VabaX
Everything posted by VabaX
Short answer: you cant. Long answer: leather (especially veg tanned) naturally darkens and browns over time. That is simply a fact of life. If its a dyed leather, like dyed by the tannery, to have white pigment in it, the process might be delayed or somewhat diminished, but it will still change. The best way that I can suggest to preserve its current appearance as long as possible would be to coat it in resolene. Once dry it doesnt change the leathers colour from what it currently is, and in my personal experience seems to arrest the exposure-driven darkening to a degree, but again, it wont permanently stop it from changing. At least what it will do though is stop it from getting dirty or grubby from use, which causes that gross black/green discolouration that some people here mistake for 'nice patina' Aside from that, the only way to keep it white is to paint it..... Other white leather goods that you may have seen from established manufacturers, idk purses, bags, etc, are (if even real leather) most certainly made of chrome tanned leather, which is an entirely separate beast
I just use a large ball peen. I say 'large ballpeen' because really its the same sized head as a normal hammer you'd use to hit nails (obviously dont use one that has hit nails before), but has the ball peeny bit on the other side, and isnt' as unweildly
My second wallet labrador design
VabaX replied to Matty101's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Same here. My only wish would be that he included a demonstration of performing the exact same stitching technique, but upside down/ mirrored (ie. instead of stitching with the bottom of the slants towards you, stitching towards yourself, you stitch with the bottom of the slants towards yourself but stitch away, such as when doing the opposite side of an item but starting and finishing in mirrored position, without using obverse/reverse stitching orientation (same orientation on both sides)). It's not physically hard to do, but it just took me many frustrating hours of fiddling around to figure out how to do it. -
Well obviously it's going to need a welt on both sides. I take it by "spacer", you are refering to a welt? I fail to see how using kydex would be too bulky, seeing as when used properly it pretty much always results in far slimmer profile than leather. I think it's just a fact of the physics of the thing that any welt on the inside edge of the blade is going to be at very high risk, and over time perhaps certainty, of being cut through.... That being the case, I might be inclined to conclude that leather simply is not an appropriate material for this use case, but thats a matter between you and your client
Hmm, I see. I've had absolutely zero experience with laser cutters, but they sound pretty mad. So you laser cut, then dye, then resolene? or do you dye and resolene and then laser cut? (thus leaving the holes un-resolene'd?). Either way, first question; is the colour/tint of the discoloration in the thread actually consistent with the colour dyes that you use? eg, is the discoloration black/grey when you use black dye, medium brown when you use medium brown dye, etc? Just to rule out the possibility that the burned holes could be causing it, thats all. If you cant be sure, mabybe follow your normal process on a test item, but simply DONT dye at all, and see if it still gets discoloured. If so, you know it's not the dye. Second: I know waxed thread is generally the standard for this hobby, but i actually dont use it, and I dont' even wax my own thread either. I stitch with completely unwaxed poly thread, and as i said, i dont have any problems with discolouration with the exception of my own dirty, sweaty hands. If the waxed thread you're using is one of those very heavily waxed ones that looks like you could just about wax your car just with a bundle of the thread, then I wouldnt be surprised if the wax was picking up some contaminants, but I couldnt give you a definitive answer on that. Could be worth testing it out, even irrespective of whether the thread is to blame or note. trying different products etc is the only way to improve what you do.
Never done a belt myself, but i'm doing a full sized compendium at the moment, and I'm feeling the pain. I've got just over 500 stitches in total, and doing it all on the one thread. doesnt help that i probably started with too much thread, so its a bit of a ridiculous amount to pull through each hole, but the last couple times i've dont largish items i've started with too little thread, and only made it to the end by the skin of my teeth . maybe once i eventually finish it, i'll let you know how long it took
I'm not exactly sure what your usual process/ order of steps is, but I've never had this issue, and I build my pieces as follows: Cut out the pieces Edge creasing on edges of card pockets burnish edges of pieces like card pockets Dying - using airbrush coat all pieces in resolene - one normal coat and then a second light pass once the first has soaked in glue pieces together punch stitching holes and then stitch burnish final/main edges of item As far as I see it, there are 2 main things to note about the way i do it that may explain why i've never had this problem, the first being, as Tom suggested above, the order in which the steps are done, and secondly, the fact that I do my dying with an airbrush, and so only a very thin amount of dye makes its way into/onto the leather in the first place, potentially meaning that there is far less (or none at all) 'unset' dye sitting on the leather. Certainly, after applying the resolene, any small amount of 'unset' excess dye becomes captured within the resolene as it cures. I do plenty of items using feibings black, navy blue, dark chocolate, etc, dyes, and even with the brightest of white threads never have any issues with the thread getting dirty, with the exception of when the dirtiness is caused by my own hands (i wear gloves whenever it looks like this may be the case)
Sticking with chisels instead of pricking irons...
VabaX replied to scrapyarddog's topic in Leatherwork Conversation
Well, I just use a set of sharpened pricking irons as if they were chisels, and my stitching looks great imho you get the significant slant and the narrow opening of the irons/awl combo without having to mess around with an awl, and the benefit of needing to do nothing more than keep going in a straight line keeping the iron vertical to get perfect holes like with chisels. only works with the right set of irons ( i use wuta, would probably work even better with KS) and on thin items (I have done up to 4 layers of kangaroo, but I couldnt say exactly how thick it was. would have been between 3-4mm) -
Two-layer belt question
VabaX replied to SouthernCross's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Holy crap man, 2 layers of 7-8 would like a light weight powerlifting belt. I do my belts out of one strap of ~9 ounce, and they're pretty solid belts -
One more chevre wallet
VabaX replied to datdraku's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice, I just gave you a follow -
Are any of their pre-cut straps thin enough to be used as a lining? you wouldnt want to end up with a 6mm thick belt... -
Do you use instagram? -
I might have to pick one of them up too. Do you use an awl as well? I have a set of the Wuta 3.38's and 3.85's, and they're narrow enough that I can punch all the way through up to about 3.5mm thick (after sharpening the prongs), so I never use an awl. Just wondering if that would still work if I go down to the 3.0's -
Very nice. I'm currently using the same sized thread, but 3.38mm spacing. I guess i'll need to step it down a level if I want to make mine look that fine. Do you use a heated edge creaser? -
Absolutely beautiful mate. Whats the stitching spacing/thread size? -
Hmm, yes, I should think that's likely the case. Possibly some liquids too, but tools etc would be 100% fine, unless your customs have some kind of weird kind of product-destruction fetish lol
Im in Aus, and i get most of my tools from Birdsall, they have a pretty large range of stuff, and they're much better priced than Scamdy (read: Tandy). Not sure if they have exactly what you're after, 'cos I cant tell what it actually is that you're after, but go have a look. They're based in Sydney.
2 different colors with the same dye and sealer
VabaX replied to BlackJoe's topic in How Do I Do That?
what method of dying did you use, and what sealer? -
patina Veg Tan Leather Finish (for best patina)
VabaX replied to Turves09's topic in Getting Started
Neatsfoot oil is very cheap. There are a few other types of oils, but they're all just as obscure as Neatsfoot is, so you'd still have to buy them specially for this purpose. Other oils like olive etc will go rancid, and wont 'cure' or 'settle' into the material properly. same reason as why you dont use those vegetable oils for oiling an axe handle or a tabletop, etc. Also, dont use mineral oils either, as that will start to degrade the leather and the stitching. Just get small bottle of neatsfoot or mink oil (should be easily less than $10). you'll find it at any leather supplies retailer. And as I said, a proper finish like resolene ontop to actually seal the leather, to lock in the oils and to block out any other contaminants that will make it go grubby. -
And you WANT me to do this to you?@!
VabaX replied to JLSleather's topic in Leatherwork Conversation
Any pictures of the offending item? -
Are you intending to patina it slightly before sending the product out, or merely finishing/preping it to age and patina for the customer whilst having a robust finish? I 100% agree with your remarks re many looking downright dirty. TBH the trend of 'patina at all cost' has gone 500% too far. some of those items you see around the place, on insta, etc, look like theyre literally rotting, while the maker proudly professes "fabulous patina after only 4 weeks!!" well how's it gonna look after 4 years? Like it's been siting at the bottom of a bog that whole time, thats how it'll look. I'd recommend a light coat of neatsfoot oil followed with (once it's fully absorbed/dried) 2 light coats of watered down resolene (everyone says 50/50 resolene with water, but i've found that to be far too much water, and almost starts casing the leather. about 70:30 resolene:water is about right in my book) or however many/few are required to get the desired level of gloss/matt finish you're after. That way, with the oil it will start with a bit of golden tint to it, and will still darken and age with exposure/use WITHOUT contracting a disease like how those totally unfinished products do, and will last many years longer because of it. Yes, it will age slower, but will be a more genuine aging process. EDIT: after reading your post again, the other replies in this thread talking about just neatsfoot oil; the oil will purely help to give a bit of colour to the leather and perhaps help it tan/bring out more of the tan colour as it does so, and help nourish the leather and prevent it drying out. Neatsfoot oil is NOT a leather finish, it does NOT seal the leather. If that is the only thing you apply to the leather, it will age like toilet wine and start to look infected as if it lives in a septic tank, with those gross black stains in the corners, etc. you NEED to apply a proper finish/sealant to the leather to prevent this from happening, or dedicate yourself to regularly cleaning/waxing the item (which you cant, since it's going to a customer). That is what will allow for the nice aging/patina'ing without becoming grotty. -
Honestly, this is a bit like going onto a forum that is dedicated to the art of diamond cutting, and asking the members if they know where you can source some cubic zirconia, or whether you should use moissanite instead....
Dying only the (laser) engraved parts of leather?
VabaX replied to blackmad's topic in How Do I Do That?
Depending on the leather and the tape, you might end up pulling some of the surface grain up when you pull the tape off. on one occasion i've put masking tape on leather before, cant remember why, but after pulling it off it had practically turned it into nap -
I have absolutely no idea, because i've never actually tried. I've just accepted it and embraced the textured look that it adds. I've tried to contact them about it before, but they never responded
If you're planning on burnishing that edge, I would steer well clear of any kind of rubber glue or contact cement, and its does not like being burnished over when its present in thick quantities (eg, any thicker than very light smear). I would use standard white wood glue, as it sands away easily and offers no issues to being burnished over. you'll just have to clamp it down for a short while as it dries.
