Everything posted by Frodo
When The Septic Tank Backs Up...
Frodo replied to Sheilajeanne's topic in All About Us and Off Topic
you said some idiot knocked a new hole in the old tank at a lower elevation? That tank is now useless, unless you can water tite seal the hole the idiot knocked in the tank. it is going to leak.. Leaking means the foundation under the tank will wash out and it will settle again.. -
I use pleather that can be bought locally for $6.00 36''' x 72'' sheets
- 29 replies
- foam padding for leather
- closed foam padding
- (and 6 more)
Sorry Jane. I am a Master plumber, This is my advice, have your local plumber: replace pipe from the house to the tank and replace tank cut the exit line out of the tank install a 90 degree elbow on the line going to the leach field add a 5' pipe to the elbow sticking straight up into the air fill the pipe with water and time the amount of time it takes for the water to leave the pipe hopefully your drain field is not saturated, but if the pipe is not draining, replace the field over dig the hole under the new tank. by 24'' add moist sand, water the sand with a hose, it will compact it set the new tank on a compacted sand bed NO LESS THAN 12"" -
I used to do that. Now, I just grab a bit of scrap rub some rouge on it and strop my blade I have used both sides and can not come to a conclusion that one is better than the other
place the pattern on the leather, use brown paper shipping tape over the pattern, and let it stick to the parts of the leather that you are not going to use see tis video, skip to 6:16 of the video too see how to mask https://www.youtube.com/watch?v=M3TeUWzPp-Y&t=6s How to print and use a Dieselpunk.ro leather pattern - YouTube
Contact member @chuck123wapati
Work look great to answer your question, You are in the business of custom work. You insist that it is constructed well, correctly and is durable. , But the art work, Do what they want, and keep your mouth shut I am a plumber by trade, I had a lady pay me to install a Kohler wild rose fixtures with polished brass fittings, Makes me want to puke every time i think about it
Steel Belt Liners
Frodo replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
In order to insert the steel band into a belt so that the belt is not damaged, use a belt sander to round the ends of the band Then glue the band into the center of a 1 1/2'' belt. I have never inserted a band into anything smaller than 1 1 /2''.. drill a hole in the ends of the band and rivet the band to the center of the belt. the band will not move and cut the threads. -
Steel Belt Liners
I use the steel 3/4'''' strap that is used to strap pallets. I make my belts 1 1/2'' wide, The strap does not move and cut my stitches. -
Hello Muppet, I am also a fellow forger.That gave it up If you need a forge, building one is simple and damn near free. If you have scrounging skills go scrounge up, 2- 55 gallon steel barrels/drums a cast iron brake drum and the exhaust fan out of an old house heater unit, looks like this
correct dialect?
My dying skills improved greatly when i bought a cheap air brush kit now I have control on the areas i want stained
你的工作得到了称赞 [Your work has been praised] Bad ass , gorgeous, beautiful, wowser, 这些都是俚语。 他们的意思是美丽的 [these are slang words, they mean beautiful]
HOT DAMN!!! I am humbled. Oriental design may not sell in your country, it will sell here in the USA I would love to see a foo dog or a dragon
Not usually at a loss for words, only one comes to mind WOWSER !!!!!
cat cat cat, how to upload more pictures in one topic?
Frodo replied to leathercraftsupplies's topic in Member Gallery
I had a really nice nikon digital. it was in my wifes lap, she stood up
WTH????? I swear i spelled that correctly. HAPPY MOTHERS DAY !! It is Friday, Collect from this mother and pay that Mother LOL Nice Picture btw, Is that your work or a stock photo? that was taken by a really nice camera
Happy Moths day Yall !!!!!!!!!!!!!!!!!!!!
All good reply's up top. another thing you can do. is use shorter pieces of thread. The longer the thread is the more times it gets pulled through a hole
Best of Coyote and Roadrunner (2) - Cartoon (english) - YouTube
You dont. toss that awl out the window. Here is 3 pieces of 9oz veg tan. run a stitch grove on each piece using your chisel. hang one tine off the leather as shown, this will ensure you are starting out at the same spot on each piece of leather glue your peices As you glue the pieces. insert a needle every couple of inches, this will help you keep everything lined up . then sew them. all pieces are lined up if you did it correctly
