kgg
Contributing Member-
Everything posted by kgg
Leather smell, storage smell, mildew smell?
kgg replied to Redbeeerd's topic in Leatherwork Conversation
Are you sure it is mildew, not mold or a combination of both?? Mold is usually stronger smelling while mildew smells more musky. If it is mildew which grows on the surface and you maybe able to clean it off if it was caught in time but if it is deep within the fibers it is probably mold. My opinion is whether it is mildew or mold get rid of it both can cause health issues. kgg -
As Quade said a 550 watt is the smallest size but should be quite capable of doing the work. The first one noted is of a 550 watt brush type servo motors. The second one referenced is a brushless servo motor with electronic controls. Like dikman suggested to get more stitch by stitch control adding a speed reducer or increasing the size of the handwheel is the way to go. I don't use the brushless electronic controlled servo motors as I like to keep my machines a little more basic, hit the go pedal and the machine runs. Motor will not run change the brush's. The electronics for the motor just adds another layer of complexity of trouble shooting when things go south. Depending on what country your in the brush type servo motors may or may not be as expensive or readily available as the brushless electronic controlled servo motors. kgg
I am probably an odd one as I only use synthetic oil in all my machines, new or old. An example is a Singer 29k-71 (1998) that I did own that also had a helper domestic motor installed before being originally sold by Landis. I did do a short video on how it sounded and the ease at which the machine could be hand cranked. https://odysee.com/@SingerSewing:0/singer:a kgg
Old Singer machines suitable for leatherworking?
kgg replied to Redbeeerd's topic in Leather Sewing Machines
This maybe not the ideal machine to start out with but for $40 dollars I can't see how you could go wrong buying it. At some point you will find a need for a patcher. These are pretty versatile machines as they can be can be mounted to any flat table surface and hand cranked or mounted to a proper treadle base. Some of these machine were even driven with a domestic style motor mounted to the rear of the base. kgg -
I wouldn't get rid of it. If you want or need a different machine and it is taking up valuable space I would grease the Singer up and break down the treadle so you can properly store it. kgg
I would try either a light soaking of the screw with a couple drops of diesel or some synthetic oil for a day or so and then hit the screw with some heat in a safe place. When you have heated the head I would give the screw a couple of light taps with a hammer before trying to turn the screw. I wouldn't be too aggressive as you may shear the head off. If you can get a turn, even a quarter of a turn let it cool then reapply a couple drops of diesel or some synthetic oil again for a day or so. There is probably a proper wrench but as a suggestion if a coin fits in the slot of the screw head I would cut or grind down the coin down too get the most metal into the slot of the screw head and then clamp the coin in a pair of vise grips. Since the handwheel is wobbling I would like Constabulary think it would be best to replace the bent shaft rather then trying to re-straight it once you get the handwheel off. Also check the body for cracks or fractures as a result of the impact that cause the problem. kgg
- 11 replies
- parts needed
- wobble in balance wheel
(and 2 more)
Since you are in California maybe check out some places like Altas Levy (Atlaslevy.com) or the Cobra Class 4 machine from Leather Machine Company ( leathermachineco.com ). They should be fairly close to you and you could drop by with some of your items and test drive some machines. kgg
The 441 class machines like the Juki TSC-441, Cobra Class 4 or the Cowboy 4500 are designed for sewing heavier items but I think you will need a second machine like a Juki DNU-1541S in a flatbed or a Juki LS-1341 cylinder bed with a flatbed attachment or their clones to cover off your bases for the lighter weight items you listed. No one machine will do everything. If you are mostly going to do really thick stuff get a new class 441 machine and a second hand upholstery class machine and set them up to a particular task or vice versa. kgg
I do agree as I have at auction got good deals and recently got some really nice (600 sq ft of 6-8 oz) leather in approximately 25 square ft hides for 0.70 cad (0.51 cents usd) per square foot as the business owner had recently died. Buys are out there but you need to be cautious. kgg
From you photo's I would say a old long arm Alder 30-1. kgg
I would be very wary. There are a lot of scams around and there was a similar one a couple or so years back regarding sewing equipment. There seems to be a lot of questions that need to be answered. Who referred you, who is he, where is he located, the list goes on and on. If it sounds to good to be true it probably isn't. kgg
All lot is going to depend on i) design / splicing software ii) the quality / type of filament iii) the quality of printer iv) nozzle size v) whether it has a heated bed and most importantly vi) your budget. I use Prusa printers and find them to be really excellent machines. kgg
Why not go to a few tannery's, I'm sure there must be some in Turkey. They would be able to show you leather of various qualities and any defects that occur throughout the tanning process. kgg
Merry Christmas to everyone everywhere. Preparing for the Grinch Storm here in Ontario. Stay Safe. kgg
Thickness and most importantly breaking strength. The V92 has a breaking strength of 14.5 lbs. while V138 is 22 lbs. A good chart for needle and thread size selection can be found at ( www.tolindsewmach.com/thread-chart.html ). kgg
I looked at their website and didn't see what size and type of needle they supplied with their machines. For that machine the needle system needs to be a 135 x 16 for leather where as the 135 x 17 is made for fabric. I would suggest a buying V92 and V138 thread for your needs. A excellent thread made in the US and Canada would be American & Efird ( www.amefird.com ) which you can also get from places like Wawak ( www.wawak.com ) in either bonded nylon or bonded polyester. Bonded polyester offers better UV protection then bonded nylon. kgg
Singer sewing machine 132K6 top thread problems
kgg replied to Mapleseeker's topic in Leather Sewing Machines
I am not familiar with a Singer 25KY needle. The needle from the info I have seen for that machine calls for a DDX1 needle system and for the thread V92 that you are using in a size #19 or #20 or #21 depending on how thick a material you are trying to sew. The needle needs to be inserted so the long grooves are on your left and the thread is threaded from left to right, Page 5 and 6 of the manual I have attached. kgg Manual Singer 132K6 Seiko SK-7 SK-8 SK-26 - II (1)-1.pdf -
First what size thread are you using with what needle size and system? From the last photo it appears you have the needle in backwards. A better photo of how you have the needle installed would help. kgg -
Dürkopp 17 Patcher - Sunday Morning Barn Find
kgg replied to Constabulary's topic in Leather Sewing Machines
I have been following your progress from a barn find to a beautiful old iron machine and the job you have done is just excellent. kgg -
Make a trip to a sewing machine repair / sales shop. kgg
I honesty don't know. I've never dove into that aspect. kgg
There are a lot of "after" market parts available for all the Juki machines but for the most part of the same quality or tolerances as that of real Juki parts. I don't even use non Juki bobbins in my machines as the tolerances are all over the place with the cheap aftermarket ones. Yes, you will pay more but they are going to work properly. I would call Juki USA to find Juki dealers near you and explain to them the problem you are having with your tension issue. They may recommend using the Juki LU-1508 NH parts. kgg
Yes, this type of thing can drive you nuts just like the screws which go into the top of the cylinder arm of the Juki's LS-1341 and clones like Techsew 2750 or Kobe Ls-1341. It is a "Juki" thread and right now were costing as high as $4.50 CAD ($3.30 USD) each. It took me forever to track down a Chinese copy at what I would consider a reasonable cost. The cost of odd ball dies would probably be prohibitive for small runs. kgg
Most of the ones that you see for sale on the used market have been used in an industrial setting so probably seen a lot of use which would be reflected in the price. The one you reference appears to be in really good condition with little use. That one if it as good as it shown it's worth the price in my mind. The Juki LS-1341 is the original and are made in Japan with a hefty engineering, manufacturing, advertisement and quality cost attached which is reflected in the new purchase price. Clones are typically out of China or Taiwan. There are a lot of clones, some are good while others not so much. kgg
The price to me seems a bit high but that will depend on your area. In Ontario, Canada a used Juki LS-1341 usually go for about $1500 CAD or approximately $1100 USD complete with servo motor and table. A couple of things to look for: i) is there grooves cut into the thread guides which will indicate a lot of use. ii) paint worn off the body and amount of wear on the foot pedals and frame as well condition of table. iii) check to make sure the built in bobbin winder works properly. iv) the machine should not have any unusual sounds like banging / rattling. vi) the machine should have no slop in the needle bar or other shafts. vii) the machine should sound and feel smooth both when handwheeled over and when running under power. viii) tip the machine and look at the drive belt and all the bearing surfaces for wear / heat discoloration. ix) the original handwheel should be gray in color x) a Juki LS-1341 should have the name " JUKI "in blue above the reverse handle and the permanently attached nameplate / serial number / model number to the left of the stitch length dial. If the machine looks like it was rode hard and put out wet I would pass. A picture of the listing may help to spot other things. kgg
