TomE
Everything posted by TomE
  1. To remove the shuttle assembly, loosen the two black screws shown in your picture and gently pry off the retaining ring that the screws secure. Be ready to catch the shuttle and driver, which can fall out when the retaining ring is removed. In addition to cleaning and oiling the shuttle race, you can easily adjust the feed dog height with shuttle removed. This video from @Uwe shows why there is play in the shuttle assembly.
  2. I would investigate the shuttle timing. My Class 4 was incorrectly timed and the walking foot mechanism was out of adjustment. I was experiencing needle strikes, missed stitches, etc. I recommend reviewing the DVD that ships with the Cobra machines then watching videos by @Uwe to learn how to adjust the shuttle timing, and the walking foot mechanism. Most of the tools needed for these adjustments are shipped with the Cobra Machines.
  3. I made a firm paste from approximately 1 part beeswax, 3 parts carnauba wax (from Campbell Randall), and about 6 parts pure neatsfoot oil. I heated the waxes in a boiling water bath and added oil until I had a thick liquid. It took a while for the carnauba to dissolve. I use a finger to apply the paste to a dampened edge. Burnishing with Fiebings Aussie conditioner (applied with a canvas scrap then slicked) produces a similar glossy edge, and I am still evaluating whether or not the carnauba finish is more durable.
  4. Here is the mark.
  5. I had to run the die into the collar of the tube to finish the threads lower on the tube. By trial and error I found how far to cut threads so they bottom out with the tube squarely contacting the punch anvil. The tube is firmly seated on the finished threads at this position even though some partial threads are showing.
  6. Use calipers to lightly scribe a tram line on either side of the mark for the hole. The lines bracket the center of the strap and are 1-2 mm outboard of the width of the punch. Roll the punch into position, lining up along the tram lines. Tap lightly and check the impression. Pound away!
  7. The Osborne 84 splitter is a classic model. I have an Asian knock off that was previously sold by Tandy as their Pro model. It keeps an edge and came with a spare blade. I think most of these splitters require sharpening when new. The Campbell-Randall looks like a nice unit.
  8. Really nice. The rolled straps are striking, and so is the belt like detail.
  9. Those are some handsome projects! You already have a broad skill set. Keep up the good work.
  10. I think a cart buckle is a generic term for a heavy center bar buckle with a round-ish profile. Bridle buckles are typically heel bar (e.g. stamped stainless steel) or center bar wire buckles in smaller sizes.
  11. I've had good luck with Batz Corp for harness and tack hardware. I find it easier to shop from their PDF catalog then search the online store using a part number. Some of the heavy brass items are currently on backorder. These guys also look interesting https://www.harnesshardware.ca/ but I haven't set up an account with them yet.
  12. Cotton web reins are constructed with leather end pieces. I use tacks to hold the pieces in place while hand sewing. Here's one example. https://www.sstack.com/premier-cotton-web-reins/p/10421/
  13. I am a big fan of Aussie conditioner. After bad experiences with Tan Kote lifting pigment from dyed veg tan and staining my thread yellow, I've been using Aussie to finish tack and for burnishing edges before dying. A little Aussie on canvas followed by a slicker or burnishing wheel. I've had better luck with it than other treatments especially for some bridle leathers with coarse/fat fibers.
  14. Good tip! I'll try the potato for the replacement tube that has the same problem with shallow threads.
  15. Thanks, Bruce. Good information. My spring punch is about 5-6 years old, and the 00 replacement tube fit whereas the 0 tube in the same order had shallow threads. Following advice from @chuck123wapati I annealed the tube, cut in the threads with a 5/16-24 die, hardened and tempered the tube, then cleaned up the cutting edge and polished it. I had to punch some oiled leather to clean out the exit hole and now I have a working punch. Thanks to everyone for their input. It is a privilege to connect with so many experienced leatherworkers here.
  16. Thanks @chuck123wapati! I'll watch the video after I feed some horses and report back on my results.
  17. After spending much of 2021 improving the edge on my Osborne round knife, I have some ideas. The taper on the edge was too steep and I've removed a fair amount of material to achieve a ~20 deg angle. I used coarse stones, but the smart way would be to use a sanding belt to get the shape before sharpening. If you don't have a belt sander, I would ask a farrier or blacksmith or knife maker to help you out. After fixing the blade profile, I sharpened with water stones and stropped with a buffing wheel and by hand. The blade on my knife appears to be very hard and I am now happy with the edge. I also cut a bit off the end of the handle to fit my hand.
  18. I purchased a couple of replacement tubes for an Osborne #153 spring punch, and one of them doesn't screw into the punch. The threads appear to be shallow and incompletely cut. I received a replacement tube with the same problem. While waiting for the vendor to resolve this with CS Osborne, I tried cutting threads on one of the tubes and the metal is hard and brittle (which I'll view as a good thing). Any advice about removing the temper, cutting threads, and hardening the tube would be appreciated. I don't own a forge but have an acetylene torch, oven, Zippo lighter, .... This is an experiment while waiting for Osborne to replace the defective tubes.
  19. I bought a buffer for touching up hoof knives between sharpenings, and now use it for all kinds of leathercraft tools. Mine has a deburring wheel and a sewn cotton (stiff) buffing wheel. The extended shafts on this bench grinder make it easier to work on curved blades without interference. Farrier suppliers sell high quality machines and wheels. http://www.farrierproducts.com/shop/tools/buffers-and-grinders/baldor-1-4hp-buffer-red/p/1375
  20. Thanks, Jonas. The PS of Sweden bridles are inspirational. I had not seen this brand. Will check out the PetHardware site.
  21. Received the narrow feed dog and plate today, and can second that they fit the Cobra Class 4 machine beautifully. So much easier to sew close to an edge. I am now determined to sew bridles with narrow padded straps and swells on the machine instead of by hand. Time for experimentation.
  22. Sounds like you have a fun niche with the stallion station. Where do you buy hardware for tack and blankets? I've been happy with Batz Corp for heavy brass hardware, which is back ordered these days. I am still looking for a supplier of stainless steel bridle buckles, particularly sturdy center bar buckles in 3/8, 1/2, and 5/8 inch sizes. Weaver and Batz sell stamped heel bar bridle buckles but I am trying to match fancier varieties on European made tack. We call the mare restraints "hobbles." We also avoid live cover as a safety issue. Merry Christmas to you as well.
  23. That's an impressive undertaking, @Mulesaw! Good looking repairs. Lots of bobbin reloads I would imagine. Our phantom is covered with canvas and has a trap door at the rear for a Colorado style AV. I wonder if the fender on yours is a clever modification to safely replace the receptacle for a fixed AV. Maybe your next project will be stallion leads with a stud chain, or a custom leather sling for a hand held AV (Missouri style AV).
  24. I know nothing about holsters, except that is pretty work. I've had problems with rolled straps rolling under the presser foot and causing needle strikes. I now leave about 3/4" of filler strip exposed and tack a leather piece under the exposed filler to shim it. After sewing, I trim the filler flush and finish shaping the piece in a rein rounder. Would it help to use a wider welt and trim it later?
  25. Wish I had your skill. Hard to stop looking at that lovely design.
