Everything posted by TomE
I quit leathercraft ~50 yrs ago to work on cars (I discovered that girls liked cars). This time around I'd rather work with leather than fuss with machines. Happy to pay a dealer to sort out the machines. Anything other than thread tension and shuttle timing is above my pay grade.
For my one experience with sewing a zipper, my double stick tape did not hold so I used a light coating of Barge cement. I was told that this basting tape works well for zippers and will try it next time. https://www.wawak.com/garment-construction/tapes/basting/wawak-hyperstik-super-strong-double-sided-vinylleather-basting-tape-clear/#sku=tpe14
Springfield Leather Co has been a good source for me of HO and other leathers. When I go to the store they will open up rolls of HO hides for me to choose from, and most of them look good. When I call in an order I tell them what is important to me and they have delivered, mostly sides of HO bridle leather.
Thanks. I think I should have added more attachment points for a pack because my niece won't be wearing this from her belt. I have avoided leather tooling since returning to the craft, although my Tandy tools from the 1970s are sitting in my shop. Was never very good at it and decided to instead focus on cutting and sewing for a while. This sheath is made from the leftover belly of a bridle side. The machete and sheath only recently arrived at my niece's house, a full month after mailing the package. The Saint Louis mail sorting facility swallowed the package for a few weeks. Then there was a problem with the zip code at the destination and it took several weeks to reroute the package to a neighboring post office. All's well that ends well.
Help with getting a nice frayed belt edge with fibers
TomE replied to blackandblue50's topic in How Do I Do That?
Bridle leather has prominent fibers and might lend itself to this look. I assume this is related to stuffing the leather with fats and waxes. Rough edges are likely to wear smooth(er) so it might be difficult to preserve the look. -
Welcome! @Northmount provided a tip to use Google's more advanced search engine to search for topics on this site. In the Google search bar type "site:leatherworker.net YOUR SEARCH TERMS HERE" I am finding useful/older threads that I hadn't seen before.
I am probably the only one who finds this interesting, but look at how he applies dye. I thought his method produced a pretty shading. I sometimes dye the back of bridle leather after splitting off the pasted/colored back. This looks like a handy way to avoid saturation/bleed through to the grain without the expense and maintenance of a spray gun.
This author states "Tokonole's first ingredient is white glue." https://www.fineleatherworking.com/blog/gum-tragacanth-leather/ I haven't purchased Tokonole so I don't know where he got this information. There have been numerous discussions here about using glue-dye mixtures to finish edges as an all-in-one treatment. My tendency would be to apply the dye, wait a few minutes for it to soak in and even out, then apply the bunishing compound and smooth the surface with a glass slicker. I would be concerned that burnishing will obscure the brand.
I think @SUP was commenting about creasing and I quoted her. I make padded straps flat and they mold to a round shape with use. Wrinkles and creases aren't an issue in my experience. It would be difficult for me to hand sew them when curved because the jaws of my stitching horse are flat. Here's a noseband that is constructed of 2 layers of 9 oz leather and a neoprene pad wrapped in chrome tanned leather. The 9 oz pieces are skived on the edges, shaped in a rounding block to create the swell, then glued and sewn together with the padding while flat. The noseband readily shapes around a horse's nose. You can see a few wrinkles in the pad but those smooth out with use and are of no concern to the clients I make bridles for. Regarding my original comment on this post, I don't have a wood shop but I do have a calculator on my phone. I had wondered if padding a strap changed the measured size and the answer is -- not much but you can make a small allowance for it, if desired.
- 21 replies
- foam padding for leather
- layer
(and 2 more)
The pads made from 1/8” neoprene wrapped with 3-4 oz chrome tanned leather are quite flexible there are no major wrinkles. It will depend on thickness/firmness of the pad and the radius of the bend. The dog collars I’ve made are for large dogs.
- 21 replies
- layer
(and 2 more)
The calculation is for full length padding then I "discount" the allowance based on the fraction of strap length that is padded. In the 15" example, the full allowance is 1.2" and I would add about 0.75" to my strap because only 2/3 of the strap length is padded.
- 21 replies
- layer
(and 2 more)
I was answering the question of how long to make the strap in order to account for padding underneath, compared to an unpadded strap. The padding will be shorter than the strap, typically spanning between the buckle return and where the buckle holes begin. In my example, the pad is 2/3 the measured length of the collar. The padding is glued and sewn to the strap, and conforms to the strap when buckled. I could make a chart of padding allowances for different length straps, but it depends on the thickness of the padding and how much of the strap is padded. At the end of the day, it is a small allowance (15.75" strap vs. 15" unpadded in my example). For my padding thickness, I can guestimate the allowance from a few reference calculations I made. For example I'd add about 0.5" to the strap length for a dog collar with a measured length of 10". Of course, if the leather stretches then it's a moot point. Why does this matter to me? For a made to order collar or cavesson (bridle nose band) I want it to fit on the middle hole. It is a point of pride.
- 21 replies
- layer
(and 2 more)
I thought it was only me... I recently was figuring out the allowance for padding a dog collar. I think of it as comparing the circumference of 2 circles. One circle is the unpadded collar and the other is the collar enlarged by the thickness of the padding. In the example below, the circumference of the unpadded collar (L1) is the measured length of the collar from the buckle tongue to the hole it fits into. We know that the circumference of a circle is Pi multiplied times the diameter (d1). We solve for d1 then add twice the thickness of the padding to calculate d2, the diameter of the padded collar. Knowing d2 we can solve for L2, the circumference of the padded collar, which is the length of a strap that fits over the padding. After calculating L2 we can calculate the difference L2-L1, which is the padding allowance for a collar that is padded over the full circumference of the circle. I figure that my collars are padded over ~2/3 of the length, so the padding allowance is 2/3 of the difference (L2-L1). I make padding with 1/8" neoprene wrapped with 3-4 oz leather, which ends up being about 3/16" thick. In the example below, for a measured length (L1) of 15" a fully padded collar would be 16.2" long. Since only the middle 2/3 of the collar is padded I would add an allowance of about 3/4" for the padding = 15.75" Not much change. Hope this helps.
- 21 replies
- layer
(and 2 more)
I added notched aluminum plates to my Weaver stitching horse, based on a suggestion for sewing straps in the Stohlman hand sewing book. I find this very handy for clamping odd shapes, such as sewing a buckle and fixed loop on the end of a strap, or sewing the edge of a raised leather piece. The space between the tabs works like an ordinary clamp but I often suspend the work between the tabs when I have different thicknesses and odd shapes.
Difficulty minimizing tooling marks from machine
TomE replied to Hemskey's topic in Leather Sewing Machines
Great suggestions from @kgg and @Hags. I tap the back side of the stitching with a polished hammer on a smooth stone. Some folks use an overstitch wheel to smooth out the stitching. Also check the type of cutting point on your needle. I think the "S" type cutting points produce less blow out (backside bulges) than the "D" type triangular needles that are good for stiff leather. Here's a guide https://cdn.shopify.com/s/files/1/0579/8857/9507/files/Cutting-Points-schmetz_db_schneidspitzen_6s_20190510_en.pdf?v=1643753018- 5 replies
- techsew 4800
- techsew
(and 1 more)
He was a handsome boy! Might that be a stallion bridle for showing in hand?
I usually mark holes after forming the strap around hardware, but I could then unfold it so I can awl the top layer before gluing/assembly.
We all agree it is tough to awl through that many layers, and it's great for me to read everyone's methods. I use a peg awl haft with a 2" awl for the heaviest sewing that I do. https://osborneleathertools.com/product/peg-awl-haft-143/ It's probably the wrong tool for leather sewing but I have gotten the feel of it to reach my destination on the backside of a stack of straps.
That's an interesting design that I hadn't seen before. Looks indestructible and very well made. I like the way the 2 straps wrap around the dee ring. As it turns out, we sold our phantom yesterday. I am getting too old for that stuff. We previously kept pony stallions for breeding children's hunter ponies based on the Caspian Horse. I then collected a friend's stallion for shipment for several years, but he was a well behaved boy. Now all of our warmblood breeding is using mail order husbands for our mares. Young colts are about as much stallion as I can handle these days, and I can only blame myself if they are poorly behaved.
After struggling for several years with burnishing bridle leather I’ve learned a key is to get the right amount of moisture and friction when burnishing and not overheating with a power burnisher. When in doubt, burnishing with canvas is a good approach. My favorite dye applicator is a small block of Magic Eraser held in a clothespin. Holds a lot of dye without dripping.
If I may suggest finishing and sealing the edges for outdoor use. This will help repel dirt and moisture to improve wear. I use mostly bridle leather for tack. It is a bit trickier to burnish than plain veg tan because the fibers are stuffed with fats and oils. You can get a fairly smooth edge by burnishing without sanding. My process is to bevel the edge then lightly wet it with water. I apply a small amount of saddle soap with a finger - just enough to feel it starting to get slick. Too much water or saddle soap will decrease the amount of dye absorbed in the subsequent step. I use a power burnishing wheel but canvas also works well to make the first pass. I then dye the edge with Pro dye or a 50:50 mix of Pro dye and Martin's Edge Solution. Once the dye soaks in I add a little saddle soap and burnish again. Gum tragacanth also works at this stage instead of saddle soap, but GT will seal the edge so you can't apply more dye if needed. Martin's Edge Solution creates a firm edge that is not sealed. I burnish before and after dyeing because it's easier to apply the edge dye evenly on a smooth edge. I usually finish by sealing the edge with beeswax applied with a heated edge iron. I let the wax harden for several hours before buffing with a soap cloth. This makes a serviceable edge for horse tack. I avoid acrylic finishes so the tack can be cleaned and conditioned as needed.
Beveling edges - I just keep getting worse at it, and it ruins my projects
TomE replied to Toffe's topic in Getting Started
Placing the edge to be beveled on a scrap of heavy leather is a good idea to gain some room. I do a lot of edges on small bridle parts that vary in thickness. Of course having the correct size edger and keeping it sharp will help the cause. I have scraps of heavy oil tanned leather that I've edged with various edgers and coated the beveled edge with polishing compound. I frequently strop my edgers on these scraps. Can also coat a leather edge with beeswax and add some aluminum oxide powder for a coarser/sharpening step before stropping. I bought the Weaver block-of-wood-with-leather-strips for polishing edgers but rarely use it. -
Thanks for the tip, @Northmount! I am finding all sorts of posts about bridle leather, horse tack, etc that I previously missed. Dreaming up lots of experiments based on new information.
Work of art! Beautiful craftsmanship.
A raised leather strap is typically made by splitting the strap and inserting a leather filler strip. The top/grain side is thin (~2-3 oz) so it conforms to the filler strip and the bottom of the split is thicker and serves as a flat platform. I make raised leather straps from bridle leather with a pasted back, but you could split 2 straps or add a thin liner if you want grain showing on both sides. The layers are glued together before sewing the edges. The width of the top cover is decreased by wrapping over the filler strip so the edges of the strap will need to be trued up after it is assembled. Depending on the height/shape of the filler you might need to start with a wider strap if you're machine sewing so the pressor feet have a place to land then trim the margins after sewing. An inline or narrow pressor foot helps with sewing next to the raised element. It takes some practice with splitting, shaping, sewing, and trimming to make raised elements. Also, the pictured belt violates a cardinal rule of strap making - don't stitch across the width of the strap - although this is often seen in manufactured dress belts.
