kgg
Contributing Member
Everything posted by kgg
  1. My take is i) The PFAFF is a brand name while the Typical is a clone. ii) the PFAFF info I have seen The "H" indicates the lift of the pressor foot where H1 and H2 are 7 mm and use the 134 needle system, H3 are 11 mm and use the 134-35needle system while the H4 has a 14 mm lift and use the 190 needle system. The "L" indicates it is rated for leather versus "S" is for fabric. iii) Parts and accessories for the PFAFF's in general are expensive and for some models not readily available. iv) The PFAFF thread capacity is generally limited to V92 for the older machines and the new model limited is limited to V69 I wouldn't personally purchase either as both are going to severely limited not only the thread size but the thickness that can be sew. What are you planning on sewing maybe a better way to approach choosing a machine?? What country are you located in. kgg
  2. Why??? Just use the Juki manuals. If I am not mistaken your machine is a clone of the Juki LS-1340 series of machines. Here is a couple of real manuals for you to look at. The question is why is your machine having a timing problem? What thread to needle combination are you using in how thick of material? kgg Juki LS-1340&42 Servcie Manual.pdf ls1340.pdf
  3. The Chinese companies can make decent quality items but that will depend on the specification they are asked to build the item to. I have gotten presser feet as well as other items that where at both ends of the spectrum. Some items end up in the garbage bin. Keep in mind PFAFF is now owned by a Chinese company, SVP. Is their quality the same as before 2006???? kgg
  4. Sorry to hear of your experience. kgg
  5. That is a very nicely done paint job and love the color. Only you can say it is too much work but here are a three video's which may help. i) Feed dog cam how you set the height and replace the yolk over the cam --- fairly simple Singer 111W155 feed dog lifting cam and fork ----- ii) This is for a Consew 226r which for your Singer should be very similar if not the same. Check out the 6:53 minute part of the video. Consew 226r Large Bobbin conversion Juki LU-563 ----- iii) For your stitch length problems this video explains how the stitch length works. It is for a 111W155 which is the same as the 111W153. Note if the main shaft has a lot of movement from front to back you should check and see if a set screw hasn't backed off or you have a bad shaft bushing. If the stitch length mechanism is worn out replacing it means the whole bottom end needs to come apart. I would consider that to be a ugly job. Youtube would allow me to embed the video. Singer 111W155 Stitch Length Selector ----https://www.youtube.com/watch?v=IsbquYazHx0 kgg
  6. Does it have a tight spot without the drive belt installed on the machine? Before I would attempt replacing things I would give the internals a really good oil bath and flush with some synthetic transmission oil combined with some light synthetic oil to penetrate deep in all the bushings surfaces and bearings. Looks like a nice color for the paint job. kgg
  7. I think these are probably a specialty clip that is produced solely by or for Sleepypod as the clip has sleepypod molded into the face of the clip. You could try and order one from Sleepypod in the size you would like. kgg
  8. I am going to assume when you say "flywheel" you mean the hand-wheel that the drive belt from the motor is on. The hand-wheel: i) the hand-wheel slides over the main shaft which has a groove ground into it. ii) hand wheel has two set screws. One that seats down into the groove of the main shaft and the other set screws seats onto the the round part of the shaft. If the hand-wheel slips chances are the set screws weren't tighten down properly or the groove location is damaged. If the set screws weren't tighten properly with one in the groove then the hand-wheel will slip / spin. You probably can just regrind the hole so there are no burrs to tear up the thread. It maybe just the angle of your photo but it appears you have the needle in backwards. The long groove going up the shaft of the needle has to be on the left and the scooped out part of the needle (scarf) on the right so when the thread is threaded from left to right the thread slips down the groove to the eye of the needle. kgg
  9. Maybe try Ailexpress for something like this: for about $0.53 https://www.aliexpress.com/item/4000204100606.html?spm=a2g0o.productlist.main.93.326chJ3BhJ3Bx3&algo_pvid=d6a455b0-fe99-4dfe-b30a-dca3ace3c4f9&algo_exp_id=d6a455b0-fe99-4dfe-b30a-dca3ace3c4f9-46&pdp_npi=3%40dis!USD!2.18!0.39!!!!!%40212240a316873568966258263d0787!10000000776821401!sea!CA!4496536814&curPageLogUid=42ffrQ11iGMV kgg
  10. Thank you. Good point I will keep an eye on that. kgg
  11. Try searching for swivel hooks, swivel snaps and or swivel snap hooks. kgg
  12. Thank you, I figure the leather sleeve will out last the recliner. kgg
  13. This type of guide is used with typically two needle machines where the thread from one thread spool goes through the holes on the left of the bracket and then to the bottom thread guide before the tensioner and the other thread from the second spool goes to the one on the right which would have second thread guide place in the where the screw in the photo is on the right side of the bracket. It can offer extra tension and also keeps the two top threads separate so they don't get tangled up when sewing. A example can be see on this video: ( www.youtube.com/watch?v=uxLo85ClZ2U ) kgg
  14. I am assuming the top head casing is a separate casing then the cylinder arming casing and maybe able to be moved / twisted slight to get rid of the 1mm difference between the front and rear as you noted in the photo. Otherwise it is just a slight error when the machine was cased. kgg
  15. Those mag base are great aren't they. I figure you got a few choices: i) Strip the machine down to bare bones and reline the casing and replace the main shaft. However that may not solve the problem as other bushings / guides maybe also be worn slightly off. ii) Shave a bit off the part that hits / comes close to striking the other. However that will not fix the problem. iii) Run the machine machine until it gives you problems or requires other parts. Use a synthetic oil rather then sewing machine oil for lubrication. How long it will last who knows. I think that will depend on how fast you run the machine and how often you are going to use it. I wouldn't be in rush to replace the machine until a problem that effects the stitch appears but I would keep an eye open for a new or newer machine. kgg
  16. Is the main shaft slightly buckled??? I would check with the tip of a pencil on the shaft and see if it marks only in one spot as the shaft is being rotated. If it puts a mark all the way around the shaft is good, if it only marks the shaft in one area the shaft is bent. kgg
  17. Thank you. It's something simple and is going to be used a lot. kgg
  18. One of my recliners is fabric and the foot rest material wore out and looked terrible. I could have stripped it down to the board but if I reupholstered it with fabric it would eventually wear out and it would be a one of. So I finally decided on making a simple functional leather veg tan sleeve that could be reused on another recliner at some point in the future. I used: i) 3 oz natural colored vegan tan ii) Fiebings Pro Dye in British Tan iii) Udderly Smooth (cream consistency ) iv) Mink Oil (paste consistency ) v) 1" Velcro vi) V138 thread vii) copper rivets viii) 1inch "D" rings ix) 1" foam x) LS-1341 clone cylinder arm xi) heat gun I would have poured the dye the leather by soaking it in a container but I didn't have one that was wide enough so I used flat plastic butter container and used paper towels to apply the dye directly by hand. I was surprised at how good the paper towels worked on a large surface of spreading the dye around. I hand rubbed Udder cream on after I dyed the veg tan when it was almost dry which did create a tan colored foam on the surface of the leather and left it to settle overnight. The next day I then wiped off the excess and applied the first heavy coat of Mink Oil paste letting that dry for about 12 hours before using a heat gun to force it down into the veg tan. I then let it sit overnight, re-applied another heavy coat of Mink Oil and hit it again with the heat gun to force some more into the leather. I then wipe the access oils off and did notice there wasn't any British Tan dye on the paper towels. Which I figure is good a thing as the British Tan sort of matches the color of the fabric but might not go great with white pants. Any comments / suggestions are always appreciated. kgg
  19. @Handstitched I am so sorry for your loss. My thoughts are with you during this troubling time. kgg
  20. My take on needle positioner: The controller is basically factory set so when it receives a input signal of a certain time duration in milliseconds from the needle positioner that is basically monitoring the position of the hand-wheel shaft. From the position of the hand-wheel shaft the position of the needle can be determined as it goes though it's up and down cycle. From the position of the hand-wheel shaft the controller then knows the distance that the motor has rotated and where it needs to be for the needle to be in the up or down position. When you throw in a speed reducer it changes the distance the hand-wheel has traveled (rotated) in a certain time frame (msec) so the input signal back to the controller from the needle positioner now is off as compared to the factory settings. When that happens the controller assumes the hand-wheel is in certain position hence the position of the needle but in reality the hand-wheel is in another position which means the needle is also in another position. Some people love the needle positioner and others not so much. I happen fall into the not so much group myself but that will depend on what you feel best suits your needs. kgg
  21. I assumed the ragged thread was just that the end raveled out for an unrelated reason. At the 20 sec mark you can see the needle plate has received a few strikes over the years for one reason or another. Were any as a result of this incident who knows. If the top thread is allowed to flap out from the needle like in the video any top tension the top thread may have had is lost. Since bird nesting is usually an indicator of inadequate top thread tension I think it would be my first place to start. So I would replace the needle, re-thread the top thread from the thread spool to the eye of the needle, examine all the guides and tensioners. It appears to be V138 thread maybe V207 but it is hard to tell the size from the video so I thinking a #23 or # 24 for V138 or #24 or #25 for V207 depending on leather thickness. I would also replace the bobbin with a fresh bobbin just to make sure it was installed, tensioned properly and inspect for any old thread. kgg
  22. Just to add here is a good video of threading the Rex 26-188: Note the video at 2:11for threading just before the threading the eye of the needle verses how your video shows it threaded at 09 sec. kgg
  23. In the video at 09 to 14 sec you can see there is no tension on the top thread. The top thread is not in the round guide at the top of the needle on the needle bar. Did you thread this guide with the same result? Did you replace the needle with a new one after the original problem happened? kgg
  24. I looked at your first video as the second video seems to be not working. A couple of points I see: i) you are not holding the bobbin thread and the top thread you seem to be holding it forward ii) the top thread should go through the last guide just before going to the eye of the needle. Suggest checking your top thread path. What size of thread and needle combination are you using. I'm assuming you are using the same size thread in the bobbin as for the top thread. kgg
