Charley1
Everything posted by Charley1
I've dealt with all 3 of them, all have done well. Must admit, I have 2 Tandy retail shops here in town. Nice to be able to buy at retail, or have things ordered for me and not have to pay for shipping.
There are a few businesses that are still on track. A lot more are not. Two major business rules that most business management should follow, but they have no idea they exist. I blame it primarily on college and university business professors and what it takes to get a BS or even an MS degree. Rule one: Treat your customers properly (well). Treat them well, they tell 10 others about your business. Screw them over, and they tell 100 others, and you lost a lot of business opportunities. Rule two; Treat your employees well. Screw them over, and your employees will find 1000 ways to get back at you that you will never figure out, and will cost you tons of money. Hello, Chapter 7 or 11!
Reckon I'm lucky, have 2 Tandys here, one about 4 miles away, another about 15 miles. Ordering online is easy as well, Fort Worth and San Antonio are not that far apart. I do want to see my leather before I buy it as well. The 20% discount in June was nice, too. My profit level was down and my expense level was up considerably, but I picked up enough leather that expenses will definitely be down for the next couple of months.
Tipmann Boss, Cowboy Outlaw, Weaver Cub
Charley1 replied to thenrie's topic in Leather Sewing Machines
Looking at the Cowboy, it sure seems a close almost copy of the Boss. I've had a Boss for about 6 years, never had any major issues with it. Of course, there is a learning curve with it, but there is a learning curve on every other piece of equipment a well. I do agree about buying the narrow foot, and skipping the edge guide.- 10 replies
- leather stitching machines
- cowboy outlaw
(and 2 more)
Which Hand Operated Sewing Machine works Best?
Charley1 replied to MarshalWill's topic in Leather Sewing Machines
I've had an aluminum Boss for almost 6 years now, no problems with it. It has paid for itself many times over. -
P 95 DC Holster
Charley1 replied to Bert03241's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Functional beats pretty, IMO and IME. -
Hot Box Holster Drying Cabinet
Charley1 replied to Lobo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Might copy your design. Currently use just a platform to lay out the leather goods, and use a fan set about 4 feet away. Works relatively fast, just a couple of hours. -
Classic example of the business rule 10/100. Treat your customers/clients well, and they tell 10 people. Treat them badly (like hanging up on them) and they tell 100 people.
I admit, I've never bothered with the plug, I just make the extension from wood or plastic, and tape it on. Has worked so far.-
I lay the items out on a shelf, then position a small fan a couple of feet away to blow air on them. Speeds drying time considerably, and doesn't affect the leather.
Thye first is always the toughest to do.
I used to add a business card, but response was a very low percentage. Now it is simply a packing slip with order information, contact information, and a thank you message.
Make my holster patterns from card stock, wanting the flexibility to insure fit. Then I trace to pattern onto sheet plastic and cut it out with an Exacto knife to make a long term template. Most available and least expensive sheet plastic I've found is used for the cheap "for sale" or "for rent" signs found at big box hardware stores or Target/Walmart.
I make a lot of blocks for holding/storing reloading equipment and tools. I use 3/4 inch red oak, laminated to the thickness I need. Layout the holes, drill them on my drill press using a fence I made. Follow with using a roundover router bit on the edges, then finish with polyurethane. They sell pretty well. Here's a block made for some RCBS Little Dandy powder measure rotors, and a block for die/turret storage for a Lee Classic Turret Press. I've made blocks for leather stamps and tools in the past, guess I need to start making them again.
I make cartridge belt slides. My 38/357 slides are 9/16 inches between slots, and the cartridge loops are 4-5 ounce. I don't rivet until formed up. I cut the strap, 90 degrees at the back end, and cut a V shape on the end that I run thru the slots. Makes things a lot easier. Wet the strap until softened, maybe 30-40 seconds. Square end goes in the first slot, fold tightly onto the slide, and hold in place with a spring clip. As long as the slide itself is dry, a properly tensioned clip won't mark it. Push the V end back thru the slot, leaving a loop. Insert the cartridge, and pull it tight. Be sure the strap is flat against the backside of the slide, and insert the V into the next slot, and repeat. On the last slot, pull the strap tight, and cut to proper length. Apply another spring clip to hold it in place, and let dry for 10-15 minutes, and remove the cartridges. Remove the spring clips and rivet the strap ends in place. I find it easier to have the rivet holes punched before hand, when I punch the slots. Then just punch thru the existing holes into the strapping when you are ready to rivet them in place.
Was checking local Craigslist for leather, meant to open the "arts and crafts" category. Opened the category above it, "appliances", by accident. Entered "leather", and it brought up a Tandy Outlaw for sale...at $500. Description was it was almost unused. Listed back at the end of November, but seller might still have it. Don't need it, but you never know.
Advice on a Reichsrevolver holster
Charley1 replied to JayB's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Agree completely. Make a copy to use, keep the original untouched, even given its condition. -
You need to see if she can make the Robot Devil, from the "Fairness in Hell" Act of 2275. He and Bender would be a great pair.
Nice gift, meatbag!
Kitchen utensils and supplies.
If you don't need a very large board, Walmart sells a three pack of HDPE cutting boards, one 11x15, one 8 1/2x 11, and one about 6 x 8. Less than $10. Work fine for smaller projects.
Tippmann seems to have had some issues in their shipping department. I ordered some thread back in August, no confirmation of order. Contacted them after about a week, asked about the order status. Don't know who responded, not sure if it was the Chelsea mentioned above, but might have been. Was told they were out of stock on the color I ordered, but would be there soon, and I would be contacted about it and the item would be shipped. Sat tight for almost 6 weeks, and the order showed up at my door, never having been contacted and told the item was in stock and would be shipped. Checked their website, logged in, and it showed my order was "awaiting shipment"". This was in October, and I placed my order on August 21. I just checked again after reading these posts, and, oddly enough, my order is STILL "awaiting shipment", even though it was shipped and received in October. Either some software/system problems, or whoever manages orders and shipping is a total moron, or doesn't care much about the business.
Got the email from Weaver as well.
Cowboy Outlaw, Tippmann Boss or niether?
Charley1 replied to Loki74's topic in Leather Sewing Machines
Been using a Boss for about 5 years. Normal wear and tear, had to replace a couple of springs, upgraded the bobbin holder. Does its job, can't complain. -
My wife does machine embroidery, has 2 six needle machines and 1 10 needle machine. Lots and lots of fabric. Takes up a lot more room than my woodwork, leather work, and reloading.
