        Chakotay
                Posts90
Everything posted by Chakotay
	I tried my hand at a new skill: sand casting my own conchos. I would say the process was a tad more difficult to learn than I expected. However, after a couple of lightbulb moments (a few actually), I was able to churn them out pretty successfully. These are cast in tin, which is easy to melt and work with. I plan on making them in silver eventually.
	My P2 is a workhorse and my main machine for cutting leather. I use it to cut everything up to 10-oz veg tan. Also works great on cutting and engraving wood and acrylics. Haven't used the S1, but have used similar diode machines, including xTool's D1. It should cut everything the P2 can (except clear acrylic sheet). Is there a specific need you're wanting to make sure you can do on either?
	You could so a simple wrap like this. Just a matter of wet-molding the leather first and allowing it to dry. The video show the process. https://youtu.be/HAqhqOZzH6Y
	I'll go against the grain and say my lasers have become my most used and indispensable machines; even more so than my sewing machine! I do most of my cutting on them. I can create, modify, and tweak my patterns quicker and more accurately. I now also incorporate the stitch holes into my patterns. Makes saddle stitching a breeze.
	Sounds just like my Class 26. Guess that's just the way they sound.
- 7 replies
		- leather
- leatherwork
- (and 7 more)
	Are Basket-Weave Stampers Negligent!?!Chakotay replied to RVM45's topic in Gun Holsters, Rifle Slings and Knife Sheathes This. Though I often stamp the entire front and back as well ... just depends. Especially if the holster is a "Mexican-loop" style with a skirt (one I make frequently), there's really no reason to stamp the back side. It's literally never going to be seen.
	I'm definitely in the minority here. I only use water-based contact cements like Aquilim 315 and EcoWeld. I find them much easier to work with and plenty strong enough . . . though I'm using them to glue items that eventually get stitched anyway. The high-VOC glues quickly give me headaches, and I don't like their 'stringiness". Once you get to finishing your edges, rub them with a rubber cement eraser, sanding belt cleaner, or even a piece of denim. It will catch all the tiny gummed-up fibers and make your edges smoother.
	Etsy is my go-to for leather patterns. If you have a bit more to spend and don't mind the wait, there's Babylon Leather. It's an overseas outfit that sells physical patterns in either acrylic or cardboard. Huge selection of bag/satchel patterns and I've purchased several times from them.
	It's great for applying dyes and oil.
	Laser cutting and engraving Chrome Tan..What Respirator UPDATEChakotay replied to BDAZ's topic in 3D Printers and Lasers good to know.
	Isn't everything ultimately made in China? I've bought loads of tools, including a full set of piping feet for my Class 26 from Amazon. All made overseas. Works just fine. In many (most) cases, you don't have a choice.
	I've only had experience with LightBurn to run the machine. But as Bert03241 mentioned, I don't actually do any design in LightBurn. I create the design in Adobe Illustrator and import into LB just to position and choose power/speed/pass settings. As someone else said, Inkscape is another vector program that's a free download. As always, Youtube is your friend on all of these.
	You'll eventually want the ability to actually CUT your leather pieces out, not just engrave. Not sure if the Laser Pecker will do that (someone else can chime in). For around that price level, there's a whole host of open-gantry style diode lasers that will cut and engrave on Amazon. I have direct experience with the Creality Falcon 10W. It's a good machine for what you're wanting.
	check out about 13 mins in . . .
	Sold!
	If you buy a generic one of these machines, this video may be helpful. It absolutely works . . . but there is a learning curve. https://youtu.be/pG8j8ql2oIw
	Cutting heavy leather with the new Creality 22W laserChakotay replied to Chakotay's topic in 3D Printers and Lasers price
	Machine for making delrin stamp for leatherChakotay replied to luckystudio13's topic in 3D Printers and Lasers Alternatively, you could just drop $200 for a cheap MSLA 3D printer off Amazon . . .
	Cutting heavy leather with the new Creality 22W laserChakotay replied to Chakotay's topic in 3D Printers and Lasers I do all my designs in Adobe Illustrator. Inkscape is a good freeware alternative. Then import those into Lightburn.
	Cutting heavy leather with the new Creality 22W laserChakotay replied to Chakotay's topic in 3D Printers and Lasers I have not tried cutting metal with either of these lasers. Just leather and wood. Yeah, at the moment the 22W is a lot more expensive and I wouldn't be able to justify the price with my current production volume. Personally I would go with the 10W version and simply adjust the gcode settings to accommodate.
	Help choosing a cylinder arm machineChakotay replied to SandyinAnaheim's topic in Leather Sewing Machines I normally run #207 thread in my Class 26. I've even accidentally run #277 on the top (grabbed the wrong spool.) It ran fine.
