Frodo
CFM
Everything posted by Frodo
  1. does this look beveled or just burnished?
  2. Howlback, If you like braiding then try making a whip I have made a few. they are time consuming and fun to do..
  3. This might help you in transitioning from a round braid to a flat braid
  4. https://www.stockcap.com/store/rubber.html
  5. use your table router and a jig
  6. Here is another boring cell phone holder thingy this will carry your cell phone has a pocket for credit cards a loop on the bottom for your ear buds a belt loop and an additional loo so you can hang this from your back pack mahogany and black with white stitches this picture is shown while the item is wet and being formed
  7. a lot has to do with the epoxy. and the way it is applied. first, always pour in 2 coats. the first base coat is very thin and that is where you get rid of the bubbles that are itrapped in the wood. after the first coat you can then pour with out worry of bubbles if the epoxy it mixed correctly. on my counter top. see the wood counter top. that is 1/2' think no bubbles in a 7' x 3' pour clear pour. no color using 2 coats. did you make another doggy for your little girl? that idea is sweet, i know she was tickled
  8. Dude !! That is AWESOME to the tenth degree
  9. poke it with your awl. if the wood is soft and crumbly . salvage the hardware and toss it in the burn barrel
  10. no, that is poured epoxy. with white and black dye i put in it then swirled it around cabinets got painted to match nd new floor looks different
  11. no pressure pot. he used a wisk thing for eggs in a drill.. i Spent cartridges go for $20.-- per hundred around here. sometime less look online for extreme epoxy for counter tops that is who i bought mine from. NOPE...new kind of epoxy. no bubbles if the directions are followed..look on line for extreme Here is 65 sq feet of counter top I did with out bubbles i mixed the epoxy, poured it, then used a hand held map gas torch to wave over the epoxy that rid it of bubbles IMMEDIATELY if you need help i will happily help out over the phone or by pm I would consider it an honor to talk on the phone
  12. Here is a neat project for anyone who wants to do it. Coasters for your table You will need epoxy for countertops and pvc pipe, the epoxy does not stick to pvc you can use anything you want, flowers, butter flys. your baby brother,
  13. if you dip dye, leave it till the bubbles stop
  14. elk lined, veg tan holster at a 20 degree cant
  15. Frodo
    Snap?
    That brings back memories The first thing in leather that i ever made was a taser holster I used a belt and believe it or not 22LR cases for rivets
  16. Frodo
    Snap?
    Frequent pulling the leather snap causes the hole for the snap to elongate . after a period the snap comes through the leather I am referring to multiple times per day . Not 1 time a day type use
  17. Frodo
    Snap?
    looking for recommendations for a closure for a cell phone holster that will be used frequently Magnet is not strong enough post would scrape every thing snaps wear out the leather Suggestions?
  18. I work with a lot of Military Surplus that is canvas and leather. Some of the old leather is in pretty bad shape when I get it This is what I do. And I do not know if it is the ''correct'' procedure. But works for me 1] clean. 1 part vinegar 3 parts water, clean salt stains and dirt 2] rehydrate rub neetsfoot into the leather, let it sit over night, reapply. repeat till leather is soft 3] Protection. rub mink oil into the hide, let it sit for 20 minutes then rub off 4] Wax. I wax the leather with Kiwi wax. I do not use any other Brand This is a shoulder holster that was given to me. He wanted to toss it in the trash because it was so dry I did the above steps, and use it
  19. I am using 2 layers of Boar hide on mine
  20. check out his other videos, Grandpa got it going on !!
