Mablung
Everything posted by Mablung
  1. I guess the lack of prevalence of fighting with swords obviates the need for very strong but flexible steel of the type. The knives I have are probably just prettier than others of similar steel. Still, I like it. It's snazzy. Sometimes, that's enough. Anyway, enough of my thread hijack.
  2. You know, was just reading something indicating Wootz steel was actually a form of particle metallurgy, not a means of pattern-welding, as I thought. So, I may need to stick my foot in my mouth over this one; that will have to wait for tomorrow. But, figured I'd throw that out there, since I probably made a few eyes roll, and may have proven the maxim from the Book of Proverbs, "It is better to be silent and thought a fool than to speak and prove one's foolishness." As I think about it, I think I do need to walk back my rant about the two methods of manufacture being essentially the same; they aren't. But, given that true Damascus was a particle steel, I wonder what would happen if one were to etch currently popular particle steels, like the S30V a couple of my knives are made from. Interesting question. Then there's the point the article I read made, which is that it's not clear why "Damascus steel" is called that, with one theory being it was a derivative of the Arabic word for water, "damas," and that being applied because of the wavy appearance of Damascus steel. That makes me wonder if my rant against pedantry still has some basis, albeit on different grounds, but that is a question for tomorrow.
  3. Ironically, then, "Damascus" steel isn't truly "Damascus," either, insomuch as it didn't originate in Damascus. It does share the same pattern, though, and it sounds like all forms of "Damascus" steel share the feature of pattern-welding techniques being the basis of their manufacture, and the pattern comes out through acid etching (which also occurs through patina of high-carbon steels developed through use). Personally, I've always found the insisted distinction between "pattern-welded" and "Damascus" silly for that reason. I think it's a distinction without a real, meaningful difference. I get that someone may point to the great flex of "true Damascus" as opposed to "pattern-welded". The same response applies, however, because the degree of flex is a function less of pattern-welding/Damascus manufacture in and of themselves but of using specific kinds of pattern-welding techniques and combinations of steels and other materials to highlight certain characteristics. All steel flexes to some degree. Sword blades need to more than others, and the necessary flex can be achieved using steels not made according to the Damascus method. The importance is less the Damascus method and more the materials. The Damascus method did so more cheaply, yes, I understand that, so it had some advantages that made it desirable, and the patterns look sexy. But it's still pattern-welded, just by different means than people use today to create patterned mixtures of steels with certain characteristics. So, I don't like the distinction because it seems to me emphasize differences that are not innate to the materials or the process of combining metals to make the patterns and produce the desired properties. Viewed in that light, "Damascus" and "pattern-welded" mean the same thing. Okay, rant over. To those who still maintain there's a meaningful distinction, feel more than free to make the distinction. I can be a pedant with the best of them (or, depending on one's perspective, worst), so I have great respect for all pedants. I just think this distinction is overly and needlessly pedantic. Please, for the love of all things good, do not let this turn into the M&G debacle. I just wanted to vent my annoyance at what I think is a needless but harmless distinction that doesn't make real sense (to me) to insist upon.
  4. Thanks for the writeup. That's really interesting, and a good advertisement for using Mop & Glow as an acrylic finish for those who want a leather-appropriate and highly effective finish. I may have to get some for some knife sheaths I'm making. I also appreciate someone who also appreciates a good pistol optic.
  5. I've got some great fixed blade knives in pattern-welded Damascus. If I could get a round knife from the manufacturer, I totally would. It's well stretched and folded together, based on the manufacturer's literature and videos, and with a little elbow grease to get the bevel set, it sharpens to a mirror polish like a dream. Holds the edge well, too. You know, I might ask them if they could make one to the pattern of my Al Stohlman knife; it'd be way better than the poorly-heat-treated D2 that knife uses...or I could make one out of a billet of their steel, since the company sells billets...hmmmmmm...
  6. I thought of it as well. Fortunately, this chap is a little better about considering a suggestion politely, without becoming snarky and insulting.
  7. It depends on the style of thing you want to make. I've made my wife and sister purses out of 4/5 oz. oil tan that are soft and pliable, not a ton of structure; they were meant to be that way, with one big compartment and a flap closure. I made my mom a tote bag out of 5 oz. chrome/oil tan (S.B. Foote utility side—overrun of Red Wing boot/shoe leather) that is stiffer and has more structure, but still basically soft. Look around on here for different things people have made. You can get some different "looks" and structure if you use 3–5 or 6 oz. veg tan for a purse, depending on just how structured and rigid you want it to be. There are a lot of good exemplars for wallets, including clutch-style wallets, on here, too. The consensus seems to be that the outer panel should be 4 or 5 oz. at the most, with 2/3 oz. pocket panels, plus maybe a thin liner. Otherwise, you'll have too much bulk that will require endless skiving, as already pointed out.
  8. You know, that makes sense. I wasn't getting much burnish until I was nearly done. The last few inches of beveling burnished nicely, so I think you're right. This was 2/3 oz. shoulder, so I could easily have let it dry a few more minutes before doing the cuts and beveling. I probably added more water than was really necessary, but I wanted to make sure the color stayed even, since I was leaving it natural instead of dying it.
  9. Fredk's method would work well if you are wanting to mold a slip/sleeve sort of case. (Correct me if I'm misunderstanding the design, fredk.) Saddleback's method is for making a case that grips the edges of the frame with a raised lip, like most cases people use now. Saddleback's video is pretty complete, so with some watching and rewatching, a little measurement and math, and a couple attempts, it shouldn't be too hard to clone, I don't think. I've got that on my list of projects.
  10. Thanks! Shoulda been more clear on the carving. The barn is inverted and originally I was going to do all of it inverted, but spur of the moment as I was beveling, I decided to do the other elements in relief instead. Make them stand out as the focal point and let the barn fade into the background. The inverted portions are by no means even, but it makes the beams look a bit darker and at least a little bit more "woody" that way.
  11. Did this as a quick project to hang on my office door at work. It turned out much better than I thought it would. All I did to finish it was give it a couple coats of NFO and punch a couple holes for a piece of dark green chrome-oil-tanned scrap to act as a hanger string. Would appreciate some pointers on the backgrounding and beveling. Can't figure out what to do with the beveling, as it keeps coming out choppy, even if I make small moves and many strikes. I used a matting tool for part of the background, mostly to fade out the beveling on Mary, Joseph, and the manger and Jesus. The star points along the barn roof beams didn't come out right, but I didn't realize that would be an issue until I had done the swivel knife work and beveling.
  12. Is that when cleaning with the pumice hand cleaner? I assume so but wanted to make sure I hadn't missed a change in tack in regard to cleaning. If so, that looks pretty good, as long as one doesn't mind any later finish being a bit matted due to the surface scratches.
  13. @ThomG To state Chuck's point another way, the pumice takes off part of the surface. The surface is slightly glossy because the very, very top layer is glossy. Thus, removing the gloss = removing part of the top layer—thereby damaging the leather. Unless, of course, you desire to take off the top. Then you have achieved your end, but if you want the leather to stay intact, then you've damaged it.
  14. That's a risk of using an IWB holster generally. The specific concern here, however, is with ensuring the leather retains its structural integrity so that the holster itself does not collapse and cause an accidental discharge. One should always look while holstering with an IWB holster of any material, but using insufficiently-rigid leather can cause additional problems.
  15. That's the place to be. I used to sit on the bluffs overlooking a local lake for hours on end, staring through my spotting scope.
  16. Sometimes gotta dial something in at closer distances before pushing it faster. I'll bet that long slide and barrel help with recoil attenuation, though.
  17. I went hunting last Saturday and didn't see a single deer, but I saw and listened to plenty of songbirds. I used to watch birds avidly, when I was younger, but I haven't had the time to do so in quite a while. it was a great treat to watch them again.
  18. That is incredibly neat. Well done.
  19. So's the one shooting it. What distance?
  20. If it's the same story I've seen, it was a Glock 19 (Gen 3, if I recall correctly); arguably the most prolific double-stack carry gun. The main thing about handling firearms is to not be stupid. Or, as I like to say and a law school friend of mine turned into a favorite aphorism through our frequent use: "Be thou not a dipstick." The same thing goes for holster design and maintenance. Imagining someone with that build trying to carry AIWB is painful...
  21. My backgrounder is checkered, but its small surface may not allow that to come out as clearly. Seam ripper it is. I slicked some edges but didn't finish them off because I realized I needed to reconstruct a few components. They'll get slicked properly once I've redone a few things. (I need to adjust the belt strap and safety snap.)
  22. Always a good reason.
  23. I made a new sheath for one of my knives, fold-over with a welt. I'm going to ask for critique but am posting it in this thread because, frankly, I was pretty pleased with the tooling and wanted to show it off a bit, which really means I thought it was going to look like crap, and I was pleasantly surprised when it looked like less than crap. Besides, I like oak leaves and wanted to make a foray into them with a simple design on a hunting knife sheath. Now, for the suggestions requested. I screwed up with the welt and left some of the stitching bare (thus the loose stitch at the end: the tip of the knife cut it). I have two questions on this point: How should I measure the welt, and how can I take the sheath apart with relative ease to redo the welt to get it right? I think I'm really asking how to efficiently undo the stitching (saddle stitch), as cutting apart the cemented portion isn't too difficult, with some care. I may also trim the shape so that it looks less like it houses a cleaver and try to match to the blade shape more effectively. On the tooling, what can I do to clean up the backgrounding? I used a combination of a small backgrounder and a matting tool, but I don't think I understand how to background. I couldn't get an even texture to save my life.
  24. What's the 17L for? Hunting, competition? Wouldn't think the latter, since it's in a thumb-break crossdraw holster, but the model is just an oddball mostly used by competition shooters. I like the balance of long-slide models, though.
  25. Holy crap, that's a whomping welt. I was trying to figure out why you would need a welt that thick, then realized you were stacking it up the thickness of the trigger guard. Definitely not busting that thing. Nice work.
