then thread a different fresh bobbin checking for correct tension and correct direction of bobbin spin in the bobbin holder. Then I would hand wheel it through a dozen cycles with fabric under the foot and with the bobbin cover plate off to watch as how it is trying to pickup the bobbin thread and sew. kgg
  24. Merry Christmas and a Happy New Year to one and all. Enjoy, be safe and sew on. kgg
  25. The Janome DC2012 and the sweet little Singer Featherweight are both not going to last or are capable of trying to do the leather working patterns that you indicated. A brief look at the patterns it seems like they are using at least v138 thread which both machines cannot take or have the ability. Both machines are meant for light fabric materials and yes you can get them to do it once in awhile on bit heavier stuff. I rebuilt a Singer Featherweight 221 a couple of years ago just to bring the it back to life and see why they are so very popular with the quilting people. Personally I didn't like it and sold it very quickly for a small profit. Yes it did a nice even stitch, was compact and weighted next to nothing but it was very weak on any more then a couple of layers of light material. You mentioned sewing multi layers of felt and then leather together in your post. For this I think you need to look into the purchase of at least a portable walking foot machine that can handle up to V138 thread. There are many companies that sell these machines like the Reliable (Barracuda), Rex (607), Sailrite(LS) and Techsew (611) to name just a few which should be able to handle your mentioned project. kgg
