DwightT
Everything posted by DwightT
  1. That's a beautiful little sheath, and I love the way your mark is incorporated into the carving. I keep saying that I need to get myself a makers mark, and after seeing how yours works I'm thinking I'll have to come up with a round design also. /dwight
  2. A long time ago when I was first starting my grandfather showed me a technique where on the last stitch he would push the needles into the last hole on each side, but come out between the layers. He would then tie a knot that was pulled tight between the layers, add a dab of glue as has been mentioned, and cut off the loose ends. He wound up with a slight bump in the leather from the knot, but otherwise it looked OK. I tried it a couple times, but I never could get the knot to hold tight enough, so I just went back to backstitching. The doubled-up stitches didn't bother me (just seems like the way it should be in my mind) and it seems to hold better. /dwight
  3. When that happens, I usually blame my wife. She comes in and cleans up after me and I can never find anything. /dwight
  4. I was thinking about this the other day. How about gluing or stitching a strip of leather to the inside to act as a ledge? Might have to do two layers to catch the candle depending on the slope of the sides, but it seems to me that would work. /dwight
  5. Thanks. It's lined with glazed pigskin. I think it is smooth enough to not scratch the lens. Thanks. I got tired of having to go back and find them so I cam up with this. The leather seems to be stiff enough to protect my glasses from crushing, and the flap keeps them from falling out. I can't say the clip won't scrape my belt though and it doesn't really hold as secretly as i would like, so one of the changes I would make next time would be to use a belt loop with a snap instead. But again it seems too work well enough for now. /dwight
  6. Since I only need my glasses for reading, whenever I'm wearing a shirt with no pockets I was constantly leaving my glasses in the other room. I finally broke down and made myself a case that I can clip to my belt when necessary. There are a few things that I'll do differently if I ever do another one, but on the whole I like it. /dwight
  7. Just this 1-ton from Vevor: https://www.vevor.com/arbor-press-c_10103/arbor-press-1-ton-lever-bench-mountable-bearings-cast-iron-manual-desktop-p_010988468116 I have an adapter that lets me use stamps such as my letters and some 3D stamps in it, but like I said having an adjustable fence would be a big improvement.
  8. @chuck123wapati FWIW I think you sent that pattern to me when I was looking to make a holster for my Taurus. I wound up using the one from @JLSleather though, but yours and Jeff's were similar (at least to my untrained eye).
  9. Love it. I've often thought that having an adjustable fence would make my press much more usable, especially for doing border stamping. I may have to see if I can get access to a 3D printer.
  10. Really nice. I particularly like the coloring and border on the first holster. Something in that just really appeals to me.
  11. Thanks. I'm originally from Idaho Falls, but I currently live in Meridian. Thanks. My goal was to have just enough pockets for the basic cards. Makes it more comfortable to carry in my front pocket instead of sitting on it when I'm in a road trip. Thanks.
  12. Got busy with family stuff over most of the summer and didn't get much of a chance to do anything in leather. Finally had a couple days free and decided to make myself a new wallet. This is a simple one based on a design that I got from Rocky Mountain Leather. Had a few little goofs because I rushed it, but in general I'm happy with it. It's thinner than my old one, and easier to carry. /dwight
  13. Not rolled. Just beveled and burnished, then lots of polishing. As to the color change, after beveling and burnishing I go over the edge with a dye pen. This is all described by @hidepounder in his "Finishing Edges" post: Thanks. All hand stitched using an awl and needles. There are still a few wobbles in the stitch line, but I'm getting better (I think). /dwight
  14. I've done several cylindrical cases. As Klara mentions, there is no real need to calculate the spacing on the base. Just mark the stitch holes on the outer tube while it is still laid flat, stitch it into the tube, insert the base and use an awl to make the holes through both the tube and the base at the same time. One thing that I do now that is different from the Stohlman method is I will cut the base piece slightly larger than needed, then wet-mold it into the tube. That way I don't have to try to poke the awl through at an angle. I just have to make sure that I keep the awl pointed towards the center of the tube all the way around. Here is the base of a flag case that I made a while back. /dwight
  15. I still use a round knife simply because that's what Grandpa taught me to use when I first started playing with leather some 50 years ago. I learned to respect the knife and never really had a problem with it. Put my tools away for about 35 years, then when I got them out again last year I found I was still OK with the round knife (after spending some time polishing the blade again), but after reading some of the comments in this forum I tried a carpet knife like @fredk suggested above. I'll admit that I like it, especially for when I have to cut into inside corners, but I still like the round knife for longer cuts. /dwight
  16. I didn't say that it wasn't possible. I said that on newer printers from the company that I worked for, it would be highly unlikely. I explicitly said that I can't speak for older printers or for printers from other manufacturers. Vulnerabilities that existed in older printers are actually the reason why I spent several years with the team that was working on hardening our printers to prevent those exploits. Even now though we don't say that it would be absolutely impossible to hack into the printer's firmware. But it would be extremely difficult and highly unlikely. Hacking into a printer driver (the code that runs on the user's PC to format a job for the printer) is another matter. That code is somewhat at the mercy of the host OS when it comes to security so depending on the OS it could be easier to corrupt a driver. I only worked on the printer FW though, so I really can't say much about that. It's always good to be wary of downloads from any site. But as far as a download print file being able to corrupt the FW on a newer printer with up-to-date code, I'm not going to be too concerned. /dwight
  17. FWIW: Before I retired I worked on printer firmware, specifically in the code for downloading and installing new firmware for an update. Obviously I can't say anything for older printers or for printers from other manufacturers, but as MtlBiker noted for newer printers at least it would be very unlikely that a virus embedded in a PDF file could cause damage to the printer. Any downloads that would change printer firmware or configuration settings must be in a very specific stand-alone format (not part of a valid print job), and must have a valid digital signature that verifies that it came from the manufacturer. The keys used to sign that download are closely held by very few people in the company, so it is very unlikely that a download would be accepted by the printer unless it really was from the manufacturer. So in short, while there is always a minuscule chance that a print job could contain a virus that could damage a printer, it would be so unlikely to have an impact on newer printers that I wouldn't worry about it. On the other hand, if anybody does happen to encounter such a print file, I would love to get a copy so that I could pass it on to my colleagues at my old employer. /dwight
  18. Thanks Chuck. I dug through our storage, and while I didn't find any bottles, it turned out that I did have one lid/adapter in the collection of accessories. I just didn't know what I was looking at. Regardless I've ordered a set of bottles and lids (local Hobby Lobby didn't have any) so I should be able to start messing around with it this weekend. Yeah, I can see that a trip to H.F. is in my future. I should be able to start messing around with what I have, but there are a couple bits that I'll probably want (like the moisture trap). Agreed. I ran some acetone through it last night using the cup just to clean it out. I didn't actually spill any, but without some sort of holder I can see that it would be a royal PITA to use that way. I might play around with the cup until the bottles arrive, but I think long-term the cup really won't be all that practical for me. /dwight
  19. Thanks all. As I mentioned the setup originally belonged to my wife's late husband, and he passed away back in 2010. He probably had it for a few years before that, so I'm guessing that it's all at least 15-20 years old. It's all been sitting out in storage since he passed, and it's possible that there are more parts out there that I missed since I didn't know what I was looking for. I'll have to rummage around some more to see what I can find. Part of my concern with it is if I find any issues, how available will replacement parts be? Haven't really had a chance to look yet. I like Chuck's idea of having separate bottles for the dyes, so I'll be looking into that. Hopefully I'll be able to find the adapter that lets me use bottles instead of the cup. I probably won't use that compressor since as noted it doesn't have a regulator or tank. I do have a 12-galleon compressor that I can regulate from 5# to 130#, so I'll look into using that instead. I imagine that I'll have to look at getting a water trap for it though. The unused hose in the bag has an inline trap. Will that be enough or should I look for something to add to the output port of the compressor? I think I like the idea of using the larger sprayers for sealers. I'll look at using the gravity-fed one for that since I'm thinking that it will be easier to clean up. Since I have two bottles for it I think I can keep sealer in one and acetone in the other for cleanup. Any thoughts on the Matheson filter? Will I need that for anything here? Thanks again for the ideas and comments. Looks like I'll be doing some tinkering over the next few days. /dwight
  20. I know I'm late to the game here, but when it comes to justifying the cost of a sewing machine, one of the things my son will do when he needs a "specialty" tool for a one-off project is he will buy the tool, complete the project, then turn around and sell the tool on the local market. He sometimes will get the full price that he paid for the tool (typically when he bought the tool used to begin with), but usually he'll sell it for some amount less than he originally paid. Even then his overall cost is less than it would have been to rent the tool, and the new buyer is happy that he got the now slightly used tool at a discount. /dwight
  21. Hello all. I've been MIA from the forums for a bit while dealing with some family issues. Got the issues mostly resolved and hopefully I'll be able to get back to leatherwork, but as a result of dealing with those issues I am now in possession of some airbrush equipment (see photos below). The problem is that I know next to nothing about airbrushing. So far I've watched some videos, but they generally seem to assume that I have at least some rudimentary knowledge of the devices. Bad assumption. I have seen others here talking about using an airbrush for dying leather, so I thought I would pop in to see if I could get some pointers to some basic tutorials. This stuff originally belonged to my wife's late first husband and generally seems to be in pretty good shape. He was pretty good at taking care of his tools. The compressor and at least one of the brushes looks like it's never been used. But do I need to be concerned about any paint residue contaminating my dye? In what I've read so far I've seen mention of filtering the paint to avoid clogging the brush. Do I need to do that with dye? In the third photo with the random accessories, the silver cylinder is a "Matheson 6164 Depth filter". Other than that it has 1/4" fittings, I'm not sure that it really goes with this set. Any thoughts? Thanks for any advice. /dwight
  22. The area where I live is down in a valley, and it seems like if there is a fire anywhere in the western half of the continent, the smoke settle in here. My step-daughter is severely asthmatic so whenever that happens she has to stay in her house with the HEPA air filters. We also have the National Inter-agency Fire Center (NIFC) for the U.S. here. They coordinate the fire crews across the country during the wildfire season. Years ago when my son was in scouts we got to go tour the command center. It was fascinating watching all that goes in to planning how to respond to the multiple fires that are going on at any give time. My hat is off to the fire fighters and smoke jumpers. They are putting their lives on the line every time they go out for one of these fires. /dwight
  23. @Mulesaw - sorry to hear about your wife's cancer. As you and others have noted, the early detection should go a long ways towards knocking it down. I lost my first wife to pancreatic cancer, which has a tendency to hide undetected until too late. Here's hoping that the side effects of the treatment are mild and the recovery is quick.
  24. Nice!! Very fitting for the day. Thanks for sharing.
  25. Beautiful work.
