AlZilla
Moderator
Everything posted by AlZilla
  1. Your question reminded me of the following thread where an admittedly talented, accomplished leather crafter turned out a piece using only entry level tools (Tandy). Take a look at the high level of work. We have a few members here who make their own stamps from bolts they've ground to whatever shape they want. So, I wouldn't get too wrapped up about using a starter set. The cost is usually below what you'd spend seperately.
  2. @RoamingRanch, I'd be surprised if it did so satisfactorily. Since it's local to you, go take some leather and have a run at it. Maybe report back your findings so the next person has a baseline?
  3. @PrecisionSewer, I moved this to For Sale. You'll need to add a price, location and some pictures, per the Marketplace Rules. Thanks
  4. That's just PHD-level sewing knowledge that you aren't gong to find anywhere else.
  5. I've seen people showing off their Texas inmate-made holsters, and pretty nice stuff it is, too. I can't find the specific link at the moment, but here's a link to the "Leather" page for the Hunstville, TX Musem shop: https://www.txprisonmuseum.org/shop-2?page=9 You have to hit "Load More" 7 or 8 times see see it all.
  6. Amazing. Thanks for taking the time to post it.
  7. Same search on Duckduckgo, 1st result: https://duckduckgo.com/?q=duncan+des+165-970&t=brave&atb=v430-1&ia=web Regular search, not image. Interesting.
  8. I don't know. It looks a lot like this patented knife sharpener: https://patentimages.storage.googleapis.com/b3/8f/f0/a3ad8bd5a091e9/USD165970.pdf Patented by Mr D. D. Duncan.
  9. Given that Mallory hasn't been here since she made that post, let's tag her like this @Mallory and hope that she's set up to receive email notifications. Mallory, you'll want to exercise all due caution when dealing with unknown parties. Good luck, folks.
  10. AlZilla
    Goatskin Hides
    Where do you ship? This is a global forum so you may get orders from anywhere. Welcome aboard. We hope you will participate in the forums.
  11. However well intended, that sounds like heartache waiting to happen. I'm going to gamble that we probably shouldn't host the discussion. Also the whole tariff discussion is just going to devolve into politics.
  12. @BurntLeatherCo, you probably need to resize the pics. The usual advice is a max of 800 pixels in whatever the longest dimension happens to be.
  13. Wallets, belts, key chains and coasters all seem like popular rookie projects. I bought one of those "starter kits" that had several small projects like that. The nice thing there was it had all the leather and tools I need. It saved looking for and cutting out a pattern right away. I didn't have to worry about which thread, needle, etc. I got straight into the dyeing, sewing, stamping, burnishing part.
  14. I usually wet the leather as if for tooling, lay the pattern on it and trace with something blunt. Ballpoint pen works. Laser owners can laser engrave a pattern. I bet there are more ways.
  15. Wow. That is a great way to use the beaver tail. Definitely eye catching against the rabbit. I just got a few beaver tails last week that need a use.
  16. Al Bane has a video where he suggested learning by buying a hide and making belts for all your friends. My friend are still waiting ... But it seemed a good idea.
  17. I think you got a great job of it. The stitching is straight and neat and you managed to keep that stamp aligned over the whole field. I think you've got a knack for this craft.
  18. 2nd or 3rd post, he said he used a regular sewing machine foot controller.
  19. Hi Vincent, I won't say for certain because there's much I don't know. However, I'd see no reason why not. I have a much older 22W156 twin needle that came to me with one needle and I've sewn with it that way. In my case, the second hook was disabled by adjusting the gears apart. Wait for one of the big dogs to chime in. There may be some downside I don't know about. Also, why not sign up for an account? It'll make communicating, getting notices of replies and so on much easier. Welcome aboard.
  20. @washe, I split you out into a new topic in the Saddle and Tack area. Maybe you could post the specific pattern you're using and tell us if you've made all the pieces to the exact specified length? A picture would be worth a thousand words, too. I don't do saddles or halters, but this is where the experts hang out.
  21. Yep, @CowboyBob, somehow you linked to the copy on your harddrive instead of uploading it. Seems like it ought to be around here somewhere ... darned if I can find it, though. EDIT: Last post in this thread might be what he's trying to send:
  22. Wow. Fine Art that happens to be in leather. Thanks for posting it!
  23. Well, without a lot of context to go on, I'll relate a similar experience with my 111W class machines. I was having on and off problems where the bottom stitches would get tangled and the workpiece would pull out from under the needle hard. There would be 2 or 3 strands of thread coming out of the needle plate. Finally I noticed that when that happened, my needle thread was split on the hook. It turned out I was holding my threads back way too hard when I was starting to sew. I only hold back lightly now and haven't had a problem since. You'll see advice here to "hold the threads back hard". But I think that applies to larger machines, like the CB4500 and such. Maybe someone else will comment.
  24. I moved this over to Suppliers since it seems like you're trying to create a resource list of people and companies that repair leather items. If I got it wrong, let me know and we can figure out where you might get the best response. Leather Sewing Machines wasn't it.
  25. Assuming you want the band permanently attached to the hat ... How you attach the concho strap kind of depends on how it all comes together in the back. Some options are to use Chicago screws or hand sew. Is it going to join between conchos, or under one of them? You could butt the ends of the band and use an X stitch or a corset stitch. You could skive the ends to a taper and overlap them. Maybe all the parts could join at center/back between conchos, everything could butt together and use about 3 rivets on each side of the joint to join it to the hat. It you want it removable, I would skive the ends of everything to a taper, glue and sew them. You could look at how bullet loops are made on gun belts for how those conchos might attach.
