TomE
Everything posted by TomE
  1. Beautiful folk art! Thinking about a summer day (although I'm happy that fall has arrived).
  2. Y-knot Lace has a good selection of kangaroo lace that could be braided to make a drawstring. I've been pleased using it for laced reins. https://y-knotlace.com/
  3. Looking forward to hearing about your experiences with the raised leather. Always looking for new ideas and improvements.
  4. I've had the impression that the grain layer of veg tanned leather contributes more to overall strength than an equal thickness of the flesh layer. This has been suggested as a reason to not use a stitch groover (removes the strongest part of the leather), and why splits are stretchy and weak compared to full grain leather. Well this paper from 1926 says the opposite. On per thickness or per cross sectional area basis the flesh side is stronger than the grain. For example, the grain side of a split that retains 70% of original thickness has half the strength of the unsplit leather. The flesh side split to 40% of original thickness retains half of the strength. Maybe not a big deal but it indicates that the grain doesn't have an outsized contribution to strength, at least not for these authors' cow hides. The sum of the strengths of grain and flesh splits is always less than the strength of the unsplit leather- that much I can understand. Does this comparison of grain and flesh agree with your thinking? I am particularly interested in the strength/stretchiness of straps. Seems it would be stronger to line a thick strap with a thin liner instead of using 2 straps of equal thickness that add up to the same overall thickness. Wilson and Kern - 1926 - Effect of Splitting on the Tensile Strength of Lea.pdf
  5. I'll bet the horse will turn up if you fill the bags with feed. Did you include hardware to tie the bags on your saddle?
  6. TomE
    Watch strap
    Looking good! I like the 3mm stitch spacing and it looks like you're using an awl.
  7. The nice thing about the narrow feet is you can turn sharp corners without coming off the edge. With the in-line feet I back out of square corners so the rear foot has a place to land.
  8. A couple of articles on tanning chemistry and several on currying - fats and oils. The files are too large to upload here, so here is a link to my Dropbox folder containing the files. https://www.dropbox.com/scl/fo/1unoj2zvcdb9xjo65u993/h?rlkey=4rx8dv5fz2obchca3n6k27qyh&dl=0
  9. I have read that the stepwise increase in tannin concentration during the tanning process produces a more uniform matrix of cross linked collagen fibers. If the concentration is too high at the beginning there’s a lot of cross linking near the surface, creating a barrier to penetration deeper in the leather. It is my understanding that tannin solutions are used for multiple runs of tanning, starting the process with used solutions that are depleted in tannin concentration and working towards newer solutions with a higher tannin concentration. In the end some tannin molecules are tightly bound to collagen (hydrogen bonds and salt bridges) and a portion of the tannins can be extracted through back soaking. If you’re interested I can post some articles describing these aspects of the chemistry.
  10. I like the appearance of the S point needle stitching and use it mostly for 15-30 oz bridle leather. The TRI needle creates a more noticeable hole but is good for hard leather with little tension adjustment. The Schmetz website is my go-to for needle information. https://www.schmetz.com/en/industrial-needles/needle-compass/cutting-points/
  11. The inline feet from Toledo Industrial Machine work great on my Class 4. So does the narrow foot set from Hennigen Precision Engineering.
  12. My brother made a rounding block for me out of pine and I gave it a light coat of beeswax. This was a prototype before he makes one out of hardwood, but it has been working fine for 18 months. The only commercial rounding block that I found is sold by Abbey England. The brass ball sounds like a good fit. I use a bone folder an a large pear shader for 5/8" straps. The trick about sewing a swell with a machine is there's no flat surface for the pressor foot and the strap slips sideways under pressure. Will be very interested in how you do this. For raised leather with a flat filler strip an inline foot can be used on the narrow margin, but to sew really close to the raised element I run an inside foot on top of the filler strip.
  13. I buy stamped stainless bridle buckles and stud hooks from Weaver, and most of my heavy brass halter hardware from Batz Corp. Abbey England has unique, high quality hardware for English tack but shipping is REALLY expensive, so I usually treat myself to a tool to justify the shipping cost.
  14. @jcuk covered it well with the links. I'd only add that the first 2 video links are what I call a "swell" -2 straps with skived edges formed in a rounding block. The 3rd link is what I call "raised leather" - a split strap with a filler inserted. Whatever terminology you prefer they are different techniques. For swells I use a Japanese style knife or a head knife for most of the skiving and do a bit of leveling up with a French edger. I case the top strap after skiving and shape it in a rounding block, check its fit to the backer strap, then let it dry a few hours before gluing and assembling the 2 straps. I keep the backer strap dry and shape the curved front around it. I haven't figured out how to sew swells on a machine so I hand sew them. For raised leather I am splitting ~10 oz leather to ~ 3 oz of grain side and the rest as flesh side, or I split another strap for the backer so both sides have grain showing. The backer strap serves as a stiff platform to shape the grain side around a filler strip. I use a ~5 oz filler strip for a 10 oz split strap. The edges are trimmed after gluing and assembly, so I typically start with a strap that is ~3/8" wider than the desired finished width. You'll need a larger margin if sewing with a machine. An in-line or narrow pressor foot set will help. I have a bucket full of practice straps that are my raised leather graveyard. By playing around with thicknesses and widths you can create different looks.
  15. I thought the main reason to use tallow instead of lard is that tallow resists oxidation/going rancid.
  16. Might try maintaining it like horse tack. Cleaning with saddle soap and water. Occasional oiling as needed with neatsfoot oil. Conditioning with a waxy conditioner like Fiebings Aussie or Black Rock Leather-N-Rich to repel water. English tack is not sealed with an acrylic top coat. Depend on regular cleaning, and conditioning with fats and oils to keep it supple and prevent dry rot. Another way to go is silicon oils for water proofing. Fiebings Saddle Oil (I use it on my work boots) or Golden Mink Oil.
  17. While we're on the subject of fats and oils... Newbury - 1940 - Oils, fats and waxes in the leather industry.pdf Blockey - The Application of Oils and Greases to Leather.pdf
  18. I use mostly HO bridle leather and it bleeds a little dye when I wet form buckle turns or rounded straps - not to the extent you describe. If I split the pasted back off bridle leather then I usually reseal it with this flexible water based adhesive. I use a glass slicker to work it into the flesh side. It leaves a matt finish similar to a pasted back from the tannery. I think this would stop the bleed from the flesh side. It doesn't accept dye well if it gets on an edge before dyeing.
  19. Thanks for the article, @chuck123wapati. Lots of good information about the chemistry of tanning and currying leather. I understand @SUP's point about the difference between producing leather and maintaining it with a conditioner, but I find it helpful to know what the starting point is at the tannery. Wish we had a reference section of this forum for depositing and downloading useful articles, book chapters, etc. I maintain my own collection but it is obviously not all-inclusive and it's fun to see what others turn up. Linen thread most certainly can rot. When repairing tack, I see linen thread that has deteriorated after decades of use. I don't know if it's caused by mold, a chemical used to maintain the tack, or something else. Coating linen thread with beeswax is supposed to help protect it, but for how long? There was a recent post asking where to find linen thread and the OP noted that Barbour has gone out of business. Campbell-Randall Corp. has a limited selection of Barbour thread. For hand sewing tack I mostly use bonded nylon thread from my machine, and for heavier weights I use waxed polyester thread from Maine Thread Co.
  20. One knock against vegetable oils and olive oil is they attract rodents at least for tack stored in a barn. I would also consider lanolin as a vehicle for fats/waxes in a conditioner. Aussie conditioner and Effax Leder Balsam cause very little discoloration in comparison to Bick 4 or Black Rock Leather-N-Rich in my experience.
  21. I think mineral oil is chemically inert and unlikely to react with anything in the leather. My concern would be the solvent-like properties of any oil applied to leather and the potential for over lubricating the fibers (spongey leather) and/or the potential to displace waxes, tannins, etc. The ideal oil would be readily absorbed so as not to remain on the surface and it would not change the temper of the leather, or do so in a controlled manner with additional applications. For me, neatsfoot oil fills the bill.
  22. The care of vegetable tanned leather has different requirements than skin care. The leather has been exposed to harsh extremes of pH and reactive chemicals that break down the collagen fibers then bind them together with tannins. Oils and waxes are infused in the currying process to seal the leather and add suppleness. Oiling and conditioning aims to add back moisture and fats/waxes without removing what was introduced during the tanning processs. Are petroleum products OK to use? Yes and no. The Stohlmans mention in their Encyclopedia of Saddle Making that they made generous use of neatsfoot compound to good effect. Neatsfoot compound is a mixture of neatsfoot oil and petroleum based oils. They also mention that pure neatsfoot oil is preferable. Silicon oils are found in lots of leather care products including Fiebings Saddle Oil and Mink Oil. Great for waterproofing and softening leather. There is also too much of a good thing. Soaking leather tack in neatsfoot oil causes the leather straps to become permanently spongey and sticky to the touch. In my view the best products have limited ability to penetrate the leather and displace tannins, waxes, and other stuff we paid for when buying quality leather.
  23. Very nice, sturdy looking halter. I like the fancy design on the cheeks.
  24. It's standard practice to dye the edges of leather that has been dyed at the tannery and your edge treatment can really enhance the look of a bag - worth your time and some experimentation. I've never used an edge paint but I'd be concerned about how flexible it is and if it would wear well. My vote would be to test whether the edge can be burnished with something like Tokonole or Martin's Edge Solution. If it can be burnished then I would dye and burnish the edges instead of painting.
  25. My favorite edge dye is a 50:50 mixture of Pro Dye and Martin's Edge Solution. Dye and burnish in one step, similar to the traditional dye/glue mixes that @jcuk posted. The Martin's Edge Solution smells a bit like acrylic floor wax but the burnished edge remains permeable to additional coats of dye. I finish the edge with a waxy conditioner or hot beeswax. Don't know what's in Edge Solution, but in my experience it produces more consistent results for bridle leather edges than other methods I've tried.
