TomE
Everything posted by TomE
  1. TomE
    Shoeing Apron
    Thank you. Realized that the chrome tanned split might oxidize the copper rivets and turn them green. Not sure if brass rivets/burrs would oxidize. I'm not set up for steel tubular rivets, and I guess appearances aren't so important for this work apron. Thanks. I used one of his old aprons to make the pattern then tweaked the belt and back piece. He says these leather aprons last him several years, whereas the lighter nylon aprons with leather knee patches are nice in hot weather but wear out in 6 months.
  2. TomE
    Shoeing Apron
    Thank you. Thanks. Learned some new things.
  3. TomE
    Shoeing Apron
    Made an apron for a farrier friend. It buckles in front and has a padded back support. The apron wraps around the front of the legs and the straps clip to dee rings on the backside. Made from Beiler's 7 oz apron split and 9 oz Hermann Oak veg tan. It is heavy and unwieldy to feed through a sewing machine, but it is done.
  4. Another satisfied customer with a Cobra burnisher. I frequently use the sanding drum to level up edges and the wooden burnisher has a variety of shapes that fit my projects.
  5. My Techpro skiver doesn't have a boot on the universal joints. I purchased some FAV parts (steel feed roller, roller feet) from Campbell Randall in order to skive heavier veg tan leather. They were quite helpful and the parts fit nicely. I posted about it several months ago.
  6. So the blade guard is used for working on the machine with the drive roller removed?
  7. That's an interesting design, Jonas, and it looks very sturdy. Maybe you'll have to make one for Bent too.
  8. I learned a lot about constructing leather projects from Stohlman's case making books. Instructions for knife sheaths are included.
  9. That’s a nice piece of work! Wish I could weld like that.
  10. Nigel Armitage has a video on sharpening the blade of an Osborne #84 splitter. He swings the blade around 180 deg and leaves it clamped to the base of the splitter. That's what I do for my Taiwanese Tandy Pro splitter. Edited to add: That is the video posted above by @jcuk. Guess CS Osborne likes his method.
  11. You could try heating the crease and using it on dry leather. When the temperature is right the crease will glide with less resistance than at room temp. Too hot and it burns the grain of the leather. I use an alcohol lamp to heat the crease. You will feel the heat coming up the shank of the tool when it's about the right temp. Creasers come in many sizes and shapes. Some are easier to use than others. You can reshape them to change the width of the crease line. The Osborne creasers (like all Osborne tools?) need a bit of smoothing and polishing to work really well. Same for the Vergez-Blanchard screw crease. I always crease after finishing the edges of straps - beveling, dyeing, burnishing - then creasing. I repeat the creasing after oiling and before applying conditioner.
  12. What type of creaser are you using - fixed or screw crease? What size is it (how close is the crease to the edge)? Is the edge beveled and burnished before creasing? A picture would help. Do you heat the crease or case the leather before creasing? Don't do both. I find that applying light pressure to establish the crease line before bearing down will give me more consistent results. The creaser works best on leather with a firm, even temper. Harness leather is especially nice because of the waxes that lubricate the crease.
  13. The diagram is easy to see but it's not easy to calculate stitch spacing from the angles shown. I think it's easier to calculate the inner and outer circumferences then convert the spacing of the outer piece to that for the inner piece as the ratio of circumferences. My point is you will end up with something like 6 and 5.5 stitches per inch for the 2 pieces and I don't know how to accurately mark 2 spacings with a small difference. Won't have to do this with an awl. Skipping a hole doesn't fix the spacing.
  14. Not East Coast but Leather Machine Co has a blade sharpening service for the Class 14 splitter. The blades are hollow ground. I've seen comments stating that they also sharpen blades for other machines. I would search for a local service that sharpens wood working tools.
  15. The math is analogous to the question in the post below - how to calculate the allowance for padding a collar - with the additional consideration of hole spacing that is proportional to the 2 circumferences. That said, it will be a small difference and difficult to accurately mark on the 2 pieces. I'd use an awl.
  16. That's for a big dog! Very pretty. I like the color scheme.
  17. The Stohlmans mention in their Encyclopedia of Saddle Making that they used lots of neatsfoot compound to good effect, but they acknowledge that pure neatsfoot oil is a better product without explanation. Anybody have an explanation? Waterproofing products typically contain silicon oils that I believe are also petroleum based. I use Saddle Oil, Golden Mink Oil, and Sno Seal on work boots. Pure neatsfoot oil on tack.
  18. Beeswax applied with heat and slicking, or a waxy conditioner like Fiebings Aussie.
  19. A glass slicker is useful for burnishing the flesh slide with wax, glue, etc. Loose fibers on the back side might indicate a loose structure overall that makes for a weak, stretchy strap. I mostly use bridle leather with a moss-back (pasted back). A flexible, pasted back can be created with this product that I use if I split the back off bridle leather. It is sold in quarts and gallons. https://campbell-randall.com/product/sup-bt639-g-leather-finish-for-sealing-flesh-side-moss-back-suede-1-gal
  20. That’s beautiful, @Sheilajeanne! Love the design and the colors.
  21. Polish has waxes and leaves a shiny finish that is somewhat water repellent. Mostly a surface treatment. Leather conditioner creams, balms, etc. aim to add some moisture to the fibers. They soak into the leather and typically leave a satin finish. The choice of finishes depends on the use of the item and your preferences.
  22. Learning to sharpen the tools is part of learning to use them. Another reason to start with modestly priced tools. I have enjoyed using CS Osborne tools once I learned how to sharpen them. Like most tools, they need some sharpening when new to work correctly. Stohlman’s book on Leather Tools has some good tips. This cheap Japanese style skiving knife works surprisingly well once it is sharp. https://a.co/d/cuO9tG1
  23. Thanks, @jcuk. From the pictures the temper looks similar to the Beiler's apron split that I purchased. Softer than the apron I am using for a pattern. The apron is 6/7 oz (~2.5 mm) and the Beiler's apron split is 7/8 oz (3 mm). Plenty heavy IMO but it will lay differently when working under the horse. The client/friend will stop by tomorrow to check out the leather for his apron. I might order the firm pearl split from Hide House and give him a choice. He's highly skilled and kind enough to shoe a couple of horses for us (I trim the others) so I want to keep him happy. I might make mayself an apron with the other split.
  24. I am making a farrier apron and ordered a double bend of pearl gray apron split (7/8 oz) from Beiler's. Was surprised how soft the leather is compared to the apron I am using as a pattern, and my own trimming apron. @bruce johnson's comment about preferring a soft apron split caught my notice, and I am wondering if anyone has experience with Beiler's apron splits for a shoeing apron or other heavy use. I was looking at Hide House as a second choice. They offer firm and soft versions of pearl splits in a a 6/7 oz weight that is similar to what I am used to. Of course, I will ask my farrier friend what he would prefer for this apron. Appreciate any suggestions or your experience with either supplier's apron splits.
  25. Impressive figure carving. I like your floral pattern as well. A distinctive piece of art.
