AlZilla
Moderator
Everything posted by AlZilla
  1. Here you go, the definitive guide on the entire Internet: Come back once you have a few in mind and ask for current recommendations.
  2. Chuck nailed it, as usual. My biggest issue with hand stitching has been when I don't hold the stitching chisel exactly straight up and down. The side I punch from will be a nice straight line and the other side will wander the opposite of whatever way I leaned the stitching chisel. Some pictures would probably help.
  3. Looks like you've been busy. I've tried that snaky looking pattern in the middle a few times. It seems simple enough but soon it looks like Otis the drunk took over. I should probably stop calling myself Otis. I definitely like the mystery braid looking work on the edges. Is it a stamp?
  4. You've been working on this a long time. It's an enviable hat, for sure.
  5. Forum rules require a price. You're probably outside the edit timeout but you can add it in a reply. Thanks
  6. None of it looks genuine to my eye. The upper white part just looks like some kind of embossed, embroidered man made product to me. The lower part, I don't know, but look at the last pic, the boot on the left. Look towards the top (of the lower piece), the left side, where it curves up and then back towards center. That edge looks like it's de-laminating. The whole edge just doesn't look like a natural product to me. Where the strap ends are coming apart at the top just doesn't look right, either. Too frayed and thin. But then, pictures can be quite different than having something in hand. I hope I'm wrong.
  7. If I recall, the size range for v138 is 19 to 22, so maybe a smaller needle. The process for turning a corner is stop at the corner with the presser foot all the way down raise the needle about 1/4" from bottom raise the presser foot turn the workpiece drop the presser foot keep going Actual experts will be along after they have their coffee.
  8. I slipped this over to Leather Sewing Machines. You're more likely to get responses here. It was in the Marketplace/Services forum, which would be for offering services. The are some patcher experts here.
  9. This is a great question. As a rookie leatherworker, edge bevelers is something I've also been struggling with. I'm looking forward to the answers.
  10. There was a similar issue here maybe 6 months ago or more. The consensus was that some kind of metal fillings had contaminated the hide, if I recall correctly. The vendor replaced the hide. That makes more sense than mold forming in an hour or two, I'd think. Even over night seems too quick for mold.
  11. Not to be a smart Alec, but couldn't you just measure the machine? Maybe if you were in doubt, you could cut a test in a stiff piece of cardboard?
  12. Blue Guns, Dummy Guns and purchased patterns only get you so far. Nothing beats real world testing and evaluation. Maybe this is a good reason to buy one of every gun for which you're asked to make a holster.
  13. I slipped this over the The Marketplace, since it's really a For Sale ad and has all the requisite information. I see where you've posted these in different parts of the forum over the years, but this is the first one with a price and actual offer to sell. Edit: found a duplicate post which I merged here, as it has more information regarding these items.
  14. A couple of rookie comments - that looks like a Singer 111W foot. Many machines use them and there are many variations available. Might be worth checking. Next, when I've read about machines bring adjusted to backstitch into the same holes, it's usually at a certain stitch length. Changing the stitch length, changes where it backstitches. Maybe this will cause one of the big dogs to jump in here and tell us if this applies to your machine.
  15. I moved you over to Leather Sewing Machines, where you're more likely to get some help. I'm going to suggest that you join the forum here so you'll be able to receive notifications about replies. I believe this machine has been talked about here quite a bit, so searching may uncover what you're looking for.
  16. Wow. On second look, I see that those are working machines, with the thread, oil and tools. Very nice setup!
  17. Greetings and welcome aboard, @PiZhihong. Looks like you navigated some translation issues and got your post sorted out. Thanks for the effort. The pictures look like a sewing machine store? I see a Cowboy machine, very popular in the US.
  18. Aha! I've seen them on rifle slings, now that you say it. Thank you.
  19. I know, I should know what this is called. But .... The hooks are the important part. How many attachments at the top doesn't really matter. I want something about 1.5" wide. Any help?
  20. Wow, that's some hard work that really paid off. I agree, wrestling that bad boy up and down off the floor would be a bear. Is any weight resting on that wooden triangle block under the cylinder arm? I remember you shortened that table up (I think that was your project). The manly clutch turned out quite well. I like the alternating color of the layers around the gusset. Burnishing them to a slick finish might give an interesting effect.
  21. I quite like that. If I used such things, I might make one myself. You're being way too critical of the basket stamp. I wouldn't have thought anything of it, had you not mentioned it. At least it doesn't look like it puked out the back of some factory in an unpronounceable Asian city, along with 9,999 others just like it.
  22. Your question reminded me of the following thread where an admittedly talented, accomplished leather crafter turned out a piece using only entry level tools (Tandy). Take a look at the high level of work. We have a few members here who make their own stamps from bolts they've ground to whatever shape they want. So, I wouldn't get too wrapped up about using a starter set. The cost is usually below what you'd spend seperately.
  23. @RoamingRanch, I'd be surprised if it did so satisfactorily. Since it's local to you, go take some leather and have a run at it. Maybe report back your findings so the next person has a baseline?
  24. @PrecisionSewer, I moved this to For Sale. You'll need to add a price, location and some pictures, per the Marketplace Rules. Thanks
  25. That's just PHD-level sewing knowledge that you aren't gong to find anywhere else.
